MS FS 2004 ---minimum equipment for IFR
Old December 20th 03, 05:11 AM
Gerald Sylvester
Default MS FS 2004 ---minimum equipment for IFR
I just got my PPL and heard from some ATP rated friends that using
MS FS 2004 could help a bit for getting down some of the navigation
techniques for IFR. I figure for $50 that is about 25 minutes in
a IFR GPS equipped plane.
What is the minimum equipment *really* required to use MS FS 2004?
Right now I have a new Dell Latitude laptop. I have a mouse
and that is about it. Joysticks? Foot pedals (cost?)? I don't want
it to replace flight since I can just get in a real plane but I have
heard from many people that it is quite good. I want
it more for the instrument training.
I have no idea about this since the last MS FS I had was back when I
had an IBM PC jr. (no joke).
replies will be directed to: rec.aviation.simulators.
Gerald Sylvester
Old December 20th 03, 07:10 AM
Dallas
Minimum? I'll let some one else answer that.
But make this mental note: Somehow Microsoft released FS2004 to match the
state of the art in personal computing on the very month it was released.
In other words, to be able to "max all the slider to the right" and have it
run well, would require the purchase of everything that was new at that
minute. i.e. 3 Ghz processor, PC3200 ram, and a $199.00 to $499.00 graphics
card. Many of us spent upwards of $700 to upgrade our computers for this
$50 program.
As you start to slide the settings to the left you can make it run on older
equipment. The trade off is a loss of realism in weather and out the window
detail.
That said, I'll let everyone else fill in the details.
Dallas
Oh, personal opinion: Using FS2004 as a PCATD would seem to require rudder
pedals.
"Gerald Sylvester" wrote in message
link.net...
Gerald Sylvester
Old December 20th 03, 09:04 AM
Dashi
"Dallas" wrote in message
nk.net...
You'll need at least six inches but the way Nomen is talking about you, I
doubt that you have an inch.
Christ, even Dallas is probably better qualified than you.
*PLONK
Dashi
Old December 20th 03, 11:48 AM
On Sat, 20 Dec 2003 05:11:55 GMT, Gerald Sylvester
Gerald Sylvester
Try Microsoft.public.simulators or rec.aviation.simulators as you'll
get more technical replies but include your laptop spec.
My 1.5GHz Homebuilt PC is good for FS2004 (frame rates near 20's) but
the 1.3GHz Compaq N115 does not have a fast enough video card (frame
rate around 5) and is useless. Can only run FS98 with any realism!
Either are progs useful for IFR practice.
David
David
Piper Warrior G-BHJO
Scotland, UK
E-mail (Remove Space after pilot): pilot
Old December 20th 03, 02:19 PM
John T
link.net
techniques for IFR.
In my experience, MSFS is good for that and instrument scan (once you
understand proper scanning techniques). The feel isn't quite right for a
good substitute for actual flight even with a yoke and pedals, so you're
right not to expect it to replace flight time.
I use it with nothing more than a force feedback joystick (mine's a MS
Sidewinder 2). Assuming your laptop can handle the graphics and has a USB
port for a USB-based joystick, you should be OK.
Spend some time with an instructor in a FRASCA or other training simulator
to learn the basics of instrument scan and basic instrument techniques
before dedicating a lot of time to MSFS. Otherwise, you may learn a lot of
bad habits from MSFS that you'll have to spend money unlearning in the
plane.
John T
http://tknowlogy.com/TknoFlyer
____________________
Old December 20th 03, 02:37 PM
Blanche
Gerald:
The benefit of MSFS for IFR training is not so much the aircraft
and controls but learning the scan of instruments, working the
avionics (vor for victor airways and ILS, adf & dme, gps, etc) and
getting familiar with the process. Start doing the IFR stuff with
VMC mode (see where you're going) then go to IMC mode when you
want more challenge. I'm using a joystick, no big deal. If I want
to practice with an airplane, I go out to the airport. When
practicing IFR I really don't care that much about the handling
characteristics of the aircraft (other than making sure I meet
the correct speeds without crashing).
Remember, for IFR practice, the goal is scan and avionics. Then
when you get into the aircraft, you're comfy with that. But make
sure you have a correct/good scan!
Old December 20th 03, 03:29 PM
Gerald Sylvester
Thanks everyone. Sounds like it is a go. For the joystick I'll
probably just spin by Fry's to check them out. The people here
said the same thing as my friend's regarding the instrument scan
(I've got a whole 5 hours of it during my PPL, I'm a pro
already.....grin). Tracking VOR's is easy. ADF same.
Will also help with ILS, HSI (none of the planes I flew had them)
and other techniques. I'll let you know how it works on my
1.8 GHz laptop.
thanks
Gerald
Gerald Sylvester
Old December 20th 03, 08:41 PM
Dashi
Good advice but it's wasted on a moron like Sylvester and his crony Dallas!
With an idiot like that flying an aircraft it would be a good idea to take
up sailing.
Dashi
David
David
Scotland, UK
Old December 21st 03, 03:19 AM
Judah
If you just got your PPL, you might want to spend some time flying VFR
before jumping into the IFR training.
From my experience, Flight Simulator can definitely help you with your
navigation techniques, but it almost definitely will NOT significantly
help you learn to precisely control the plane, regardless of whether you
use a yoke or the keyboard. It's just not real enough. At least that's
how it's been for me.
Where it helped me most was with VOR tracking, holding patterns,and the
like. When you read the books and see videos and all that, it kinda makes
sense. But when you open up the Map view, and turn on the feature that
draws the red line over your track, it makes a WHOLE lot of sense very
quickly.
The key is (IMHO), you first need to be able to keep the plane on heading
and altitude without requiring too much attention before you can start
also thinking about hold entries or approaches and following bouncing
needles and reporting positions and such...
Beyond that, for what it's worth, I wouldn't even worry about using 2004.
I use 98 and it works great. But 2002 has some ATC communication built in
I think, so that might be worth something. I don't really know about
2004, but MS generally has a policy of intentionally building new
versions that are bigger and hungrier than previous versions just to
force you to upgrade the computer and OS. So if you're not sure you have
the minimum equipment, you might consider finding an older version on
EBay or something.
Just my 2 cents.
Gerald Sylvester wrote in
link.net:
Gerald Sylvester
Old December 21st 03, 03:32 AM
Dashi
The only place that he would be welcome is : alt. family.tree.doesn't.fork
Dashi
"An Metet" wrote in message
ster...
NOTE: This message was sent thru a mail2news gateway.
No effort was made to verify the identity of the sender.
Speedbyrd squawked:
Maybe YOU should. You're the one that seems to have the problems. Hiding
behind a remailer.
The Speedbyrd :
Dude, you sure get around. First everyone killfiles you in alt.video.dvd,
last week you get
laughed out of alt.rec.guns, and now you're here. Keep trying, Dude. Maybe
you'll find someplace
that won't see you as a steaming turd that needs to be stepped over.
24 Sep 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 September 24th 04 11:08 PM
Squawk Sheets Greg Esres Piloting 23 August 23rd 04 08:15 PM
Flying when you know there is something wrong with the plane C J Campbell Piloting 26 January 14th 04 04:38 PM
09 Jan 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 January 9th 04 10:05 PM
