FS2004: Ceilings/visibility too high
Old March 12th 04, 06:19 PM
ajohnson
Default FS2004: Ceilings/visibility too high
I am a private pilot with an instrument rating and one
of my primary uses for MSFS is practicing instrument
approaches. I like to set the cloud deck to the minimum
ceilings for that approach (e.g. 200 ft and 1/2 mile vis
for an ILS), plus winds etc, so I break out of the clouds
right at minimums or close to it.
On FS2002 this worked fine. However, when I 'upgraded'
to FS2004 I now find that the in-cloud visibility is much
too high. For example, if I set the ceilings to 200
feet overcast (8/8) as above, I may start seeing the
runway while I'm still as high as 1000 feet! And looking
out any view but the front of the plane is even worse.
I've tried about every combination of video settings I can
think of, to no avail. Increasing cloud texture to max,
reducing it to min, cutting terrain display to minimum etc.
Reducing visibility helps some, but not enough. Bearing in
mind that I don't care about outside graphics, just smooth
instrument and airplane response, any suggestions?
My setup:
AMD Athlon 650 w/ 128 mb RAM
geForce 2 video card (32 MB?)
TIA
Allen
Old March 15th 04, 10:55 AM
David
Go to World/Weather/Customize and set Cloud 8/8 and Visibility (1/2ml)
Make sure the check box is set to User Defined.
Select Advanced Weather then Visibility Tab.
You can now set the cloud Tops & Base.
If using 1ml horizontal then you need about 1/2 ml Vertical Tops
(3000ft?) and Base near Zero so you can't see down.
You ain't going to see much now!
So where is that runway?
I use the same prog for IMC practice and it's very good though it's
easier to fly the Warrior for real as it's more stable than the FS
aircraft.
David
Piper Warrior G-BHJO
Scotland, UK
E-mail (Remove Space after pilot): pilot
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS MT. DIABLO HIGH SCHOOL PHOTOS Home Built 1 October 13th 03 03:35 AM
Disappointed with FS2004 Phiber Optik Simulators 5 October 12th 03 04:13 PM
Bridges in FS2004 Kevin Reilly Simulators 18 October 2nd 03 11:00 PM
High Flight NOTAM Kirk Stant Military Aviation 1 September 10th 03 03:31 AM
