Starting Prop Engines in FS2002
Old August 30th 04, 04:52 AM
Default Starting Prop Engines in FS2002
Hi,
I know this should be easy, but it's proven not to be.
The jet aircraft have 'auto start' and the engines crank up in sequence
just fine.
Props are becoming problematic. What is the sequence for starting to
Beechcraft or Baron props? Is there an 'auto start' command?
Thanks,
Honus
Old August 30th 04, 08:40 AM
Scet
Hi,
just fine.
Thanks,
Honus
CTRL E
Scet
Old August 30th 04, 12:53 PM
nooneimportant
I know for a couple of the planes you can't "HOLD" the switch/dial in the
start position, and instead have to keep clicking to the start position to
get it to go. I know that the KingAir has this issue. Think the Baron may
be the other. Don't remember the exact starting sequence. CTRL E will get
an autostart. HOWEVER if you fail a manual start due to something that is
not in the normal start procedure, the computer will not be able to start it
either!!!!!
Hi,
just fine.
Thanks,
Honus
Old August 30th 04, 02:54 PM
Paul Riley
"nooneimportant" no.spam@me wrote in message
newszEYc.70350$9d6.9417@attbi_s54...
may
get
it
either!!!!!
King Air DOES NOT have the issue, at least on my installation. I manually
start it every time, one engine at a time, and clicking on the starter, it
stays in the start position until I release the mouse button.
Manual start sequence is in the check list.
Only aircraft I fly, works just fine.
Paul
2 Engines - 1 Prop...ME Rating? Andy Asberry Home Built 16 January 20th 05 05:14 AM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Hot Starting Fuel Injected Engines Peter Duniho Piloting 23 October 18th 03 02:50 AM
