Hi
Now with more time on my hands, just got back into Flight Sims. In order to mimimise background progs running and slowing down any flight sim applications, I always start from a basic msconfig startup setup. With regards to Windows Task Manager however, I've never disabled anything, at the risk of fowling up. Any guidance with regards to which applications it is essential to NOT disable would be appreciated. Is there anyway of saving and booting with these preferences.............. like the "old days" with a boot disk... Thanks John Helligsworth |
"John Hellingsworth" wrote in message
... Is there anyway of saving and booting with these preferences.............. like the "old days" with a boot disk... First, try to understand that not all processes listed in the Task Manager are really problematic for running FS or other games. Generally speaking, what causes problems are *non-idle* processes that a) use significant CPU time and/or b) use significant amounts of RAM *when they are active* (an idle program listed in the Task Manager that uses a large amount of RAM does NOT affect performance). For most of the processes listed, they don't do either, and eliminating all them might give you a 1% improvement at best. Processes that are likely to take away from game performance are likely to be those that you have explicitly approved. Things like email programs (which are usually configured to "wake up" periodically to check email) for example. These are usually easy enough to stop just before you run a game. Personally, I exit all applications before running a game, and don't bother with any of the other processes. It's just not worth the time and hassle, both with respect to figuring out what I can stop and with respect to tracking down problems if I accidently stop something that turns out to be important later on. (Terminology note: I'm using "applications" and "processes" in the same way that Task Manager does. An application is a process with a top-level window with which you as the user can interact. All applications are processes, but not all processes are applications. There should be NO applications that you need to run, but there are processes that are required.) With all that in mind, it's not too hard to reduce the process load on the computer, nor to do it by default, if you are willing to use regedit. You can save and restore the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es key, which contains the settings for which services are enabled or disabled (of course, the key contains many other things too, but it won't hurt things to load those settings too, as they'll be the same each time as long as you don't change them). Basically, go into regedit, save the current state. Then go into msconfig (or the Services control console) and disable whatever services you don't want to run. Then go into regedit again and save the new state (under a different name, of course). At that point, you ought to be able to simply restore whichever settings you want and reboot. You can do similar things with the other kinds of processes that start, but they are going to be harder to find. The easiest ones are in the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run key. Some legacy stuff might still be found in system.ini or win.ini, and there may be things in the "Startup" menu. Since these are all either files or registry entries, it's easy enough to save and restore settings you want, but obviously the wider variety of things you want to mess with, the more hassle it will be to go each and every one. You could create a batch file to handle the hassle though (registry settings can be restored using the "reg" command line program, and files obviously can just be restored using the "copy" command). Most people wouldn't bother with any of that, even if they found services and other stuff they don't want running. For many of the services, you don't really EVER need them, so it's safe to simply disable them permanently. There are web sites that have pages dedicated to listing which services you can do without; since I don't bother with that, I don't know them off the top of my head, but Google ought to find them for you easily. Like I said, personally I don't find it worthwhile to do ANY of the above. It doesn't produce a performance improvement that justifies the hassle and headaches. Your mileage may vary. ![]() Pete |
On Sat, 18 Sep 2004 21:42:46 GMT, "John Hellingsworth"
wrote: With regards to Windows Task Manager however, I've never disabled anything, at the risk of fowling up. Any guidance with regards to which applications it is essential to NOT disable would be appreciated. Is there anyway of saving and booting with these preferences.............. like the "old days" with a boot disk... Thanks John Helligsworth Hi John. I've been using FsAutoStart, and found it really is a nice way of trimming down XP for flight sim use. I use to while I fly Aces High on-line with excellent results. The program will stop programs and services, launch the game, and upon exit re-starts everything that it stopped. In addition, during the configuration setup it gives some pretty good advice on what's 'safe' to stop and what is really needed. Here's a link http://www.softpedia.com/public/cat/12/2/12-2-188.shtml Take Care, James Lerch http://lerch.no-ip.com/atm (My telescope construction, Testing, and Coating site) Press on: nothing in the world can take the place of perseverance. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. Calvin Coolidge |
![]() "James Lerch" wrote in message I've been using FsAutoStart, and found it really is a nice way of trimming down XP for flight sim use. I use to while I fly Aces High on-line with excellent results. The program will stop programs and services, launch the game, and upon exit re-starts everything that it stopped. In addition, during the configuration setup it gives some pretty good advice on what's 'safe' to stop and what is really needed. Here's a link http://www.softpedia.com/public/cat/12/2/12-2-188.shtml -- Thanks for the tip. FsAutoStart works very well. |
