Marske Flying Wings do not stall
Old July 31st 03, 04:50 PM
Marske Flying Wings
Default Marske Flying Wings do not stall
I did a modest cross country in the Pioneer IId yesterday but what is most
interesting was that I am exploring all of the flight envelope and yesterday
was stalls. When I pulled the stick all the way back slowly I suddenly found
that my airspeed had fallen to zero where I held it for quite some time and
my sink rate was 100 down. And I have it on video! I did this many times
although there was tendency to turn to the left since we have a left turn in
the glider.
The airspeed system was calibrated recently, both the airspeed instrument
and the installation, however I did not do the calibration for zero
airspeed... so it could be off slightly.
I have posted a picture on the web site showing the airspeed near zero and
will post a video shortly.
http://www.continuo.com/marske/pione...%20pioneer.htm
This is rather a long address so if this does not work go to our web site
and find "Marske Pioneer IId"
-mat
I have been recording all of this on video to give some credibillity to my
claims.
Marske Flying Wings
Old July 31st 03, 07:27 PM
Marske Flying Wings
No this is where you are quite wrong! There is pleanty of up elevator on the
trailing edge of the main wing.... the air going over the top is separating
due to the high angle of attack and this makes the elevator ineffective, so
the nose lowers slightly and the glider picks up airspeed and it resumes
normal flight.
"spektr" wrote in message
Bravo.
So you are flying a glider with insufficient up elevator to cause a stall
equipped
with an airspeed indicator that doesn't register well on the low end of
spectrum.
All wings stall when their critical angle of attack is exceeded. In its
most benign
form a stall will be recognnized as a slight vertical oscillation without
a
discernable
break. If you had more elevator authority, it would get into this flight
mode. Its inability
to do so indicates a lack of elevator authority at slow speed.
Your airspeed indicator reading zero means you are flying at a speed less
than the minimum
required to move the needle. You are probablu using a run of the mill ASI
for airplanes.
Nothing wrong with that, it just means you are slower than the gauge can
indicate. You
might consider an ASI for helicopters, they are much more sensitive at the
lower end
of the spectrum and will probably give you a better indication of whats
going on.
If you want to make your glider even more efficient, replace the ASI with
a
Mach Meter.
Then you can get 30 something to one l/d with an indicated airspeed of
ZERO.
OBTW, Its impossible to fly with an airspeed of zero, lift requires air
movement over the wing
on any conventional fixed wing airplane. You by definition still have
airspeed if you are flying.
Scott
Scott did you miss the part in my posting where I said this airspeed was
calibrated by itself and then while in the glider at differing airspeeds
from 40 mph to 80 mph. using a GPS method posted on our website. It is also
helicopter airspeed. Now I do think that at about 20 mph the airpspeed goes
to zero... but again I did not test it in the aircraft for this slow a
flight. What did confuse me was the low sink rate... but I could have been
in rising air... and next time I will check my GPS groundspeed. But I have
this on video and will post it for all to see.
I was actually quite surprised myself and do not really know what to think
of it. By the way this aircraft has a 3.6 lbs per sq ft wing loading and I
easily fly at 90 to 100 mph. and I have videos of that too. Again that part
of the spectrum has not been calibrated but it is interesting to see how
well it flies at that speed. I will push for 130 mph in the sping when I
have redone the canopy and fuselage.
-mat
Old July 31st 03, 08:00 PM
Bob Kuykendall
due to the high angle of attack...
Sounds like a stalled condition to me.
Bob K.
Old July 31st 03, 08:05 PM
Al
So its under elevatored then.
Al
"Marske Flying Wings" wrote in message
separating
so
normal flight.
Bravo.
stall
equipped
spectrum.
most benign
without
a
discernable
flight
mode. Its inability
less
than the minimum
ASI
for airplanes.
indicate. You
lower end
going on.
with
a
Mach Meter.
ZERO.
Scott
also
goes
part
-mat
Old July 31st 03, 08:31 PM
Robert Ehrlich
the glider.
-mat
claims.
Marske Flying Wings
A zero speed indication is not surprising in these conditions, and doesn't
mean the speed (or even its horizontal component) is zero, but rather that
the pitot tube used by the ASI for total pressure is no more at the stagnation
point in these conditions and so you don't get the true total pressure. I guess
that the pitot is in the nose and when near stall angle the stagnation point
is well below, with a nice round nose like on the Pioneer IId, the pitot may even
be at a point where the airflow is accelerated at a speed higher than the freestream
speed, so the pressure is lower than the static pressure and the ASI should show
a negative speed if it could. Isn't that the reason for what modern gliders with
a nose pitot have a sharp nose (ASW20, Pegases) and many other ones have a pitot
in the fin?
Old July 31st 03, 08:49 PM
spektr
"BD5ER" wrote in message
Doesn't this kind of depend on your definition of flight? The Kaspar wing
can
enter and recover from a controlled vertical decent. In this case the
forward
airspeed is zero but you are still in the air and in control.......and if
that
air is rising fast enough....
There is no such thing as "forward airspeed". Just Airspeed.
The speed of the air over the wing is completely independent
of ground reference points. If you want to use a ground
reference, use GROUND SPEED. Airspeed and Groundspeed
are easily confused when you try to describe things so don't take it so
hard. To use your illustration, push the nose down 100 degrees from
vertical, you are now slightly inverted and traveling backwards
over the ground. Do you now have NEGATIVE AIRSPEED?
Don't think so.............
Scott
Old July 31st 03, 09:02 PM
spektr
I guess it depends on your definition of a stall. Most stalls end with a
marked nose down attitude but not so with the Marske Pioneer, just a
little
forward stick and you have it flying again without any nose down attitude
while it gets up to flying speed..
-mat
Mat.
What you are describing is the high sink rate/high
drag attitude before a stall break occurs.
You are saying that the recovery requires forward stick
to exit the high sink mode of flight. Fair enough.
What that indicates is a lack of elevator authority.
You are unable to put enough pitch command into
the airframe to stall it. Your premise that most stalls
end with a marked nose down attitude is probably
acceptable for straight line flight, not circling or in
attitudes with more than 1g on the airplane. Roll 45
degrees pull hard, bleed energy and you can generate a snap
roll spin entry.
Scott.
Old July 31st 03, 09:13 PM
Bill Daniels
"Bob Kuykendall" wrote in message
Bob K.
Again, not quite. Mat is describing an incipient stall, not a full stall.
The PII is under-elevatored with respect to stalling the aircraft but not
with respect to achieving CLmax. The Marske PII elevator authority
limitation is directly related to the incipient stalling of the wing. At
airspeeds above stall, the elevator authority is as large or larger than
conventional gliders. But as the incipient stall begins, the elevator
authority is sharply limited. (Another way to say this is that there is a
large non-linearity in elevator authority that sharply reduces elevator
effectiveness as the incipient stall begins.) This is not a linear function
of AOA or airspeed. As far as I know, this behavior is unique to plank-type
flying wings - particularly those with the elevators on the inboard trailing
edge of the wing such as the Marske planform.
On the other hand, with a conventional tailed aircraft, there is no link
between the elevator authority and the stalling behavior of the wing. In
the case of a conventional glider with a horizontal tail located some
distance aft of the wing, the wing may be fully stalled or fully flying, or
anywhere in between, with no effect on the elevator authority. Depending on
the elevator area, up angle limit, airspeed and CG location, the elevator
may be able to bring the wing to stall or beyond without the wing stall
imposing any limits on the up elevator authority at all. The designer may
choose to impose limits on up elevator authority to achieve benign stalling
behavior - this is not the case with the Marske planform.
As to Mat's report of near zero airspeeds, there are certainly large ASI
errors involved and the true airspeed is almost certainly not zero. To get
a true reading, Mat would need a nose boom with a gimballing pitot/static
probe and a sensitive calibrated ASI.
However, there are many reports of special conditions where a spanwise
vortex forms above the wing at high AOA preserving a large amount of lift.
One prototype of the Velocity canard pusher encountered this phenomenon with
the forward wing which resulted in the aircraft settling in a flat attitude
at low sink rates. The aircraft was not recoverable from this condition and
the test pilot elected to ride it into Tampa Bay at 200FPM sink and lived
to tell the tale. The Kasper Wing apparently can do this as well but is
recoverable.
It would be interesting to see a video of yarn tufts on the upper wing
surface to help visualize the flow with near-zero indicated airspeed.
Bill Daniels
Old July 31st 03, 10:07 PM
Kirk Stant
Must be that antigravity effect that flying wings are famous for...or
maybe you had an inadvertent deployment of a recovery parachute.
Seriously, Matt, what you probably saw is the same thing most gliders
do when put into a severe slip - the pitot gets masked or moves into
turbulent airflow and no longer indicates your actual airspeed. Ditto
with the rate of sink, perhaps (static port location?). Where is your
pitot located?
Do you have a GPS logger trace of this event? That should show what
your actual groundspeed (and sink rate, with the right software) was.
Repeat the exercise upwind and downwind, then tell us what really
happened.
Meanwhile, enjoy your wing!
Kirk
Happy with the nice, long, beautiful tail of my LS6
Old July 31st 03, 10:23 PM
Marske Flying Wings
We have a pitot tube.. 1/4 " slightly protruding out from the front of the
nose inside a 2 " vent tube in the normal nose location. As I said before, I
will check my GPS ground speed on the next attempt.
I fly all kinds of gliders so I do know a slip well... but this is no slip.
Watch for that video!
I started at 40 mph and slowly went from 35 to 30 to 25 then 20 and then
zero. The video will show all of this on the instrument panel.....and I did
this more than once. I doubt that I actually got to zero..... but the
forward speed was definitely down about 20 or lower. I have boom mounted
turbine and will attach that on one of next flights.
-mat
"Kirk Stant" wrote in message
om...
and
pitot located?
happened.
Kirk
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") Roberto Waltman Home Built 2 October 29th 04 05:21 PM
Charging for Wings safety seminar? Marty Shapiro Piloting 19 June 23rd 04 06:28 PM
Stolen "Champ" wings located...from 23,000 feet!! Tom Pappano Piloting 17 December 15th 03 02:24 PM
Stall resistant 172? Roger Long Piloting 19 October 19th 03 12:48 AM
