DUO DISCUS GROUNDED AS OF 31 JULY 2003
Old July 31st 03, 11:37 PM
Eric van Geetsum
Default DUO DISCUS GROUNDED AS OF 31 JULY 2003
WTH IMEDIATE EFFECTIVENESS THE GERMAN AUTHORITIES HAVE SUSPENDED THE
AIRWORTHINESS OF THE DUO DISCUS (T)
ALL DUO'S ARE GROUNDED DUE TO A WING FAILURE IN FLIGHT (BOTH PILOTS BAILED
OUT AND LANDED SAFELY WITH THERE CHUTE.)
MORE DETAILS
LOOK AT:
www.lba.de/dokumente/ad/lta-dt/2003-245-d.pdf
www.lba.de/dokumente/ad/lta-dt/2003-246-d.pdf
Eric
Old August 1st 03, 12:06 AM
Bob Kuykendall
English-language version he
http://www.lba.de/dokumente/ad/2003-246-e.pdf
Bob K.
Old August 1st 03, 08:17 AM
Marc Till
see also :
http://www.lba.de/dokumente/ad/2003-245-e.pdf (for the Turbo version)
Marc
Bob K.
Old August 1st 03, 08:22 AM
Bernd Dorien
Eric van Geetsum writes:
MORE DETAILS
LOOK AT:
Hi Eric,
thank god the pilots are safe!
Do you know anything more about how the accident happened?
Are there any 'official' sources, e.g. like www.bfu-web.de
where an analysis of such accidents is done?
Failure of the wings sounds a bit like they went 'very' fast
before the glider broke?
Safe landings!
Bernd
Old August 1st 03, 08:50 AM
Bruce Greeff
Report by LBS states "manouevering speed" - ergo a lot below Vne...
There was no reference to unusual attitudes, turbulence or any other
factor. The LBA report implies that the wing failed while being flown in
the certified flight envelope.
One assumes they would not ground the fleet on grounds of not being
airworthy unless they were fairly sure there was some structural fault.
Question is whether it was a singular fault, damage to the specific
aircraft, or generic to the design.
Old August 1st 03, 09:10 AM
Bernd Dorien
MORE DETAILS
LOOK AT:
Hi Eric,
Safe landings!
Bernd
PS: The only I could find so far (source: DAeC):
25.07, 16.30
Schempp
Duo Discus
Thermiksegelflug
Primärbruch des linken Tragflügels im Flug /
Beide Insassen konnten sich mit dem Fallschirm retten.
Old August 1st 03, 11:02 AM
Robert van de Sandt
Hi,
ich vermute mal, dass es dieser Unfall war.
http://de.news.yahoo.com/030725/27/3k388.html
mfg,
Robert
http://www.ballonfahrten-niederrhein.de
"Bernd Dorien" schrieb im Newsbeitrag
BAILED
MORE DETAILS
LOOK AT:
Hi Eric,
Safe landings!
Bernd
Old August 1st 03, 12:36 PM
John Galloway
Southern Sailplanes, the UK agents, have been told
that the wing failed about 4 metres from the tip.
The glider was still flying (presumably not very well)
and so the pilots were able to get out successfully.
Apart from the fact that all the Duos with the relevant
serial numbers are grounded they have no information
as to what action needs to be taken by owners until
an Airworthiness Directive appears.
John Galloway
SUSPENDED THE
(BOTH PILOTS BAILED
MORE DETAILS
LOOK AT:
Eric
Old August 1st 03, 04:33 PM
Basil Fairston
Nothing too serious. Just cut a few dozen holes in each wing, do a
borescope inspection and if you are lucky, repair the holes. Should be back
in action by the end of the season. Ours is booked in for Monday.
http://www.schempp-hirth.com/en/index.html gives details
"Marc Till" ] wrote in message
see also :
Marc
Bob K.
Old August 1st 03, 04:41 PM
Michael I Green
The AD & Technical note are available. Check
http://www.schempp-hirth.com/en/serv...gen/index.html
Mike Green
John Galloway
SUSPENDED THE
(BOTH PILOTS BAILED
MORE DETAILS
LOOK AT:
Eric
_____
mighty gorilla
Duo Discus N175DD
PW-5 N80MG
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
Air Force Print News for July 30, 2003 Otis Willie Military Aviation 0 July 31st 03 10:35 PM
Air Force Print News for July 9, 2003 Otis Willie Military Aviation 0 July 10th 03 02:41 AM
NavNews for Tuesday, July 08, 2003 Otis Willie Military Aviation 0 July 10th 03 02:39 AM
Business Aircraft & Jet Preview - July 10, 2003 - Van Nuys Airport (VNY) Mergatroide General Aviation 0 July 2nd 03 05:36 PM
