#11
Some semi-random notes and observations on this topic from someone who
has messed about some with composite tooling: * The C-150 is a pretty poor basis for such a project. If you do get to the end of it, you'll have - a copy of a Cessna 150. If you're going to go to the trouble, you might as well make something special or at least different. If what you want is a 150, just take the cash and go buy one. It will cost about half or a quarter of what it would cost to replicate it in composites. * Some pretty smart people designed the Cessna 150 for low-cost, high-volume manufacturing in light sheet metal. If they had started with the idea of a composite airplane, they would have been at liberty (as you are now) to accommodate more compound curves and many other improvements for lower drag and better performance of one kind or another. * Making a mold off of any riveted aluminum structure can be a heinous, hateful experience. The seams and universal-head rivets won't want to separate, and when they do you've got a mold with a bunch of dimples and seams. So you end up spending hours and days refinishing the molds. * A while back, a couple guys made molds off of a BD-5 fuselage, and then made carbon fiber shells from the molds. It was a neat project, but I don't think any airplanes came from it, and last I heard of it I think the whole project was for sale. * The trouble it would take to smooth out a 150 fuselage enough to get a nice mold off of it would probably be better invested in making a new fuselage plug from scratch using plywood, lath, foam, and bondo. * If you want to save some trouble, buy transparencies (windshield, canopy, etc) for some other aircraft and incorporate them into your plug. That way you know the plastic parts will be available and relatively inexpensive, and it will save you the trouble of making transparency tooling and having custom transparencies made. * In the history of general aviation, there have been several instances of someone using someone else's fuselage or wing or cowling or whatever without permission as a direct pattern for their molds. I don't know of any of them that became legal intellectual property issues. However, it has almost always ended in tears for the plagiarist. That history alone makes me believe no little bit in karma. * You have to show the FAA very little if anything in the way of substantive data about the thing you've built. About all you have to do is convince them that the major portion of the thing was made for education and recreation, and that its operating limitations are clearly marked. Ron W. can tell you a lot more about that than I can. Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 |
On Mon, 20 Sep 2004 16:14:20 -0700, "NW_PILOT"
wrote: Hello, everyone a friend of mine own's Fiberglass and Carbon Fiber molding business (He makes hoods, doors, fenders & tubs for cars). I was wondering if anyone has ever used a Cessna 150, 172 or 182 fuselage as a template for the making of a Carbon Fiber fuselage? I have few questions! Since it will not be a kit what kind of info would have to be provided to the FAA to be able to get such a thing approved for a homebuilt experimental aircraft project? Only enough to satisfy the 51%, or local examiner. We had a Lake at HTL that used a Corvette engine. He had to change enough of the structure that the FAA was happy. It sat up there for years, but disappeared a couple years back. He did fly it, but I don't think it met his expectations. The point being, if you make enough changes it can become a home built even though it started out as a certified airplane. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Thanks In Advance |
carbon fiber | dutchpilot | Home Built | 0 | June 16th 04 12:20 PM |
Foil Antenna on Carbon Fiber | Dennis Mountains | Home Built | 7 | April 24th 04 12:54 AM |
Realistic Strengths of Homebuilt Carbon Fiber? | BllFs6 | Home Built | 5 | March 31st 04 05:23 PM |
Carbon fiber vs. antennas | Jim Weir | Home Built | 8 | January 2nd 04 01:40 PM |
Foil antenna and carbon fiber | BD5ER | Home Built | 11 | August 6th 03 04:44 AM |
