Hello,
I'm just now learning about Gliding and will start instruction soon. Question: I'm 6ft tall and weigh 232 lbs. Have I weighed myself out of many sailplane options? I DO plan on losing some more weight, but just in case I don't, would appreciate some knowledge on this Theinstructor said I'm ok for the trainer I'll be flying in. Thanks in advance john |
John,
The 2-33 for example has a max weight limit of 1040. Approximately 640lb of that is Iron so that leaves you 400lbs to split between the two of you. You have to see the WB for the actual ship you will be flying, ships that have had work and paint jobs add up weight. It really boils down to specific weight and balance figures for each sailplane. If you plan on taking lessons in a 2-33, and you say you are 232lbs clothed..extra radios, gps,water bottle.....your instructor can weigh no more than an honest 168lbs. All that being said, I've seen more than one pair go up that combined couldn't possibly weigh 400lbs or less! Some gliders will be a better fit than others.. you'll have to find out whats comfortable for you. Good luck! Douglas |
JohnH wrote in message . net...
Hello, I'm just now learning about Gliding and will start instruction soon. Question: I'm 6ft tall and weigh 232 lbs. Have I weighed myself out of many sailplane options? I DO plan on losing some more weight, but just in case I don't, would appreciate some knowledge on this Theinstructor said I'm ok for the trainer I'll be flying in. Thanks in advance john If you want to move into high performance single seaters, your options will be somewhat restricted, but you'll manage to find something. Its typical for Euro gliders to come out of the factory with a max cockpit load of 242 lbs (110 kg.), but that often gets reduced when extra equipment is installed. On the other hand, if you are content to fly Schweizer junk your whole life, you've got nothing to worry about. |
"Liam Finley" wrote...
On the other hand, if you are content to fly Schweizer junk your whole life, you've got nothing to worry about. Gee, what a fine way to encourage a newcomer to become involved in this sport. At least he'll find out what he's up against early on... Marc |
options will be somewhat restricted, but you'll manage to find something. Its typical for Euro gliders to come out of the factory with a max cockpit load of 242 lbs (110 kg.), but that often gets reduced when extra equipment is installed. Most high performance gliders have provision to store ballast in the tail. This could increase the minimum cockpit weight. You will have to reduce the water ballast accordingly to stay below gross weight. |
Marc Ramsey wrote:
"Liam Finley" wrote... On the other hand, if you are content to fly Schweizer junk your whole life, you've got nothing to worry about. Gee, what a fine way to encourage a newcomer to become involved in this sport. At least he'll find out what he's up against early on... Marc No, I sure don't want to fly Schweizer junk my whole life. But, I'm not looking to do aerobatics either....and least not on purpose, at this time ![]() Thanks for the replies. Marc, I grew up in newsgroups and really expected some pretty rude comments, but haven't received any yet. I have also received some encouraging and enlightening emails. I apparently am not the only one on this board that has been fighting the pilot weight problem ; john |
most high performance gliders of European manufacture have a max seat load
of 242 lbs (US) or 110Kg, that cannot be adjusted (increased)by extra ballast weight in the tail, regardless of what the W&B computes out to. It is a manufacturing design limit for structural integrity under impact loads. The other consideration other than weight, especially with an aircraft like the 2-32, is the "belly girth", even at 6ft+ and 232#, if you can't get full aft stick movement.. don't fly. Our very lightest CFI turned down a student, the CG worked out ok, but the "fit check" did not. BT "Guy Byars" wrote in message ... If you want to move into high performance single seaters, your options will be somewhat restricted, but you'll manage to find something. Its typical for Euro gliders to come out of the factory with a max cockpit load of 242 lbs (110 kg.), but that often gets reduced when extra equipment is installed. Most high performance gliders have provision to store ballast in the tail. This could increase the minimum cockpit weight. You will have to reduce the water ballast accordingly to stay below gross weight. |
kinda hard to get DUAL primary instruction in a single seat glider
"Bob Kibby" wrote in message news:FYe1b.170667$Oz4.44660@rwcrnsc54... I have a SZD-59 Acro for sale that would satisify your needs. I am 6'5" and weigh 210 lbs. Plenty of room for a big guy. Information on Wings and Wheels web site under used sailplanes. I believe it is on sheet 7 or 8 of Tim's used sailplane listings. Bob Kibby "59A" old SZD-59 and ""2BK" new Discus-2T -- ---------------------------------------------------- This mailbox protected from junk email by Matador from MailFrontier, Inc. http://info.mailfrontier.com "JohnH" wrote in message et... Hello, I'm just now learning about Gliding and will start instruction soon. Question: I'm 6ft tall and weigh 232 lbs. Have I weighed myself out of many sailplane options? I DO plan on losing some more weight, but just in case I don't, would appreciate some knowledge on this Theinstructor said I'm ok for the trainer I'll be flying in. Thanks in advance john |
On the other hand, if you are content to fly Schweizer junk your whole life, you've got nothing to worry about. Unless that was said "tongue-in-cheek", that's just plain ignorant. You don't have to like it, but Schweizer has its place. Not everyone who loves to go places and drive has to do so in a Ferrari to enjoy the trip! --Shirley |
Hello, I'm just now learning about Gliding and will start instruction soon. Question: I'm 6ft tall and weigh 232 lbs. Have I weighed myself out of many sailplane options? I DO plan on losing some more weight, but just in case I don't, would appreciate some knowledge on this Theinstructor said I'm ok for the trainer I'll be flying in. Thanks in advance john Schleicher makes gliders that will take your frame. BTW, the Adkins diet worked for me, dropped about 30 lbs. |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 08:35 PM |
| Angle of climb at Vx and glide angle when "overweight": five questions | Koopas Ly | Piloting | 16 | November 29th 03 11:01 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
| Where are the CFIG's? | Michael | Soaring | 10 | August 19th 03 01:23 AM |
