#21
Ups, make that;
Hundreds of feet per minute times 0.508 = meters per second. JJ Sinclair |
#24
How do I convert Meters/second to Leagues per Hour? I need the answer
to five significant digits. I also need to convert wing loadings from Kg/square meter to tons/acre. Can I do the conversion in Winpilot? |
#25
You seem like a swell person. I have two tickets to the rodeo. Maybe you
would like to have some Chinese food and a couple of brewskis, then we can go to rodeo together. You will really enjoy it. Try to rent some Levi's though. I don't think a starched collar is appropriate. "Gene Nygaard" wrote in message m... "Pete S" wrote in message ... Looks like they made the mistake of assuming that a nautical mile was 6000 feet when it's actually 6080 ft No, it's actually 1852 m in today's world. Your 6080 ft is 1853.184 m, all around the world since an international agreement on the definition of the yard (and thus feet, inches, etc.) over 40 years ago. Gene Nygaard http://ourworld.compuserve.com/homepages/Gene_Nygaard/ |
#26
tons/acre = Cos( furlongs/ weekend)
Jon. "Liam Finley" wrote in message om... How do I convert Meters/second to Leagues per Hour? I need the answer to five significant digits. I also need to convert wing loadings from Kg/square meter to tons/acre. Can I do the conversion in Winpilot? |
#27
Nygaard is a troll. He is *not* a glider person. He gets his jollies
by trying to "show off" his supposedly superior knowledge of units of measure. Ignore him. (Gene Nygaard) wrote in message om... "Pete S" wrote in message ... Looks like they made the mistake of assuming that a nautical mile was 6000 feet when it's actually 6080 ft No, it's actually 1852 m in today's world. Your 6080 ft is 1853.184 m, all around the world since an international agreement on the definition of the yard (and thus feet, inches, etc.) over 40 years ago. Gene Nygaard http://ourworld.compuserve.com/homepages/Gene_Nygaard/ |
#28
Hey Gene, What kind of glider do you fly? Methinks you are a troll
and should leave this newsgroup alone with your misguided "superior" knowledge of weights and measure. This is a newsgroup for soaring. Gene Nygaard wrote in message . .. On Sun, 24 Aug 2003 14:38:07 +0100, "W.J. \(Bill\) Dean \(U.K.\)." wrote: On the Equator. Wrong. There have been some geographical miles based on the equatorial circumference, but I've never seen them called nautical miles. There was one geographical mile equal to 4 minutes of arc on the equator, or about 7.421 km; I have a copy of a map using these units. Nautical miles have normally been defined to be some midrange, midlatitude value for a minute of arc as you travel north-south along a meridian. At the equator, 1 minute of longitude is 1.001795 nmi. But 1 minute of latitude (geodetic latitude, the kind normally used) at the Equator is only about 0.9950 nmi. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "JJ Sinclair" wrote in message ... Navigational question for the day; One minute of latitude = 1 nautical mile. At what point on the earth does 1 minute of longitude = 1 nautical mile? JJ Sinclair. It is at some place close to the equator, where the circumference of the earth at that latitude is 40.0032 Mm, rather than the 40.007495 Mm at the Equator (WGS-84 ellipsoid). A latitude close to the arccosine of 40.0032/40.007495, or about 3½ degrees from the Equator either north or south (a more exact value depends on which type of latitude you use, as well as which ellipsoid you use to approximate this). To help see this better, your "minute of longitude" at a latitude of 60 degrees would be about 0.50 nmi, and at the poles a "minute of longitude" is 0 nmi. It is actually the minute of latitude as you travel along a meridian (constant longitude) that most people consider in evaluating the fit of a nautical mile to the Earth. Now, at what point is one centigrade of latitude equal to one kilometer? Gene Nygaard http://ourworld.compuserve.com/homepages/Gene_Nygaard/ |
#29
My vario is calibrated in megaparsecs per millenium. Very
handy. |
#30
Troll = Ugly devil liviin' under a bridge, (see also motorcycle cops with
radar guns (usually under a bridge)). Trolls = More than one ugly devil (also found in newsgroups) Trolling = Fishin' with fake bait from a slow boat. Cheers! |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Hiroshima/Nagasaki vs conventional B-17 bombing | zxcv | Military Aviation | 55 | April 4th 04 07:05 AM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
got this from a friend | JD | Naval Aviation | 7 | August 31st 03 03:21 AM |
