Feet Per Minute Conversion Question
Old August 25th 03, 02:54 PM
JJ Sinclair
Ups, make that;
Hundreds of feet per minute times 0.508 = meters per second.
JJ Sinclair
Old August 26th 03, 12:12 AM
Liam Finley
How do I convert Meters/second to Leagues per Hour? I need the answer
to five significant digits.
I also need to convert wing loadings from Kg/square meter to
tons/acre.
Can I do the conversion in Winpilot?
Old August 26th 03, 02:33 AM
John Shelton
You seem like a swell person. I have two tickets to the rodeo. Maybe you
would like to have some Chinese food and a couple of brewskis, then we can
go to rodeo together. You will really enjoy it. Try to rent some Levi's
though. I don't think a starched collar is appropriate.
"Gene Nygaard" wrote in message
m...
"Pete S" wrote in message
Looks like they made the mistake of assuming that a nautical mile was
6000
feet when it's actually 6080 ft
No, it's actually 1852 m in today's world. Your 6080 ft is 1853.184
m, all around the world since an international agreement on the
definition of the yard (and thus feet, inches, etc.) over 40 years
ago.
Gene Nygaard
http://ourworld.compuserve.com/homepages/Gene_Nygaard/
Old August 26th 03, 09:36 AM
Jonathan Gogan
tons/acre = Cos( furlongs/ weekend)
Jon.
"Liam Finley" wrote in message
om...
tons/acre.
  #28
Old August 26th 03, 10:33 AM
Doug Hoffman
Hey Gene, What kind of glider do you fly? Methinks you are a troll
and should leave this newsgroup alone with your misguided "superior"
knowledge of weights and measure. This is a newsgroup for soaring.
Gene Nygaard wrote in message . ..
On Sun, 24 Aug 2003 14:38:07 +0100, "W.J. \(Bill\) Dean \(U.K.\)."
On the Equator.
Wrong.
There have been some geographical miles based on the equatorial
circumference, but I've never seen them called nautical miles. There
was one geographical mile equal to 4 minutes of arc on the equator, or
about 7.421 km; I have a copy of a map using these units.
Nautical miles have normally been defined to be some midrange,
midlatitude value for a minute of arc as you travel north-south along
a meridian.
At the equator, 1 minute of longitude is 1.001795 nmi.
But 1 minute of latitude (geodetic latitude, the kind normally used)
at the Equator is only about 0.9950 nmi.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"JJ Sinclair" wrote in message
Navigational question for the day;
One minute of latitude = 1 nautical mile.
At what point on the earth does 1 minute of longitude = 1 nautical mile?
JJ Sinclair.
It is at some place close to the equator, where the circumference of
the earth at that latitude is 40.0032 Mm, rather than the 40.007495 Mm
at the Equator (WGS-84 ellipsoid). A latitude close to the arccosine
of 40.0032/40.007495, or about 3½ degrees from the Equator either
north or south (a more exact value depends on which type of latitude
you use, as well as which ellipsoid you use to approximate this).
To help see this better, your "minute of longitude" at a latitude of
60 degrees would be about 0.50 nmi, and at the poles a
"minute of longitude" is 0 nmi. It is actually the minute of latitude
as you travel along a meridian (constant longitude) that most people
consider in evaluating the fit of a nautical mile to the Earth.
Now, at what point is one centigrade of latitude equal to one
kilometer?
Gene Nygaard
  #29
Old August 26th 03, 05:57 PM
Pat Russell
My vario is calibrated in megaparsecs per millenium. Very
handy.
  #30
Old August 26th 03, 09:24 PM
George William Peter Reinhart
Troll = Ugly devil liviin' under a bridge, (see also motorcycle cops with
radar guns (usually under a bridge)).
Trolls = More than one ugly devil (also found in newsgroups)
Trolling = Fishin' with fake bait from a slow boat.
Cheers!
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Hiroshima/Nagasaki vs conventional B-17 bombing zxcv Military Aviation 55 April 4th 04 07:05 AM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
got this from a friend JD Naval Aviation 7 August 31st 03 03:21 AM
