My RHJ -8 uses HP 14 wings; I have only a rough idea of the root and tip
weights, needed for trailer design. Would some obliging owner supply known values. Thanks John firth |
But John, they really are not HP-14 wings !
Give me a couple of days and I'll try climb in the trailer with a scale... Best Regards, Dave (owner of a very dusty RHJ-8) "John Firth" wrote in message ... My RHJ -8 uses HP 14 wings; I have only a rough idea of the root and tip weights, needed for trailer design. Would some obliging owner supply known values. Thanks John firth |
John - We dragged out the trailer and weighed a wing this AM.
Root - 119 lbs (including about 4lb for root dolly) Tip - 62 lbs (no dolly) Mine has quite a lot of filler on it (feather fill is in fact heavier than feathers)... Hope this helps, Best Regards, Dave PS: Want to copy my trailer ? Doubles as a home-away-from-home if need be. I built it back in '79, perhaps you saw it lsat time you were here ? "John Firth" wrote in message ... My RHJ -8 uses HP 14 wings; I have only a rough idea of the root and tip weights, needed for trailer design. Would some obliging owner supply known values. Thanks John firth |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
F35 cost goes up. | Pat Carpenter | Military Aviation | 116 | April 11th 04 07:32 PM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 02:33 AM |
An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 03:52 AM |
