Drag Chute Deployed ?
Old August 31st 03, 09:31 AM
Ian Forbes
On Fri, 29 Aug 2003 13:14:38 +0000, MikeYankee wrote:
If you have to land in the water, put the landing gear down to keep the
nose from plowing too deeply and too steeply under the water.
Does anybody know if the Ventus pilot in the recent incident (
http://www.ntsb.gov/NTSB/brief.asp?e...15X01341&key=1 ) landed
wheel up or down?
Thanks
Ian
Old September 1st 03, 04:46 PM
F.L. Whiteley
"Ian Forbes" wrote in message
news
wheel up or down?
Thanks
Ian
Heard it was wheel down. From the damage, would appear not to have been
minimum energy. Gross reservoir is 7950MSL though. If downwind
(conventional wisdom), touch down would have been pretty fast.
Frank Whiteley
Old September 2nd 03, 01:59 AM
Shawn Curry
news
wheel up or down?
Thanks
Ian
Frank Whiteley
Wheel down, according to my second hand source (whom I believe was part
of the crew that picked up/fished out the pieces). Also, I was told the
tail touched first, causing the nose to hit hard enough to submerge,
resulting in the flip. Again second hand.
Shawn
Old September 2nd 03, 01:52 PM
Chris
I guess the lesson that we can learn from this is;
If there is nothing but trees below you, then *put it in the
trees*
and don't try to avoid them.
May be a coincidence but we had two crashes this season, both
into the trees and both pilots survived with virtually no injury.
One had a cut on his head from the canopy and the other one just
bruises. The gliders, a Pegase and a DG-300 were totally damaged.
So obviously crashing into trees can give you an *edge* in such a
situation.
Christian
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Lower Drag: Rounded or Sharp? Jay Home Built 9 May 10th 04 10:30 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
Forward CG Experience Jay Honeck Piloting 41 November 19th 03 02:54 PM
