Inflatable Rotors (Flying Car?)
Old August 1st 03, 03:42 AM
Ernest Christley
sanman wrote:
Well, polymers and reinforcement fiber technology are continuing to
improve. You can even buy carbon-fiber reinforced polymers these days,
with superduper tensile strength. But I would imagine that kevlar,
spectra, vectran would have enough strength to do the job for a small
personal transportation vehicle. They would be able to handle the high
pressures.
To ease the load requirements, the rotor could be 4-vaned. Each pair
of opposing vanes could have a commonly inflated structure -- that way
if a single vane suffered a rupture, then it and its opposing partner
could be deflated/depressurized, while the remaining pair of rotor
vanes would take the load while you landed. Or why not even a 6-way
rotor?
Someone who responded to my posting suggested weighting the rotor tips
for flywheel effect. The centrifugal force from the weighted tips
would help to keep the rotors rigid and reduce the possibility of
buckling. Flywheel energy could also help in the event of an unpowered
landing due to engine failure.
Another idea to strengthen the rotor. Make it like one of those flat,
roll-up water hoses. 3 or 4 narrow tubes running parallel. It will be
stonger since you have to crimp the 'side wall' to get it to 'break'.
If each tube section is pressurized seperately, it give redunancy in the
design.
Here's another possibility...Pressurize with helium, and you might end
up with an ultralight that has a negative empty weight!! OK, maybe that
one is a long shot.
----Because I can----
http://www.ernest.isa-geek.org/
Old August 1st 03, 05:20 AM
Dan & Jan Hollenbaugh
I don't recall inflatable wings, but both telescoping and "ribbon" blades
have been tried. IIRC, the cloth rotor had a wire "spar" with a tip weight,
and a cloth single panel sail-like "blade". Also IIRC, the idea was to use
it in autorotation mode, as a deceleration device in place of a parachute.
Rigid telescoping blades have also been tried experimentally. The variable
diameter allowed for two flight regimes - high speed (with outer portion
retracted) and low speed (outer portion extended, more lift for hover
profiles).
I've got some info on my work computer, I'll try to post it later.
Dan Hollenbaugh
AnyBody43 wrote in message
Mark Hickey wrote in message
(sanman) wrote:
I was reading about inflatable wings:
snip
So you'd be riding a sort of lightweight automotive vehicle along the
road, and you could switch to helicopter mode, with inflatable rotors
popping out on the top of your vehicle. Your engine would then power
the rotors, and you'd fly away. Once you landed again, the deflated
rotors would be tucked back into whatever compartment they'd popped
out from.
Cmon, there are all kinds of wierd-looking lightweight concept cars
out there, so why not this? What would be the main difficulties with a
concept like this?
Given that centrifugal force keeps the rotors from folding upwards
anyway it seems a relatively small change in the principles of operation
to have such a mechanism.
If inflatible was no good how about folding/telescopic . . .
or just ribbon/strip with a weight on the end.
## Miniature emergency parachute hat ##
Since the "wing" area of a helicopter is much less than that of
a parachute, and that a helicopter CAN land softly without an engine
why not have a small device that:-
Is an auto gyro that infates out of a bag
Uses gas jets to accelerate the blades to operating speed
lowering the wearer safely to the ground.
Would be smaller and lighter than a conventional parachute?
Maybe a pyrotechic charge could be used as a gas source?
Perhaps a small hand grenade would be enough to get it going
Old August 5th 03, 11:04 AM
Christopher
There was a design for an inflatable car years ago it was quit good.
"Ken Sandyeggo" wrote in message
om...
(sanman) wrote in message
. com...
http://www.spacedaily.com/news/plane...-wing-01a.html
http://www.ilcdover.com/EngineeredInfl/inflatwing.pdf
and I wondered why these couldn't be implemented as rotor
configuration, for a
"flying car" type of vehicle -- ie. a car that could instantly convert
to helicopter flight.
If you look back at those older Hiller helicopters, they had big,
thick, rigid aluminum rotors:
http://avia.russian.ee/vertigo/hiller_x-2-235-r.html
http://avia.russian.ee/vertigo/hiller_xh-44-r.html
An inflatable equivalent might be somewhat thicker and yet not be so
rigid, and would not have the high mass penalty.
out from.
concept like this?
Getting anyone to stop laughing long enough to think about it. Are
you related to Moller?
KJSDCAUSA
Old August 6th 03, 06:37 AM
Ken Sandyeggo
"Christopher" wrote in message ...
If it was only "moderately good," the way we buy junk, it'd be on the
market. "Quite good" would make it an overwhelming success. If it's
not on the market at all, it was "quite" junk. Maybe had a couple
good features, but not enough that people would buy it, or we'd see
them all over the place.
KJSDCAUSA
om...
. com...
out from.
concept like this?
KJSDCAUSA
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 March 1st 04 07:27 AM
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons Curtl33 Aerobatics 0 December 12th 03 12:00 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
