Eta crashed
Old October 3rd 03, 12:02 PM
Jona
The loads on spin recovery can be quite unpredictable,
especially if the recovery pull-up is done with some
twisting moment still present on the tail - hence we
are trained to stop the spin, unstall the wings, recover,
not one 'pot-stirring', stress-inducing manoeuvre.
This is an interesting point - I guess lots of pilots employ a mushy
some/loads/a bit of rudder (very slightly ahead of ) stick-forward.
Quickly followed by pull back.
We do this because it works and no one has explained exactly WHY
there are mysterious pauses in the official spin recovery.
Jonathan
Old October 3rd 03, 12:19 PM
Stefan
Robert John wrote:
Never assume the glider is stronger than the placarded
limits.
Don't get me wrong: I didn't say because there's a safety cushion of 50%
you should go for it. Don't! I said theres a safety cushion of *only* 50%
to catch the unpredictable. Besides, as you pointed out, the placarded
load limits are for "straight" load only. Add some twisting forces, and bang!
Stefan
Old October 3rd 03, 01:58 PM
Brian Case
snip
.. JAR further requires that the break load be no lower
than 1.5 times the allowed load.
Yes, 1.5 times is the ulimiate design factor for the aircraft. However
1.0 times the allowed load is the limit facter. If you exceed the
limit factor you may (will?) damage the aircraft structure but it will
not fail until 1.5 times the limit. This is especially true of metal
structures where the material itself will fail (i.e. Break) at about
1.5 times the yeild strength(i.e. bend permanently).
Brian Case
CFIIG/ASEL
snip
Old October 3rd 03, 02:48 PM
W.J. \(Bill\) Dean \(U.K.\).
I have always understood that the first composite gliders were well
over-engineered, because the manufacturers were dealing with a new
technology and did not want any risk of failure. I have not heard of any
problems with old glass gliders due simply to age or high hours.
As designers and manufacturers have gained experience I imagine they have
been able to design and build to the limits rather than way past them, so
gaining performance and reducing cost. There are a number of cases where
older designs have had the limitations increased without any modification to
the airframe.
Perhaps one problem we now have is stall/spin recovery. The usual cause of
disaster from a stall/spin is hitting something (usually the ground) before
recovering to normal flight.
There is another problem, flying outside limits while recovering to normal
flight. This can happen with any type if the recovery is handled badly, I
have known of cases involving a Ka6E and more than one K13.
Modern types of glider are easy to fly, and normally reluctant to depart
into
an inadvertent stall/spin (and often difficult to make spin deliberately).
However, many of them can depart violently into a steep spin, and recovery
has to be immediate and correct or Vne will be exceeded. This is most
likely to happen when ballasted and thermalling hard in strong lift.
I know of three fatal accidents where it appears that the glider went
outside limits while recovering from what appeared to be an inadvertent
1. ASW20CL at Dunstable (I think more than 10years ago), the glider
reached a speed in the dive which made the dive irrecoverable; the C. of G.
may have been aft of limit.
2. Nimbus 4DM at Minden on 13th July 1999.
http://www.ntsb.gov/publictn/publictn.htm , then
http://www.ntsb.gov/publictn/2002/AAB0206.htm or
http://www.ntsb.gov/publictn/2002/AAB0206.pdf .
From the report it would appear that the glider departed into a stall/spin
while thermalling, and was overstressed in the subsequent dive while
recovering.
The brakes opened during the recovery, which reduced the 'g' limitations;
correspondence to Rec. Aviation Soaring indicates that some pilots have
experienced inadvertent deployment of the brakes on this type of glider.
There was also a suggestion that the pilots may have been incapacitated by a
problem with their oxygen system, thought there was no evidence to back
this.
3. Nimbus 4DM in Spain 1999.
Referred to in the report of the Minden accident above.
Quote: "the pilot stated they were in a turn when a heavy thermal caused the
glider to enter a steep descending spiral. The pilot could not recover the
aircraft from the spiral and the glider quickly exceeded Vne. The pilot
then reported that the right wing failed and he bailed out." The second
pilot was unable to bail out.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"Howard Franks" wrote in message
I have always assumed the recent (last 20 years) composite
gliders to be very robust, i.e. no issues flying right
up against placarded limitations at anytime (maybe
once or twice nipping over?).
Perhaps the Eta break-up is a sign that we are reaching
the structural/design limitations of the current materials
and the designers ability to optimise gliders for performance.
Are we at the point of diminishing returns where the
small increase in performance only comes at a far greater
risk of structural failure (similar to the Americas
Cup yachts).
This coupled with the recent Schempp-Hirth issues (agreed
manufacturing not design defects), and the AD restricting
GROB 103s is leading me to rethink just how tough these
things are.
Old October 3rd 03, 10:01 PM
Mike Borgelt
On Fri, 3 Oct 2003 14:48:55 +0100, "W.J. \(Bill\) Dean \(U.K.\)."
recovering.
this.
To which can be added the in flight breakup of a Blanik L13 at
Narromine NSW in about 1996 or 97 I think it was.
Two dead, instructor and student.
Intentional spin(Annual spin check!) which developed into a spiral and
the glider was overstressed in the recovery, bending the rear fuselage
and preventing recovery from the dive.
Neither pilot was wearing a parachute.
Just my opinion but intentional spinning is something that should be
treated with great caution. Brief the exercise properly, wear
parachutes and be prepared to use them. Best done in something like
Pitts S2 which is likely to hang together rather than a slippery
sailplane.
Mike Borgelt
Old October 4th 03, 08:58 AM
Slingsby
"W.J. \(Bill\) Dean \(U.K.\)." wrote in message ...
the airframe.
Until recently I thought of the Grob 103 as an over-engineered glider,
especially the fuselage and tail. It is quite heavy and I don't have
first hand knowledge of any with broken tail booms. I do know of
several which have been ground-looped without structural damage.
Old October 4th 03, 12:56 PM
Vaughn
"Slingsby" wrote in message
om...
I have heard of, but not seen, G-103's with snapped tail booms.
Locally, over the years, we have had at least two snapped tail booms on
plastic gliders, both from unavoidable groundloops in off-field landings.
It happens.
Vaughn
  #28
Old October 4th 03, 05:46 PM
Pat Russell
Which Eta was it?
  #29
Old October 4th 03, 10:18 PM
Paul Remde
Who owned that one?
"Markus Feyerabend" wrote in message
No. 2 D-KFEM
Regards,
Markus
Pat Russell schrieb in Nachricht ...
Which Eta was it?
  #30
Old October 4th 03, 10:42 PM
Markus Feyerabend
DonŽt know, but from the registration it could be Erwin Mueller...!?
IŽll try to find out tomorrow..
Regards,
Markus
Paul Remde schrieb in Nachricht ...
Who owned that one?
No. 2 D-KFEM
Regards,
Markus
Which Eta was it?
24M of Cocaine in a crashed plane Jim Fisher Piloting 20 January 6th 05 01:43 AM
Experimental plane crashed : FFZ RobsSanta Piloting 1 September 22nd 04 04:10 AM
What REALLY Crashed @ Boscome Down? Kenneth Williams Military Aviation 5 October 29th 03 04:37 PM
Tu-160 just crashed near Saratov Michael Petukhov Military Aviation 23 September 23rd 03 12:19 PM
Airplane that crashed in Lake Ontario yet to be raised James Robinson Piloting 12 July 17th 03 03:45 PM
