Winglets for SZD55
Old October 13th 03, 11:29 PM
Tom and Jane Gilbert
Default Winglets for SZD55
Any 55 owners fitted winglets to their ships? Thoughts... comments??
Tom Gilbert
Old October 14th 03, 06:48 AM
Janusz Kesik
I have never seen any. The wingtip shape disables use of wingtips I =
think, and also there's no need because tapering wingtip also reduces =
induced drag as the wingtip does.
Regards,
--=20
Janusz Kesik
visit
www.leszno.pl - home of the www.css-leszno.it.pl
Old October 14th 03, 11:37 AM
I have seen photos of two different types of winglets installed on the
SZD55. One I thought was a factory approved set (slightly kicked up) and
another set were large swept types (M&H??)
The 55 tends to drop a wing on take off and could use a bit more aileron
response at low speed. The winglets should help.
Tom
"Janusz Kesik" wrote in message
I have never seen any. The wingtip shape disables use of wingtips I think,
and also there's no need because tapering wingtip also reduces induced drag
Regards,
Janusz Kesik
visit
Old October 15th 03, 03:07 AM
SNOOP
My eighteen year old son and I flew our 55 over 120 plus hours since
February, and yes occasionally the wing drops. I've watched the
current U.S. 15 Meter Champ (also a former SZD55 owner) in his Discus
A, drop a wing in the dirt one day at our home field. David just
popped out the spoilers, picked it up and off he went. Same thing in
the 55. No big deal.
It's a non- event. The 55 is a great ship, with a beautiful wing that
doesn't need winglets. There is a paper written by,I beleive it was
Peter Masak,here on Google, about the SZD55's construction, and it's
wing. I'll try to find it. In short, Peter said nothing but great
things about the weight and construction of this fine glider.
The dealer for the 55 is Windpath Corp. outside of Toronto, Canada.
They are doing a great job of supporting this ship. Look for them on
the internet!
Old October 15th 03, 03:12 AM
SNOOP
"Tom and Jane Gilbert" wrote in message ...
Tom
I found it. Just go to the Google search and type in Peter Masak
SZD55, and you'll have his comments. Cheers!
Regards,
Old October 16th 03, 09:21 AM
Nick Gilbert
Wing dropping can be a problem with part-water on board. If the wing is down
for long enough the water sloshes to the tip and the wing NEVER comes back
up!
Nobody is questioning the performance or the construction of the glider. It
does have a wing dropping problem that could possibly be rectified with
winglets.
Regards,
Nick.
"SNOOP" wrote in message
om...
the internet!
Old October 16th 03, 10:48 PM
SNOOP
"Nick Gilbert" wrote in message ...
up!
No arguement on that point, but we have not seen it in the 55.
Various water loadings, which, actually seem to help stop the drop,
have been used. When it has dropped, it has typically popped back up
as fast as it went down, if it did drop at all. I would offer that
using the forward (chin) tost hook versus the c.g. hook helps to
alleviate the inevitable ground loop that happens to ships with c.g.
hooks when the wing goes down. Plus the 55 has quite a powerful rudder
which helps keep you tracking straight.
winglets.
Going back to my first note, the Discus whose tip hit the grass has
the biggest rabbit ears out on the tips. Didn't help. I just would
hate to see someone spend good money, and cut up that nice taperwing,
to accomplish probably nothing much. Doing a good briefing with the
wing runner, and being familiar with the ship would be whole lot less
expensive. Thanks for your thoughts.
om...
the internet!
Old February 8th 16, 05:49 PM posted to rec.aviation.soaring
Tom Gilbert
This is a very old thread, but I recently purchased an SZD-55 with winglets. I have been searching for others, but so far think I may be the only one.
-JJ
Old February 8th 16, 07:02 PM posted to rec.aviation.soaring
AS
Tom Gilbert
-JJ
There was a '55 on our field in Spartanburg, SC that had winglets. My son was a part owner and loved the way it flew. The group dissolved and the ship was sold to TN. Is yours '9U'
Uli
AS
Wingtip Vortex: Heavy, Clean, Slow - Why? Eric Nospam Piloting 23 January 21st 05 04:09 AM
Wanted: Ventus C Winglets E.Mertins Soaring 1 October 14th 03 02:15 PM
