There is a technical note dated 9/23/2003 (LBA) regarding fixing of
mass balance weights to the elevator of the following models and SNs: V2: 1, 2, 31, 32, 48, 54, 71, 117, 124-151, 153 D2: 1-185, 187-189 D2T: 1-33 See the S-H website for details. http://www.schempp-hirth.com/en/index.html Summary: A Discus 2T was observed to have elevator friction during pre-flight inspection. Removal of elevator revealed a lead weight had detached from elevator. TN requires drilling of inspection holes prior to next flight. If lead weights are observed to be loose, repair must be made immediately and entered in log. Otherwise, the repair of fixed weights must be completed prior to next Annual Inspection or 12/31/2003. I have asked for fixed price quotes for this work from Ridge Soaring and M&H. I'll share them with the group as soon as they come in. OC |
Be advised that you DO NOT HAVE TO DRILL HOLES IN THE HORIZ. STAB!! to
comply with the technical note (and German AD). I emailed Tom Knauff (who forwarded my email to Schempp-Hirth) and noted to them that you can much better inspect the weights by taking the elevator halfs off (remove 6 bolts total). You then can closely inspect them instead of drilling the 1/4" holes and trying to do it through the hole. Plus, you don't have two holes to repair! Schempp-Hirth explained that you could drill the holes so you could do the inspection and then keep flying if all was OK and then comply with the balance of the tech. note by Dec 31st. The balance of the note REQUIRES the removal of the halves, so you might as well do it to begin with and save the holes. As info, my Discus 2 had one weight that was loose, being held in only by the roll pins. There was no bond at the weight to epoxy interface, so it is an inspection worth doing. I do not believe that mine would have been seen through a hole. It was only after wiggling it that I noticed a very slight movement. -Deputy Dog (3J - Discus 2B) TN requires drilling of inspection holes |
TN requires drilling of inspection holes in tail
prior to next flight. Also drill holes in Discus and Duo Discus wings.... I guess next season we'll see if swiss cheeze can fly... Sounds like lots of holes in lots of gliders, maybe they they should build them of clear resin. |
[LBA] Schempp-Hirth - Discus bT - Discus | Frederic FUCHS | Soaring | 0 | September 17th 03 08:42 AM |
All Czech built Discus grounded | Paul | Soaring | 0 | September 14th 03 02:22 AM |
18m Discus | Burt Compton | Soaring | 2 | September 8th 03 10:52 AM |
Discus Wing question | John Galloway | Soaring | 6 | August 23rd 03 07:52 AM |
Duo Discus Tech note | Thomas Knauff | Soaring | 25 | August 9th 03 10:10 PM |
