#121
On Sun, 2 Nov 2003 00:05:21 -0000, "W.J. \(Bill\) Dean \(U.K.\)."
wrote: There have been many accidents of the types described, insufficient energy to avoid a heavy landing after a launch failure, and a spin entry after stalling during the first part of the launch. See this example: http://www.alexburger.de/sf/seilriss.avi Pilot suffered only minor injury. Bye Andreas |
#122
Marty, I'm going to top post here since I can't figure out which way this
thread is expanding. In the first case, the weak link at the tug failed because the tugee modified it without our knowledge or approval. In the second case the rope itself was the weak link and it most likely failed because it was left laying on the ground in the path of a landing 2-33 which cut some of the strands with its razor sharp metal skid. I know that in the first case, the glider was in perfect position - the link just fell apart. In the second, the student was flying but was not badly out of position. In both cases the failure was a complete surprise to the CFI-G. These incidents happened at different airports under different conditions and operating procedures but to the same CFI-G in the same month. One could argue, as I did, that the CFI-G shared responsibility with the tug pilot to check the integrity of the rope and weak links . As we know, this is hard to do for each flight at a busy operation and we rely on the operating procedures and ground personnel to insure the rope is usable. Sometimes your luck just runs out. My original point was that with airtow stuff happens and sometimes you aren't in position for a return to the runway. In winch launching, you are. Bill Daniels "Martin Eiler" wrote in message ... Should we assume that these two rope breaks were during aero tow? The next obvious question is how strong were the weak links and why did they break. The fact that this individual had two weak links break at a low enough altitude that it resulted in his landing off field, does make us wonder what the complete story is. Was he solo in a single place glider? Or was it a result of letting a student get too far out of position? Inquiring minds would like to know. M Eiler More specifics please for those off-airport landings. Otherwise your "1000 feet" may be taken by some as a bit of an exageration. Jack In my friends case, the first break came shortly after crossing the field boundary at about 50 feet. This was a case of insufficient climb angle to reach 200 feet while still in range of the runway. The other, as I understand it, was at about 300 feet but still out of gliding range of the airport. My comment about 1000 feet referred to a situation that happened to me because the tug pilot turned downwind at 100 feet AGL with a heavy glider and strayed still further downwind as the air tow ground on despite urgent radio calls. It was only at 1000 feet AGL that I felt that I could release and get back. (and get another tug pilot) This has happened to me too many times to recall all of them. Understand, I fly in an area where density altitude at takeoff can exceed 10,000 feet. It takes a strong tug to keep a heavy two seater constantly in range of the runway. My point with the original post is that there is no guarantee that the magic 200 feet AGL will always get you back. Bill Daniels |
#123
Not always.
I learnt to fly at the London Gliding Club, Dunstable Downs some 40 years ago, entirely on the winch, and on the T21b. There was one run for which I was taught that the correct procedure for a launch failure at a certain height was to land beyond the airfield boundary in the farmer's field. The point surely is that before the launch starts the pilot should have in mind all the possible options to cope with any launch failure; this may include an off-airfield landing for either a wire or an aerotow launch. Incidentally, the London Club now has more land, and outlandings after a winch launch failure are not now required. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Bill Daniels" wrote in message nk.net... snip My original point was that with airtow stuff happens and sometimes you aren't in position for a return to the runway. In winch launching, you are. Bill Daniels |
#124
The film clip posted by Andreas shows another sort of accident, i.e. it
seems not to have been caused by rotating too much and hence insufficient energy to avoid a heavy landing. Instead it is one of the accidents relatively common in winch launching - we do not see the glider leaving the cable, but it clearly flies at an adequate airspeed for some distance before spinning off a turn which is too steep, too close to the ground, in the wind gradient, and too slow for that set of circumstances. Without knowing the site one cannot say what the pilot should have done instead, but it is rare for there not to be a "land ahead" option with less serious potential after a low cable break or launch failure. As I remarked before, it is not the winch launch itself that usually produces the accident, it is pilot mismanagement of the subsequent flightpath. The too-little-energy syndrome this thread had been discussing most recently is pilot mismanagement during the launch - not having learned properly how to avoid having too little energy to cope with any eventuality. Both kinds of pilot error seem hard to eradicate in civilian gliding clubs, which leads to considerable numbers of "winch launch" related statistics. My understanding is that the Air Cadets in the UK, who do huge amounts of winch launching, have a much better safety record. It is rumoured that they achieve this by teaching in a more regimented fashion. However they do it, it demonstrates that winch launching CAN be safe - the problem is the human element, not the technology itself. The only way the human element can be made safer is by better training etc. If a wave of winch launching were to commence in the USA, I think it would be difficult to avoid a wave of accidents following, unless the training and conversion of pilots were done better than we often manage in the UK civilian gliding world. I wish every success to the instigators of the project, and I hope they can pick up enough know-how to climb the learning curve safely. Chris N. |
#125
Of course. When we say 200 feet, it's the first 199 that are
important. As a rule, you should only attempt to land in what you can see up to 200 feet agl. You've already been planning your landing during the tow, now you need only execute. Above 200 feet you have more options, one of which is to recognize the conditions (wind shear, sink, low airspeed, tailwind on takeoff, etc.) which may not favor a rote return to the airfield. But above 200 you can start planning landings to known fields that you cannot see (not necessarily the airport). |
#126
In article , F.L. Whiteley
writes There once was a non-BGA soaring site/club in East Anglia in the UK. The operator was named Fred, but the surname escapes me and I believe he passed away in the 1980's. By all accounts he operated a steam winch though I never met him nor saw it in action. I believe that operation was dwindling and may have ceased operations about 1980. Any stories out there? Frank Whiteley In the 60s there was an instructor at the Midland GC who had the idea of building a steam winch. Because the Long Mynd is largely peat, we thought we might use the terrain as a fuel source. The project never got off the ground; we never got any steam driven, Mynd fuelled launches. -- Mike Lindsay n |
#127
![]() "Chris Nicholas" wrote in message ... The film clip posted by Andreas shows another sort of accident, i.e. it seems not to have been caused by rotating too much and hence insufficient energy to avoid a heavy landing. Instead it is one of the accidents relatively common in winch launching - we do not see the glider leaving the cable, but it clearly flies at an adequate airspeed for some distance before spinning off a turn which is too steep, too close to the ground, in the wind gradient, and too slow for that set of circumstances. Without knowing the site one cannot say what the pilot should have done instead, but it is rare for there not to be a "land ahead" option with less serious potential after a low cable break or launch failure. As I remarked before, it is not the winch launch itself that usually produces the accident, it is pilot mismanagement of the subsequent flightpath. The too-little-energy syndrome this thread had been discussing most recently is pilot mismanagement during the launch - not having learned properly how to avoid having too little energy to cope with any eventuality. Both kinds of pilot error seem hard to eradicate in civilian gliding clubs, which leads to considerable numbers of "winch launch" related statistics. My understanding is that the Air Cadets in the UK, who do huge amounts of winch launching, have a much better safety record. It is rumoured that they achieve this by teaching in a more regimented fashion. However they do it, it demonstrates that winch launching CAN be safe - the problem is the human element, not the technology itself. The only way the human element can be made safer is by better training etc. If a wave of winch launching were to commence in the USA, I think it would be difficult to avoid a wave of accidents following, unless the training and conversion of pilots were done better than we often manage in the UK civilian gliding world. I wish every success to the instigators of the project, and I hope they can pick up enough know-how to climb the learning curve safely. Chris N. Chris makes a good point. There does seem to be a condition experienced by some people who find it hard to make fast mental adjustments from one set of conditions to another. One moment they are setting on the ground and 35 seconds later then are high in the sky at the controls of a glider and struggling to cope. The rush of a winch launch may create a sensory overload beyond their ability to manage. This may be analogous to a well known condition experienced by some motorists who enter a high speed expressway and find it hard to adjust to the fast traffic for a while. (and, of course, the reverse when leaving the expressway and entering slow surface traffic.) I have never experienced this and know of relatively few who do. If we were more alert to this possibility we might intervene and ask a pilot showing these symptoms to get a little more recurrent training. Perhaps this is something we instructors should emphasize in training. Instructors should be alert to sensory overload in their students and pace their lessons accordingly but things do happen quickly in a winch launch. Bill Daniels |
#128
In article , "Adrian Jansen"
writes: I was lucky enough to get a kite launch one day. We had about 35 Kts of wind on the ground, and someone suggested we try a launch. An instructor and I climbed into a Blanick L13, launched ( *very* short run ! ) and climbed to 4300 ft still on the wire. Of course we needed the expert cooperation of the winch driver, who eased off the power as we got about 500 ft, then payed out cable to let us climb. At the end, it was mostly the weight of cable ( single strand high tensile steel wire ) which determined the max height, although there wasnt much wire left on the drum. Yessss, but!! I suggest you now estimate the wing loading with 4300 ft of high tensile steel plus the down pull of the winch. Because you cannot feel the "G" loading on a winch does not mean it is not there and two effects occur. 1) Your stalling speed increases with the weight of cable dangling below you, and, 2) the G loading increases by the weight of cable attached to your glider so you MAY be far exceding your all up "weight". Beware, whilst this may be great fun, you get much closer to the envelope limits than you know.Care is needed. Barney UK |
#129
On Sun, 02 Nov 2003 15:03:18 GMT, "Bill Daniels"
wrote: There does seem to be a condition experienced by some people who find it hard to make fast mental adjustments from one set of conditions to another. One moment they are setting on the ground and 35 seconds later then are high in the sky at the controls of a glider and struggling to cope. The rush of a winch launch may create a sensory overload beyond their ability to manage. Hmmm... I never saw this during a winch launch yet. The work load during a winch launch is very low compared to an aerotow - the only thing you really need to watch is airspeed and the "bang" of a rope break. The situation you describe (when the pilot gets behind the plane) happens much more often during very low maneuvering (like low approaches) - suddenly pilot looses track of airspeed and stalls, for example (just as the clip I posted shows). Bye Andreas |
#130
wrote: There does seem to be a condition experienced by some people who find it hard to make fast mental adjustments from one set of conditions to another. One moment they are setting on the ground and 35 seconds later then are high in the sky at the controls of a glider and struggling to cope. The rush of a winch launch may create a sensory overload beyond their ability to manage. Hmm... If their sensory is overloaded so easily, then they should consider to quit flying immediately. Stefan |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 02:46 PM |
