Winch Way Is Up !!
Old November 5th 03, 11:25 PM
Stephen Haley
Ask arround the sailing community about how much one can be hurt by a
flailing synthetic rope - it might not be as bad as wire in some ways but
because it is infinately more flexible it can be just as bad.
"Bob Johnson" wrote in message
Hi Bill --
After my limited experience with it, I can't help but think that
synthetic is going to be a lot safer and less nasty to work with during
breaks or whenever else it has to be dodged or handled. It's light as a
feather, soft as a baby's butt and stores absolutely no energy.
BJ
"W.J. (Bill) Dean (U.K.)." wrote:
A winch should never have any doors or windows open while actually
launching. The cab must be fully enclosed, doors and windows shut.
The
windows must be of laminated glass or similar, with Lexan or something
similar on the inside surfaces. Any openings not glazed must be
protected
with expanded metal sheet, weldmesh or similar.
If the cable breaks, and sooner or later it will, it can get inside the
winch through any opening with amazing ferocity.
One of the Long Mynd amateur winch drivers had the back window slightly
open. The cable broke, came in through the window and attacked his
clothing. He considered he had a very lucky escape, and has given up
driving the winch.
At another club one of the most experienced of all winch drivers parked
his
car directly behind the winch and facing it, what he thought was a safe
distance away. This was at a busy club which has done many thousands
of
winch launches every year for a very long time. The cable broke and
flew
back, trashing the back of his car and round the car to break one of the
front door windows. I saw the car afterwards and asked who had run
into
him.
This sort of thing does not happen very often so it takes people by
surprise. It is a completely avoidable risk and is just not worth
taking.
Remove "ic" to reply.
"Martin Gregorie" wrote in message
snip
Climate control: there is a diesel burning heater for winter and the
sliding doors open in summer.
Martin Gregorie
  #42
Old November 5th 03, 11:54 PM
Bill Daniels
Stephen is right - IF you get tangled in it while it is under tension,
Spectra cut right through you like any strong line. Since you need a strong
line, there's no getting away from that. The real danger from winch line is
ballistic impact and there steel is far more dangerous.
The commercial shipping and barge industries have almost completely switched
from wire rope to Spectra on the safety issue alone. Steel
stretches,storing energy like a spring - that energy is released in a
springback when it breaks. Steel cable used to result in a hundred or so
deck hand deaths a year. Spectra has eliminated those deaths. Spectra
creeps under load and creeps back a little when it breaks - no real danger
there.
Spectra does not eliminate the danger posed by line termination hardware
like carabiners and weak links. Those can hit the winch cab with the energy
of a pistol bullet. A good strong, armored cab is still a necessity. (A
heater and air conditioner would be nice too.)
Bob is right in that Spectra is sweet to work with. Bare hands are fine -
no gloves needed to protect your hands from "fish hooks" that are common
with stranded steel cable. It's not black and white, but steel is far more
dangerous than spectra and that alone makes it worth the switch.
Bill Daniels
"Stephen Haley" wrote in message
Hi Bill --
BJ
  #43
Old November 6th 03, 03:12 AM
E. A. Grens
Martin -
I appreciate that, Bert. So far all the bad break descriptions have
described the cable lashing straight back over the winch. Has anybody
known it to go sideways and if so, how far to the side? I'm now
wondering if I should park the cable truck further away still or if my
usual position is reasonable.
As Bert said, the cable may strike anything within its range. That means to
the side as well as straight back. Where the cable goes in a break depends
little upon the wind (it has a low drag profile), but primarily on the
failure mode of the cable. The rupture across a cable is not simultaneous
at all points. It proceeds (rapidly) from one side to the opposite, and in
doing so may impart a large lateral force on the cable. I have seen cable
breaks, not in sailplane launching, where the cable whipped its full length
to the side. The whole circle of radius equal to the length of the cable
out, must be avoided if unprotected.
Ed Grens
  #44
Old November 6th 03, 06:58 AM
F.L. Whiteley
"E. A. Grens" wrote in message
Martin -
to
depends
in
length
Ed Grens
This was also briefed to me at Aston Down on the reverse pulley, that the
wire clearance zone was quite large in the event of a break it could flail
about a large radius around the pulley.
Frank Whiteley
  #45
Old November 6th 03, 11:23 AM
Martin Gregorie
On Thu, 06 Nov 2003 03:12:58 GMT, "E. A. Grens"
Martin -
Ed Grens
Thanks, all.
Noted for future reference.
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
  #46
Old November 6th 03, 03:08 PM
Robert Ehrlich
Bill Daniels wrote:
... It's not black and white, but steel is far more
A lot of other factors are to be considered when deciding to switch.
In our case, as we just spent a lot of money in 6 reels of 1km of
new steel cables, which is already a questionable decision when you
consider the very low use of the winch, spending a much higher lot
of money in spectra is even more questionable.
Safety of winch launch vrs. aero tow? Gary Boggs Soaring 172 November 13th 03 06:59 PM
Tost internal Winch HL Falbaum Soaring 3 September 24th 03 02:31 PM
using winch instead of aerotow goneill Soaring 5 August 27th 03 02:46 PM
Winch cable Bill Daniels Soaring 5 August 24th 03 11:13 PM
Using Plasma Rope For Winch Tows Craig Freeman Soaring 56 August 24th 03 10:55 PM
