Thin flexible solar panels
Old November 12th 03, 04:53 AM
Eric Greenwell
Default Thin flexible solar panels
I've come across some thin (0.008 inches), flexible solar panels that
look like they'd be ideal for gliders. These are the PowerFilm 7.2V
100mA ($30) units, with and without adhesive on the back:
http://store.sundancesolar.com/pow72v100maf1.html
So, $120 would buy me 4 panels, which would give me 200 ma at 15+
volts, almost enough keep up with my panel (including the
transponder) over a full day. By "full day", I'm including the time
it's tied out, as it would be at a soaring camp or on a safari, and a
five hour flight.
Has anyone used these, or know anything about them? Are there any
better units than these? I'm aware of the Strobl units from Germany,
but they are about twice the cost per amp.
!Replace DECIMAL.POINT in my e-mail address with just a . to reply
directly
Eric Greenwell
Richland, WA (USA)
Old November 12th 03, 11:19 AM
Vaughn
"Eric Greenwell" wrote in message
No, I don't know anything about those particular panels, I just want to
point out that even with only 200 ma of charge, you will need a charge
controller or you risk cooking your battery. Last time I checked, they were
a $29.00 item. I ruined several batteries before I learned.
Vaughn
Old November 12th 03, 12:25 PM
Paul Remde
Hi,
I have heard that solar panels are rated a bit optimistically (like glider
polars). So you may not get as much current as you think you will.
But it does sound nice and worth investigating. Let us know how it works
for you.
Paul Remde
five hour flight.
directly
Eric Greenwell
Richland, WA (USA)
Old November 12th 03, 03:01 PM
G.A. Seguin
Hi,
I have used flexible solar panel fot 14 seasons. Voltage never drop
below 12 volts with one battery 12v 7 amps even after 6-7 hour with
all electrics on.
Specs a Open circuit voltage 18V
Short circuit current 200 m.a, charging 12v 160 m.a., 14v 140 m.a.
Max power 3 watts and diode protected prevent flow-back.
dept is .5 inch ( today they are thinner) and 10X10 inches on top of
my solar panel.
Flex to 60 degrees max.
I run a L-nav, garmin gps and Microair radio and logger.
Regards,
Gilles
"Vaughn" wrote in message ...
Vaughn
Old November 12th 03, 03:53 PM
Nyal Williams
At 15:12 12 November 2003, G.A. Seguin wrote:
Hi,
never drop
6-7 hour with
all electrics on.
14v 140 m.a.
dept is wrote in message news:...
'Eric Greenwell' wrote in message
Are there any
units from Germany,
will need a charge
I learned.
Vaughn
Howzabout some particulars?
Old November 13th 03, 02:12 AM
G.A. Seguin
Hi,
I own this glider for 14 years. First battery lasted 11 years, present
one 3 years old. To avoid overcharge turn radio on when you connect
the battery
or install a on/off switch. My battery is on charge full time when not
in the
glider. This advice was given to me by the technician who maintain the
alarm
system at work some 15 years ago. It works. At my club one other
glider has
the thin flexible panel on top of the motor door, never a problem.
Regards.
Gilles
Nyal Williams wrote in message ...
Hi,
never drop
6-7 hour with
all electrics on.
14v 140 m.a.
Are there any
units from Germany,
will need a charge
I learned.
Vaughn
Old November 14th 03, 12:47 AM
Rudy Allemann
Eric Greenwell wrote in message ...
Also available at Jameco.com are Powerfilm 15.4V /100mA units that
are 10x5.9x.02" for $45.
Old November 28th 03, 02:08 PM
David Kinsell
"Paul Remde" wrote in message news:QEpsb.182087$e01.657569@attbi_s02...
Hi,
Sometimes the current rating given is into a short circuit, so you get
substantially less in practice. I'm sure these particular ratings are for the
panel laid flat, pointing directly into the sun, with no cloud cover. Wrapped
on a fuselage, frequently pointing away from the sun, the average will be a
whole lot less.
for you.
Paul Remde
five hour flight.
A full panel these days (with an active transponder) easily draws over 2 amps.
The current you'll actually get out of the solar panel would not make a
significant difference. You'd be more likely to notice the additional drag
due to the turbulence than you would notice a benefit in the electricals.
If 36 AH of batteries (with a generator on your engine) isn't enough, you've
got other problems.
Dave
directly
Eric Greenwell
Richland, WA (USA)
Old November 28th 03, 03:20 PM
Keith W
amps.
drag
you've
got other problems.
Dave
Is that the generator attached to the spare bike pedals for something to do
when the pilot gets bored? 8-)
But more seriously, would the material of the canopy absorb the frequencies
used by the solar panel - if not, would there be a problem with mounting the
panel inside the 'glass'. Even mounted outside, I suspect that the joint
around the canopy would cause sufficient turbulent layer that the extra
'roughness' would not be noticeable, if the panel were to be mounted behind
the canopy.
Keith
