![]() "ISoar" wrote in message ... Is a APRS (Automatic Postition Reporting System) enabled ham radio a reasonable substitute? Intro: http://nwaprs.org/downloads/WhatIsAPRS.pdf Way more info: http://web.usna.navy.mil/~bruninga/aprs.html Probably not for SAR since PLT's work fine BUT what a great idea for team flying. I note that Winpilot can plot team members position on the moving map display. Link members of the team with APRS and feed the data to Winpilot and each could see the position of the others. Bill Daniels |
Hi Gang, me again.
Let's be realistic about ELT's. Automatic activation in a crash situation has got to have a very low sucess probability. The ship and therefore the ELT antenna, may very well be upside down. The ELT may be damaged in the crash. At best, we can't expect a search plane on scene in anything less than 24 hours. So what's our best way to communicate a distress signal? I would think it's our aircraft radio. Transmit on 123.3 and 123.5 to your buddies or anyone who answers. The local soaring operation should send out a search plane in the evening. In a contest, you can expect a search to be activated about 7:30 in the evening. I think it would be a good idea to carry a hand-held radio, as a back-up. If your aircraft radio is functioning (transmit light on) but the antenna lead is broken, then I would pull out as much wire (RG-58) as I could and strip away 24 inches of the outside (grounding) shield. Then get your new antenna as high as possible. The survivor that started this thread, could have done this and then tied the end of his antenna to a parachute shroud line and the other end to a stone. Toss the rock over a tree branch and start calling, MAYDAY MAYDAY MAYDAY on all frequencies that might have listeners. Don't forget about 121.5 (emergency freq) To conserve your battery, the best time to brodcast is 15 to 18 and 45 to 48 minutes after the hour. Any SAR forces will be listening at these times. I cary a small survival kit with 2 quarts of bottled water in my ship, but what if I bailout? So, I just added several book matches and a very thin pocket knife to my parachute inspection pouch holder. With that parachute, a knife and matches, I feel I would have a fighting chance. Now, lets all conduct our soaring activities in a manor that doesn't require any of the above. JJ Sinclair |
http://www.gliderforum.com/thread-vi...id=885&posts=1
Al "JJ Sinclair" wrote in message ... Hi Gang, me again. Let's be realistic about ELT's. Automatic activation in a crash situation has got to have a very low sucess probability. The ship and therefore the ELT antenna, may very well be upside down. The ELT may be damaged in the crash. At best, we can't expect a search plane on scene in anything less than 24 hours. So what's our best way to communicate a distress signal? I would think it's our aircraft radio. Transmit on 123.3 and 123.5 to your buddies or anyone who answers. The local soaring operation should send out a search plane in the evening. In a contest, you can expect a search to be activated about 7:30 in the evening. I think it would be a good idea to carry a hand-held radio, as a back-up. If your aircraft radio is functioning (transmit light on) but the antenna lead is broken, then I would pull out as much wire (RG-58) as I could and strip away 24 inches of the outside (grounding) shield. Then get your new antenna as high as possible. The survivor that started this thread, could have done this and then tied the end of his antenna to a parachute shroud line and the other end to a stone. Toss the rock over a tree branch and start calling, MAYDAY MAYDAY MAYDAY on all frequencies that might have listeners. Don't forget about 121.5 (emergency freq) To conserve your battery, the best time to brodcast is 15 to 18 and 45 to 48 minutes after the hour. Any SAR forces will be listening at these times. I cary a small survival kit with 2 quarts of bottled water in my ship, but what if I bailout? So, I just added several book matches and a very thin pocket knife to my parachute inspection pouch holder. With that parachute, a knife and matches, I feel I would have a fighting chance. Now, lets all conduct our soaring activities in a manor that doesn't require any of the above. JJ Sinclair |
JJ Sinclair wrote:
Hi Gang, me again. Let's be realistic about ELT's. Automatic activation in a crash situation has got to have a very low sucess probability. The ship and therefore the ELT antenna, may very well be upside down. The ELT may be damaged in the crash. At best, we can't expect a search plane on scene in anything less than 24 hours. At best, how about less than an hour? Happened to a friend of mine when he crashed his glider. It wasn't a search plane, but an officer on the ground sent to check on the ELT signal. It can be much longer, of course. So what's our best way to communicate a distress signal? I would think it's our aircraft radio. If the glider is upside down, or the crash was so severe the ELT was damaged, it seems this is unlikely to be successful, because the radio, batteries, wiring, and antenna will be probably be damaged. An ELT is much more rugged than the normal VHF radio system. An ELT would've still functioned in the crash near Hemet, while the glider radio didn't. Had the crash disabled the pilot, it wouldn't matter if the VHF radio still worked, while the ELT would've activated. These considerations, plus the ability to fly my motorglider when no other glider pilots are flying, and the ability to fly out of range of my crew radio, led me to install an ELT. An ELT is not perfect, but it's not expensive over it's lifetime of, say, 15 years: $15-$30/year for the unit including battery changes. JJ's comments for coping with the situation (no ELT, no cell phone contact, no portable VHF) make good sense, however. I would add a signal mirror to his parachute pack. Transmit on 123.3 and 123.5 to your buddies or anyone who answers. The local soaring operation should send out a search plane in the evening. In a contest, you can expect a search to be activated about 7:30 in the evening. I think it would be a good idea to carry a hand-held radio, as a back-up. If your aircraft radio is functioning (transmit light on) but the antenna lead is broken, then I would pull out as much wire (RG-58) as I could and strip away 24 inches of the outside (grounding) shield. Then get your new antenna as high as possible. The survivor that started this thread, could have done this and then tied the end of his antenna to a parachute shroud line and the other end to a stone. Toss the rock over a tree branch and start calling, MAYDAY MAYDAY MAYDAY on all frequencies that might have listeners. Don't forget about 121.5 (emergency freq) To conserve your battery, the best time to brodcast is 15 to 18 and 45 to 48 minutes after the hour. Any SAR forces will be listening at these times. I cary a small survival kit with 2 quarts of bottled water in my ship, but what if I bailout? So, I just added several book matches and a very thin pocket knife to my parachute inspection pouch holder. With that parachute, a knife and matches, I feel I would have a fighting chance. Now, lets all conduct our soaring activities in a manor that doesn't require any of the above. JJ Sinclair |
try doing it in the frence alpes you plonker
Eric wrote the ability to fly my motorglider when no
other glider pilots are flying, Eric, Wasn't that the subject of a recent rules change proposal? :) JJ Sinclair |
![]() "Eric Greenwell" wrote in message ... ........... These considerations, plus the ability to fly my motorglider when no other glider pilots are flying, ............ Hey Eric, in a previous thread with JJ, I thought that you said that you did not do that! (Just couldn't resist) Duane |
Duane Eisenbeiss wrote:
"Eric Greenwell" wrote in message ... ........... These considerations, plus the ability to fly my motorglider when no other glider pilots are flying, ............ Hey Eric, in a previous thread with JJ, I thought that you said that you did not do that! (Just couldn't resist) Never said that! I often fly during the week, which means most pilots aren't even around, except for the few other retired motorglider pilots. So, this often means I'm the only glider pilot flying. Note that I didn't say "I often fly when it's unsoarable". It's 2.5 times more likely to be soarable during the week.... -- ----- Replace "SPAM" with "charter" to email me directly Eric Greenwell Washington State USA |
ISoar wrote:
Is a APRS (Automatic Postition Reporting System) enabled ham radio a reasonable substitute? Intro: http://nwaprs.org/downloads/WhatIsAPRS.pdf Way more info: http://web.usna.navy.mil/~bruninga/aprs.html An experimentation was done in my club with a such system, not as an emergency locator, but as a continuous position reporting system, and the experimentation was susccesful. It could be better than an emergency locator, since this last system, unless very resilient and so expensive, may be destroyed in a crash, while a permanent reporting system gives a last known position before the crash. However the reason for which we didn't adopt this system for all gliders in the club was the lack of available frequency. The both way we tried it were both illegal, one of them was using the radio of the glider on the airfield frequency, the other one was using a couple of talkie-walkies, allowed only for ground to ground transmission. See http://bipspevv.free.fr (sorry only in French). |
Buck Wild wrote:
I've said it before, though I haven't done an extensive web search on it, There's gotta be an elt available that sends one short burst with your exact GPS location to a satalite, instead of having the boy scouts try to hunt down an AM signal with a directional antenna, Does ATC radar log the radar positions of VFR traffic squawking 1200? I know they do it for codes assigned to airliners. If they did, it might provide a way to locate crashed glider that was using a transponder. -- ----- Replace "SPAM" with "charter" to email me directly Eric Greenwell Washington State USA |
Is this a fake or a joke? | Andrew Chaplin | Military Aviation | 0 | March 29th 04 12:04 PM |
On Topic Joke | Eric Miller | Home Built | 8 | March 6th 04 03:01 AM |
EU as joke (modified) | Cub Driver | Military Aviation | 241 | November 17th 03 04:55 PM |
American joke on the Brits | ArtKramr | Military Aviation | 50 | September 30th 03 10:52 PM |
