Revised IGC-approvals for some types of legacy recorder
Old November 17th 03, 09:40 AM
Ian Strachan
Default Revised IGC-approvals for some types of legacy recorder
This GFAC announcement has been prepared with the agreement of
the IGC GNSS Committee and the IGC Bureau.
It was put out a couple of days ago on the FAI IGC email mailing lists
and ). A question that has been
asked is where the current 24 types of IGC-approved recorder and their
10 manufacturers, are listed. This can be seen on:
http://www.fai.org/gliding/gnss/igc_approved_frs.pdf
At the last IGC Plenary meeting earlier in 2003, a new approval level
for
GNSS flight recorders was agreed. This was for "all IGC badge and
distance diploma flights" and was in addition to the existing levels for
"all
flights" and "badge flights up to and including Diamonds". The latter
is
used for types of recorder units that do not have their own GPS receiver
but rely on a separate GPS unit connected to the recorder by cable.
There are currently 24 models of IGC-approved GNSS recorder, from 10
different manufacturers. GFAC has completed a review of legacy
recorders, the IGC-approvals of which go back as far as 1996. The
following principles have been agreed for the futu
For world record flight claims, it is not considered suitable to have
recorders with one or more of the following characteristics:
1. No security microswitch or equivalent (this operates if the case is
opened).
2. Without electronic security giving the strength of systems such as
RSA
(public/private key systems) as assessed by GFAC and its experts in
electronic security.
3. No current manufacturer support (out of production and the original
manufacturer either no longer exists or is no longer dealing with them).
Negotiations with appropriate manufacturers have been going on for some
time, and revised IGC-approval documents have been circulated to them.
Types of recorders affected will have IGC-approvals for the new "all IGC
badge flights and distance diploma" level.
Types of recorders affected with the main reason:
Cambridge 10, 20 and 25 (not RSA or equivalent strength).
Filser LX20 first batch (not RSA or equivalent strength, no
microswitch).
Peschges VP8 (no microswitch, original manufacturer understood to be no
longer in the recorder business).
Print Technik GR1000 (not RSA or equivalent strength, original
manufacturer no longer in the recorder business).
Timescale
Filser LX20, Peschges VP8 and Print Technik GR1000
- all on 1 January 2004.
Cambridge 10, 20, 25 - the date of re-issue of IGC-approval documents as
part of present negotiations with the Horn Lake (MS) and Martinsville
(VA)
operations (this could be earlier than 1 January).
This announcement is made so that there will be no doubt of what is
happening, and why.
The only pilots affected will be those planning to attempt world record
flights, for which other types of IGC-approved flight recorder must be
used.
Any questions to the undersigned,
Ian Strachan
Chairman, GNSS Flight Recorder Approval Committee (GFAC)
of the International Gliding Commission
Bentworth Hall West
Bentworth
Alton, Hampshire GU34 5LA
ENGLAND
Tel: +44 1420 564 195
Fax: +44 1420 563 140
Old November 17th 03, 07:47 PM
Paul Remde
Hi Ian,
I am very suprised to learn about this development. So, if I undertand your
note correctly, you are saying that the CAI GPS-NAV units are suddenly not
considered secure? I think that is ridiculous. Please explain in detail
why you came to that conclusion.
Paul Remde
"Ian Strachan" wrote in message
for
"all
is
opened).
RSA
microswitch).
Timescale
(VA)
happening, and why.
used.
Ian Strachan
Bentworth Hall West
Bentworth
ENGLAND
Old November 17th 03, 08:16 PM
tango4
After going to all of the time designing the hardware security along came
the idea of public key cryptography so the IGC spec was 'upgraded' to
incorporate this additional security layer. The Cambridges and others got
caught between the two specs.
On the basis of openness and transparency shouldn't the IGC be disclosing
all known or suspected cases of 'trace fraud?' ( If there have been any )
then the general gliding community can get a grip on how the system is
working.
Ian Molesworth
"Paul Remde" wrote in message
news:VA9ub.28061$Dw6.139143@attbi_s02...
Hi Ian,
your
Paul Remde
for
"all
is
opened).
RSA
microswitch).
Timescale
(VA)
happening, and why.
used.
Ian Strachan
Bentworth Hall West
Bentworth
ENGLAND
Old November 17th 03, 09:29 PM
Bruce Hoult
Public key cryptography was well known in 1994 when the Cambridge 10's
were used at the NZ pre-worlds, and in fact I *told* them at the time
that they should be using something like RSA instead of something
home-grown.
Oh well.
-- Bruce
Old November 18th 03, 02:45 AM
Paul Remde
Yes, but doesn't the CAI system work? It is my impression that it is
perfectly secure and has never been compromised. So why suddenly call it
"insecure".
What is the plan to get the approval back in place? What must CAI do to
make it meet your new requirements?
Paul Remde
"Bruce Hoult" wrote in message
came
got
home-grown.
Oh well.
-- Bruce
Old November 18th 03, 03:15 AM
Marc Ramsey
"insecure".
As of January 1st, the CAI Model 10/20/25 won't be considered
"insecure", they just won't be considered "secure enough" for world
records. You can still use it for badges, 1000K+ diplomas, contests,
etc., just not world records.
Minimally, a firmware upgrade would be required, but it is not clear
that the microcontroller is fast enough to support the needed changes.
The manufacturer(s?) is the only one that can provide an answer...
Marc
Old November 18th 03, 04:01 AM
Paul Remde
I just find this absurd. I'm very angry about the sudden change.
If I remember correctly, Steve Fossett is using a GPS-NAV (and a 302 I
believe) and currently setting world records in the southern hemisphere.
I'm still waiting for a good answer to the question why. Why is the GPS-NAV
suddenly not secure for world records?
This is not acceptable behavior by the IGC.
Paul Remde
"Marc Ramsey" wrote in message
om...
it
"insecure".
Marc
Old November 18th 03, 05:10 AM
Bruce Hoult
In article gJfub.230766$Fm2.231960@attbi_s04,
home-grown.
Unfortunately we have no way of knowing, because the method used isn't
published. But essentially I believe it is a typical private key system
which relies on only trusted parties knowing the secret key. These
trusted parties include anyone writing software to upload flights (which
I suspect is the reason they would never give me the specs for writing
mac software), and authorized repair agents.
It is my impression that it is perfectly secure and has never been
compromised. So why suddenly call it "insecure".
Secure doesn't mean "hasn't (to our knowledge) been compromised". It
means "*can't* be compromised". If we didn't know how to do the latter
that would be a different matter, but we do.
And I'll ammend my earlier remarks. In 1994 when I was recommending RSA
to them I never imagined that they'd get to nearly 2004 before it became
an issue. So they may have made the correct commercial decision.
-- Bruce
Old November 18th 03, 05:12 AM
Marc Ramsey
The 302 will continue to be approved for world records for the
forseeable future. Steve Fossett also owns at least two Volksloggers,
which will also continue to be approved for world records.
According to the current flight recorder specifications, a new design
similar to the GPS-NAV could not be approved for world records. There
are other older flight recorder models for which there are known
security concerns. The only (more or less) fair way remove world
record approval from some models was to remove such approval from all
similar designs approved under the older specifications.
I can't think of any way this could have been done that everyone would
find acceptable...
Marc
Old November 18th 03, 05:39 AM
Marc Ramsey
I'd make the simple point that if RSA was required when the first flight
recorder specification was issued in 1995, there were no existing flight
recorder designs which could have been approved. RSA (or equivalent
asymmetric algorithm) has been required for "all flights" approval since
1997, I believe...
Marc
