Thermal locators!
Old November 19th 03, 04:48 PM
Bob Johnson
Default Thermal locators!
Serusly, maybe Dr. Jack can log in with his forecast of when he thinks
real-time moving map cockpit displays of current thermals, or (let's not
be unreasonable here) 1-hr old thermals will be available.
Or does he think there is a physical limit to this problem, beyond which
we cannot go? (Like 7 A-h batteries)
Winter food for thot
BJ
Old November 19th 03, 09:03 PM
John Ferguson
How about this to help you make the best of thermals
you have bumped into. Does anyone have any practical
experience of this device ?
http://www.themi.de/Themi%20Centering%20Device.htm
Anyone used the Winpilot Pro Climb maximiser, does
it work ?
John
of when he thinks
or (let's not
BJ
Old November 20th 03, 04:02 AM
Rod Pool
All
As I'm still trying to make Silver distance I well appreciate the
desire for a thermal road map. However, mystery is part of the marvel
of soaring.
For certainty all one need do is fill the tanks on a power plane and
go. No mystery in that.
Tom Knauff reports the Themi works. See eglider.com for a review.
Regards
Rod
Old November 20th 03, 05:29 AM
DrJack
The first thing that needs to be established is data uplink to a glider
so that _presently_ existing observations (eg satellite images) or
predictions (eg updated BLIPMAPs) can be obtained, and I'm not an expert
on when that will occur. (Milt Hare used to solve the updating problem
by calling his glider-rated wife from the air and having her describe
the latest BLIPMAP predictions to him, but I don't think that will be a
common practice!). Observation of individual thermals is difficult
enough for researchers (typically taking two lidar/radars) so I can't
see that being feasible in my lifetime, and in any case thermals have
relatively short lifetimes - what would be more practical would be
observation of the general "convective status" at specific locations,
which is possible using special temperature-profile sounders (not the
sounders used for upper-level wind speeds) - but at present those are
few and far between (an example of such sounder output can be seen at
http://www.weather.nps.navy.mil/profiler/ord_mix.gif )
Dr. John W. (Jack) Glendening Meteorologist
Old November 20th 03, 02:50 PM
Richard Pfiffner
Check out the thermal finder in WinPilot. WinPilot XP takes logger flights,
IGC files, and produces a thermal data base. You need to have WinPilot XP
for your desktop computer and WinPilot ADV or PRO for your Ipaq. I
personally have six years of data for Montague and all the contest flights
in the area, in my Montaque thermal data base. WinPilot can be set to
limit the thermals by sun position and wind direction. The thermals can be
turned on and off by assigning a button on the front of the Ipaq. Many
contest flights are available for download for most US contest sites. One
interesting thing is the thermals that were found by contest pilots in areas
that locals very rarely fly. I believe there is also a thermal data base
available for the Minden area. I will add a thermal database page for
WinPilot users to my website in the next couple of days. If you have a
thermal database for you area and want it placed on my web please email it
to me.
Richard
www.craggyaero.com
"Bob Johnson" wrote in message
BJ
Old November 20th 03, 03:19 PM
Ray Lovinggood
I heard about this feature of WinPilot at the SSA convention
earlier this year. Amazing.
Now, it will be interesting to see the effect to the
database(s) as land-use changes take place. What happens
to the burned areas (California?) or timbered areas
or locations that were purely agricultural and change
to residential or commercial?
I don't have WinPilot, but I think it would be interesting
to know what happens.
Ray Lovinggood
Carrboro, North Carolina, USA
your Ipaq. I
can be set to
The thermals can be
of the Ipaq. Many
a thermal data base
database page for
days. If you have a
to me.
Richard
www.craggyaero.com
Old November 20th 03, 06:01 PM
Gary Kemp
The closest thing I have seen for thermal locators is WinPilot's data
base for thermals. you can enter as many thermals for a site that you
want to and have a read out on you PocketPC Winpilot program that
shows where thermals have historically been located given a particular
day, time of day and wind variables. Works pretty good, but if you
have flown many years at one site you know where the thermals are
anyway, if there are any thermals that is.
G. Kemp
DrJack wrote in message ...
Old November 20th 03, 08:04 PM
Jack Glendening
Robert Ehrlich wrote:
How does such a device work? There is on the picture the indication
"915 MHz" which seems to imply that it uses radio high frequency, but
how?
In additon to the HF radio signal an acoustic pulse is sent which alters
the propagation speed depending on temperature. The height to which it
can reach is limited by the strength of the acoustic signal and so is
not practical at higher altitudes. See
http://www.wx.rutgers.edu/PAM/aboutRASS.shtml
Old November 20th 03, 09:01 PM
Bob Johnson
DrJack --
I took the liberty of truncating your url and came up with this record:
http://www.weather.nps.navy.mil/profiler/r07_sfc.gif
The second bar of 24-hr data "deg" shows a background of Westerly winds
until about 10:00 UTC (1 PM? local), when shifts around the compass are
seen. These shifts persist until around local sundown. Could these
shifts be "convective status" markers from the profiler?
Another story (good grief, will they never stop?):
Wally Scott was limited by car tows to only collecting more Barringer
Trophies than his wife had room for on the walls of their home. He would
wait at the end of the runway with his ship hooked up to his Chevy
station wagon until one or more of the runway windsocks started to droop
and point away from the prevailing wind. This was his signal for "OK,
Boots, slack's out, let's go". And he was gone.
I guess a space-based Doppler Lidar would be hard pressed to to
determine a surface convective reflection through all the intervening
atmospheric layers?
http://www.ghcc.msfc.nasa.gov/sparcl..._tutorial.html
Thanks for your answer,
Bob Johnson
Midland, Texas
Old November 20th 03, 11:39 PM
DrJack
Those are surface measurements from a normal set of surface weather
sensors. The one you mention is surface wind direction, the dramatic
changes being onshore/offshore sea-breeze flow since the site is located
within 2 miles of the ocean.
For Auction: Thermal Imaging Camera - One Day Left sell2all Rotorcraft 0 April 29th 04 08:29 PM
For Auction: Thermal Imaging Camera - One Day Left sell2all Naval Aviation 0 April 29th 04 08:09 PM
For Auction: Thermal Imaging Camera - One Day Left sell2all General Aviation 0 April 29th 04 08:09 PM
For Auction: Thermal Imaging Camera - One Day Left sell2all Military Aviation 0 April 29th 04 06:45 PM
For Auction: Thermal Imaging Camera - One Day Left sell2all Home Built 0 April 29th 04 06:43 PM
