Finding vent hole in wing skin
Old November 20th 03, 06:38 AM
Martin Eiler
Default Finding vent hole in wing skin
We have a Lak 17 in the shop and have found that water cannot
be put into the left wing. It appears that during some previous
repair, apparently the shop glassed and refinished over the vent
hole in the underside of the wing. The problem now is how to
find the exact spot to drill in order to open up that vent hole.
Hopefully the vent line is still attached to the inside of the wing
skin where the hole was.
Measuring the position of the vent hole in the other wing is no
guarantee, and even measuring the location on the same wing on
another Lak 17 would be questionable. Tapping on the skin
seems to give no real indication either. So has anyone ever ran
across this before and if so did you come up with a fool proof
method of finding the exact spot to drill?
M Eiler
Old November 20th 03, 03:04 PM
Timbro
If you fish a light around in there you may be able to find the hole
by looking for light coming thru the glass.
"Martin Eiler" wrote in message ...
M Eiler
Old November 20th 03, 09:07 PM
Bob Kuykendall
Sounds like a job for a LAK-tation specialist. ;}
Old November 21st 03, 03:33 AM
Tim Ward
"Bob Kuykendall" wrote in message
om...
I can see you're going to milk the situation for all it's worth.
Tim Ward
Old November 21st 03, 03:58 AM
tango4
An ultrasound scanner might help, ask the local midwife!
How about running the wing through the nearest MRI scanner or the local
airport baggage x-ray machine?
Ian
M Eiler
Old November 21st 03, 04:09 AM
REMOVE TO REPLY.pdb
In the early 70's David Harper wrote a fictional account of
a world soaring competition held in Alaska. He was evidently
a reasonably successful author before this bomb and appears
to have spent some time in Alaska because he did capture
some of the regional peculiarities generally known only to
locals.
Does anyone know if he is still alive and if so, how I might
reach him?
Thanks
Pete Brown
Anchorage
http://home.gci.net/~pdb/
http://groups.yahoo.com/group/akmtnsoaring/
Old November 21st 03, 07:22 AM
tango4
"Tim Ward" wrote in message
om...
Tim Ward
Oh, don't be such a cow!
Ian
Old November 21st 03, 01:44 PM
Luka Znidarsic
Hello,
I just asked into factory about your problem!
I receive answer below. If you give me your fax number I can send you =
also fax with drawing.
Best regards,
Luka Znidarsic, www.ies.si LAK Sailplanes (dealer of LAK for Italy and =
Slovenia)
Dear Luka,
The spot where vent hole is located is at distance of 25mm from =
root rib and 226mm from wing leading edge, and (or) 394mm from flap =
mounting axis. To help you to understand where it is located I'm sending =
to you a fax.
CAUTION!!!: for finding hole, first of all, use small (about 1mm =
diameter drill) and drill about 2mm deep hole. And only if you find =
hole, only then use bigger drill.=20
Sincerely
Linas Bartkevicius=20
Manager=20
AB Sportine Aviacija=20
Pociunai LT-4340, Prienai=20
Lithuania=20
Tel.: +370 319 60567=20
Fax.: +370 319 60568=20
Mob.: +370 652 77282=20
http://www.lak.lt=20
E-mail: =20
fuel tank plumbing pwm Home Built 18 January 27th 05 04:54 AM
Almay Hypo-Allergenic Kinetin Skin Care Value$32.89 [email protected] Aviation Marketplace 0 April 29th 04 11:41 PM
Canard planes swept wing outer VG's? Paul Lee Home Built 8 January 4th 04 08:10 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 03:52 AM
