#31
![]() "soarski" schreef in bericht om... In my country, our gliders move forward because the wing produces thrust, and our sailboats move over the water because the sail produces thrust. Whether we should rule the world is causing much controversy. In my country (Holland) students will be disqualified from their examination when they make an "interesting" remark like this. Reducing induced drag is what winglets do and gravity is the engine of our gliders. Karel Termaat |
#32
![]() "Nyal Williams" wrote in message ... Why don't we just combine the two words in one concept and call it 'thrift?' Personally I'd prefer 'lust' ![]() Ian |
#33
At 14:06 30 November 2003, K.P. Termaat wrote:
'Reducing induced drag is what winglets do and gravity is the engine of our gliders.' Hallelujah John Galloway |
#34
K.P. Termaat wrote:
"soarski" schreef in bericht om... In my country, our gliders move forward because the wing produces thrust, and our sailboats move over the water because the sail produces thrust. Whether we should rule the world is causing much controversy. In my country (Holland) students will be disqualified from their examination when they make an "interesting" remark like this. Reducing induced drag is what winglets do and gravity is the engine of our gliders. And what produces the "thrust" that moves your sailboats? Gravity? This may be a simple confusion over the word "thrust", which I used (as did the original question) in the sense of "force in the direction of motion". Both the glider and the sailboat are propelled in a forward direction by lift from the wing or sail. -- ----- Replace "SPAM" with "charter" to email me directly Eric Greenwell Washington State USA |
#35
At 17:18 30 November 2003, Eric Greenwell wrote:
And what produces the 'thrust' that moves your sailboats? Gravity? This may be a simple confusion over the word 'thrust', which I used (as did the original question) in the sense of 'force in the direction of motion'. Both the glider and the sailboat are propelled in a forward direction by lift from the wing or sail. -- ----- Replace 'SPAM' with 'charter' to email me directly Eric Greenwell Washington State USA Eric, The 'thrust' for a sailboat comes from the wind. No wind, no go. The 'thrust' for a glider is from gravity. No gravity, no go. A good clue to this is that sail boats have their wings built vertically and gliders have theirs horizontal. The observation that the airofoil (wing, sail or winglet) of a non powered vehicle can have a forward pointing component to its lift vector cannot seriously be argued to represent thrust by anyone with any notion as to cause and effect. Your definition of thrust (as applied to a glider) as a 'force in the direction of motion' is fundamentally flawed as the 'force' cannot exist without an external source of power i.e gravity dragging the glider downwards. The thrust for a glider is always directed vertically downwards. Conveniently for us there is a viscous medium between the glider and the ground and clever design of the lift and drag aspects of the glider shape allows a resolution of the lift and drag vectors such that the glider slides forwards as it falls. Winglets have a favourable reducing effect on the overall drag at certain speeds by reducing the induced drag. In the case of a glider the thrust or force that powers it only acts in the direction of flight when the glider is pointing vertically downwards. John Galloway |
#36
On Sat, 29 Nov 2003 11:32:36 -0800, Eric Greenwell wrote:
Here's an expanded expanation: Gravity is pulling straight down, and so can not propel the glider forward; drag is pulling the glider back, and so can not propel the glider forward. So, what is left to counteract the drag? Lift, produced by the wings. This forward force comes from the lift, which is not vertical, but tipped forward a bit. Look at any diagram showing the forces on a glider, and you will see how the lift, drag, and gravity forces accomplish this. It is not common to call this force moving the glider forward (without it, drag would bring it to stop) "thrust", but the word is sometimes used that way. Sheesh! So many words and so little knowledge... Here's how it works, guys. For any aircraft in balanced flight, there are four forces acting on it. All forces except gravity act only along the chord or perpendicular to it. Gravity not only produces a force in opposition to lift, but a resultant vector force which can be either thrust or drag, depending on the angle of the chord in respect to earth (gravity). in other words; Gravity is the 'engine' in a glider that produces thrust. For those that don't understand vector force components (or flunked trig), don't worry 'bout it. Simply believe they exist. As for the winglets, they only reduce drag. At the point where the airfoil ends, air rolls to the other side of the wing due to the pressure difference. The rolling air produces a vortex that kinda acts like vacuum cleaner hoses grabbing the trailing tips of the wings. The winglets interfere with the creation of the vortex(s) thus reducing drag. Smaller vortex (smaller vacuum cleaner) means better L/D (slicker ship). LittleJohn Madison, AL |
#37
John Galloway wrote:
The observation that the airofoil (wing, sail or winglet) of a non powered vehicle can have a forward pointing component to its lift vector cannot seriously be argued to represent thrust by anyone with any notion as to cause and effect. We are becoming almost philosophical here, but I'll give it a go. I'm not seriously arguing it is "thrust" as the term is typically used by aeronautical engineers. Bob Salvo asked "Do winglets produce thrust?", and most of us knew exactly what he was asking: "Do winglets produce a force in the forward direction?". I continued to use in that manner in what I hoped was a light-hearted way to get people to think about what does move a glider through the air. Your definition of thrust (as applied to a glider) as a 'force in the direction of motion' is fundamentally flawed as the 'force' cannot exist without an external source of power i.e gravity dragging the glider downwards. I agree the force of gravity is needed. I don't agree it is "the" source of power. See below. The thrust for a glider is always directed vertically downwards. Conveniently for us there is a viscous medium between the glider and the ground and clever design of the lift and drag aspects of the glider shape allows a resolution of the lift and drag vectors such that the glider slides forwards as it falls. What if the glider isn't falling, but moving at a constant altitude while ridge or wave soaring? What powers it then? I think it's the wind, like a sailboat. We also get our power (it might be better to say "energy") from the towplane, that first pulls us up, then from the thermals that let us climb on our own. Winglets have a favourable reducing effect on the overall drag at certain speeds by reducing the induced drag. Agreed. -- ----- Replace "SPAM" with "charter" to email me directly Eric Greenwell Washington State USA |
#38
You could describe it as 'interfering with the formation
of the tip vortex and thereby reducing drag', but an easier to understand explanation (and just as accurate) is that of the Thrust component of the force vector produced by the winglet. The crossflow component generated by the tip vortex means that the angle of incidence of the winglet relative to the flow is different to that relative to the line of flight. If this angle is large enough then the winglet itself will no longer produce a force component opposing the direction of travel, but will instead produce a small 'Thrust' component in the direction of travel. The fact that the winglet is in fact producing a force in the direction of travel is why the term 'Thrust' is perfectly correct. Its easier to explain using a diagram, and plenty of textbooks have them if you really are that interested. The important thing to remember is that because of the influence of the tip vortex, the flow striking the winglet is not travelling in the same direction as the freestream velocity. Thats what makes it all possible. |
#39
May be they reduce drag, but in my opinion they can=B4t produce thrust. A=
n airfoil can produce nothing but lift and drag. A wing produces "thrust" because it=B4s lift is partially directed "forward". I=B4ve made two graphics, I think they are more clearly than my bad engli= sh: http://www.ich-habs-doch-gleich-gesagt.de/fluegel.gif http://www.ich-habs-doch-gleich-gesagt.de/winglet.gif The black vectors are the real airforces. Bernhard |
#40
The glider is always sliding "downhill", the updrafts, thermals, ridge lift,
all just change the height of the hill. The wing just changes the slope of the hill, a 1-26 has a steep slope and an ASH-25 has a shallow slope. We are all sliding downhill when we soar. What if the glider isn't falling, but moving at a constant altitude while ridge or wave soaring? What powers it then? I think it's the wind, like a sailboat. |
A Level 1 AOA clarification | Ramapriya | Piloting | 64 | January 9th 05 01:19 AM |
Space Elevator | Big John | Home Built | 111 | July 21st 04 04:31 PM |
max altitude and Mach 1 | Boomer | Military Aviation | 22 | June 1st 04 08:04 PM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
P-38 Exhaust | Stephen Harding | Military Aviation | 10 | April 19th 04 07:03 AM |
