Overstocked on PDA's
Old December 1st 03, 06:42 PM
Ed Hollestelle
Default Overstocked on PDA's
We have too many iPaq's on hand.
All models: 31XX, 36XX,3765, 38XX and 39XX
Cables/GPS units (with iPaq cable and power converter), Colibri loggers and
LX160 computers.
Pleas give us a call at 519-461-1464
Ed Hollestelle / Solaire Canada
Old December 2nd 03, 12:58 AM
Jim Kelly
the 3950 is **clearly** the best of these for gliding . .
jk
"Ed Hollestelle" wrote in message
loggers and
| LX160 computers.
Old December 2nd 03, 01:20 AM
Marc Ramsey
No, the 3950 is **clearly** the best for use under office lighting,
thanks to its transflective screen. The 36xx, 37xx, and 38xx have
reflective screens, which my eyes find somewhat easier to read under
direct sunlight. The 31xx may only have a grey scale screen, but it has
better contrast in direct sunlight than any of the color models. In
reality, none of these devices can beat the contrast or clarity of the
screens on the SN10 or B2000, but they do look prettier during those
moments when you can actually distinguish the colors...
Marc
Old December 2nd 03, 02:19 AM
Eric Greenwell
Is this because of the screens used on the SN10/B2000, or because they
are mounted on the panel and mostly out of the sun and glare?
Replace "SPAM" with "charter" to email me directly
Eric Greenwell
Washington State
USA
Old December 2nd 03, 02:54 AM
Marc Ramsey
has better contrast in direct sunlight than any of the color models.
In reality, none of these devices can beat the contrast or clarity of
the screens on the SN10 or B2000,
The real answer would have to come from an LCD expert. My experience
has been that my SN10 and Palm m100 had roughly the same (good) contrast
under sunlight and shade, the Aero 15xx was slightly worse, and the iPaq
31xx had even lower contrast (but still better than any color display).
The reflective color displays work OK in sunlight, with the backlight on
or off. They work in shade if the backlight is on. The transflective
displays are basically unreadable in sunlight or shade with the
backlight off, with the backlight full on in sunlight they are
marginally readable, OK in shade.
I think the clearest indication that there is a problem with using the
39xx in soaring, is that I am always experimenting with screen
protectors to try to eliminate glare and improve contrast. I never felt
the need with earlier models...
Marc
Old December 2nd 03, 04:56 AM
Jim Kelly
backlight on
However these units are quite old now and I find that even with my
current model h5550 I could happily have it's speed many fold better
Afaicr no iPaq models have had this type of display for 2 years or
more?
The transflective
Hence we leave the backlight on (requires an efficient 5v supply
from the glider's battery) and need to solve the reflective issue.
felt
Perhaps you could add your findings for us, to the adjacent post?
The H3950 is not a current model, but it has some advantages over
it's replacement, the H5150 (simpler design, no Bluetooth, bigger
battery, adequate audio volume). The H3950 can be updated to the
latest firmware/operating system. And it has the large display (new
iPaqs have a 15% smaller display! - the H5xxx have the larger).
Thanks for your insight . . I had not appreciated that the displays
had changed a couple of years back and become harder to use in
sunlight. So much for progress!!
Cheers,
Jim Kelly
Old December 2nd 03, 05:25 AM
Marc Ramsey
backlight on
The extra speed (in comparison to earlier iPaqs) is only useful if
you're trying to display terrain. Since the terrain makes the display
even harder to read, I don't see much point to spending the extra money.
more?
That's correct, all Compaqs (and just about every other production PDA)
since the 39xx have used transflective displays, because they are vastly
better in the office environment.
The transflective
The reflections are only part of the problem. The older models were
easier to read, even with reflections, as they had better contrast. The
newer transflective designs are getting brighter backlights, that should
help improve the sunlit display.
Marc
Old December 2nd 03, 10:54 PM
Marc Till
I have been happily using a 3760 iPAQ for two seasons now, with no
display visibility problem. The only drawback is actually the poor
autonomy on internal battery.
As I am flying club gliders, I am using a set of 4 D-size NiCd batteries
(4400 mAh @ 4.8 V) which allows for something like 10 hours with a
Navman 3000.
Marc
Marc Ramsey a écrit:
backlight on
more?
The transflective
Marc
Old December 3rd 03, 02:56 AM
Jim Kelly
Can anyone remember the models in the H38xx range? How did they
differ? Since this was apparently the last of the 'better' *sunlit*
displays, it would be good to know which ones to snap up if they
become available second hand.
This Australian site shows that HP sell an upgrade to the latest
operating system for the H38xx (and H39xx, H54xx):
http://h50043.www5.hp.com/ppc2003/au/welcome.html
Cheers,
Jim Kelly
Old December 3rd 03, 01:40 PM
Paul Remde
Hi,
I disagree that the older (3800 and before) screens were easier to read
outside. I think the 3900 and later a slightly better.
Paul Remde
"Jim Kelly" wrote in message
u...
Cheers,
Jim Kelly
PDA's Tony Owning 15 February 6th 04 10:20 PM
