50+:1 15m sailplanes
Old December 26th 03, 11:02 AM
Gerhard Wesp
Ian Strachan wrote:
Our vaches may not be very vicious but our roads (for retrieving) are
But didn't the ``vaches folles'' (=mad cow) start out in the UK??
SCNR ;-)
-Gerhard
Old December 26th 03, 11:41 AM
Ian Strachan
In article , Eric Greenwell
writes
JJ Sinclair wrote:
"There is a substitute for span, it's called skill, but you can buy
span"
OK, it's 7:00 PM, the sky has been completely overcast for hours,
you have
5000 feet and your looking at a 50 mile final glide. Now SKILL your way home.
You don't grasp the concept, JJ: with skill, the pilot is 50 miles out
at 6 pm, not 7 pm, and gets home just before all the lift dies.
Since I can't buy skill either, I bought a motor.
Even better, a motor AND good L/D. Gap-crossing can be needed any time,
not necessarily after 6 PM !
Ian Strachan
Gap Crossing Country (UK)
Old December 26th 03, 02:54 PM
JJ Sinclair
Now, Now, Eric we don't want to start that *motor* argument again, do we?
JJ Sinclair
Old December 26th 03, 03:01 PM
JJ Sinclair
Iam wrote.
Now, Now, Ian we don't want to start that *motor glider* vs *pure glider*
discussion again, do we?
JJ Sinclair
Old December 26th 03, 08:59 PM
Ian Strachan
In article , JJ Sinclair
writes
Iam wrote.
I meant gap crossing by L/D, not by motor, as I am sure you knew!
I only use the motor to avoid landing out, and that very rarely. This
year, not at all other than self-launch.
Ian Strachan
Bentworth Hall West
Tel: +44 1420 564 195 Bentworth, Alton
Fax: +44 1420 563 140 Hampshire GU34 5LA, ENGLAND
Old December 26th 03, 09:31 PM
Eric Greenwell
JJ Sinclair
That was a *contest* argument, I think!
And lest someone not understand the joking going on here, it's worth
noting that span, motors, and skill aren't mutually exclusive, as Klaus
Ohlmann and others flying in Argentina have shown them to be a potent
combination. Regardless of our individual skills, we all face the
challenge of finding that "sweet spot" combination of glider attributes
(performance, handling, cost, span, motor, competitiveness, etc.) that
will give us the most enjoyment for our money. The glider we end up with
affects the social aspects (who we fly with, when and where we fly), and
the social aspects also affect the glider we choose.
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
Old December 29th 03, 02:48 AM
BTIZ
I don't see it on their web page..
BT
"Paul T" wrote in message
Here's the figures on the American DuckHawk (got to
be one of the most awful names for a sailplane) from
the promo sheet.
Windward Performance LLC takes its advanced technology
to the racing class.
Specifications
Empty Weight 300 LBS
Gross Weight 900 LBS
Wing Span 49.17 FT
Wing Area 74.93 FT^2
Aspect Ratio 32.2:1
Length 20.6 FT
Horizontal Span 6.8 FT
Vertical Height 4.5 FT
Structural Limits
+11.0 / -9.0 g's
Va, Vb = 165 KTS
Vne = 200 KTS
Performance
At 500 LBS, 6.7 Lbs/FT^2
Best Glide 50:1 at 50 KTS
Min Sink 94 FPM at 40 KTS
Stall Speed 35 KTS
At 900 LBS, 12.0 Lbs/FT^2
Best Glide 52:1 at 67 KTS
Min Sink 122 FPM at 57 KTS
Stall Speed 47 KTS
(data for 900 LBS, 12 PSF)
Airfoils
Inboard 12.7 % t/c
Outboard 10.2 % t/c
The DuckHawk has the broadest wing loading range available,
the highest maneuvering and redline speeds, and the
lowest inertias for snappy handling. The lower flying
mass within the 15m span constraint gives an induced
drag advantage of 49% at 500 LBS and 33% at 900 LBS
(span loading squared) compared to the competition
Time will tell - my money is on the Diana 2 which is
a development of the SZD-56-1 Diana. (Whose cockpit
is bigger than a Ventus a!). Incedently at Leszno they
were also talking about an 18m version and 22m Open
class version.
  #28
Old December 29th 03, 03:36 AM
Eric Greenwell
The info appears to be from a handout at the Sailplane Homebuilders
Association's Western Meeting at Tehachapi, CA, in September 2003. I
can't find my copy of the handout, and the website only mentions the
DuckHawk (Peregrine falcon, but maybe that name was taken, or more
likely, to match with the SparrowHawk now being produced).
BT
the promo sheet.
Specifications
Wing Span 49.17 FT
Aspect Ratio 32.2:1
Length 20.6 FT
Structural Limits
+11.0 / -9.0 g's
Va, Vb = 165 KTS
Vne = 200 KTS
Performance
Stall Speed 35 KTS
Stall Speed 47 KTS
Airfoils
Inboard 12.7 % t/c
Outboard 10.2 % t/c
class version.
Eric Greenwell
Washington State
USA
  #29
Old December 29th 03, 05:51 PM
GMC
Wil Schuemann achieved 50:1 with his modified ASW-12 (wings modified
and cut down to 15 m span). Very clear clean sink rate data on a very
good calm day with as little airmass movement as one could hope for.
This was in the early 80's with an aircraft that was old then.
  #30
Old December 30th 03, 01:25 AM
Bob Kuykendall
Earlier, Greg Cole ) wrote:
...Very clear clean sink rate data
on a very good calm day with as
could hope for.
I'd like to see that data. Is it available online?
Thanks, and best regards to all
Bob K.
http://www.hpaircraft.com
sailplanes for sale Jerry Marshall Soaring 1 October 21st 03 03:51 AM
