Why Fly only seated
Old December 29th 03, 03:15 AM
Mackfly
Default Why Fly only seated
I think if you look deep enough you might find that the "head first" position
is prohibited by the FAA regs. Mac
Old December 29th 03, 03:13 PM
JJ Sinclair
Something that no one has mentioned yet is the effect on your inner ear when
pulling G's with your head down. Maybe some of our medical types could expand
on this. I once saw an F-102, roll into an overhead pattern, looked down to
change radio frequency and flew right into the ground.
JJ Sinclair
Old December 29th 03, 05:58 PM
Gill Couto
I think that nails it. Flying prone in a hang glider is not a problem
because the G's are rarely significant even with the extra weight of
the helmet. Visibility and comfort also add up to make the
"lawn-chair position" ideal as several have suggested. You can just
take a lot more G's that way.
The reason I asked this question is because I took sailplane lessons
last year, after several years of hang gliding. I found a number of
things that took some getting used to, starting with the comfy seat.
It took many flights before my instructor stopped telling me to not
weight-shift the plane with my shoulders.
GillCouto.com
JJ Sinclair
Old December 29th 03, 08:32 PM
Bill Wallace
Ok, I'll bite. Please cite the specific regulation.
(Mackfly) wrote in message ...
Old December 29th 03, 10:18 PM
Buck Wild
Gill Couto wrote in message news:RWZHb.32862$J77.2112@fed1read07...
I pull the same G's in HG as in gliders on a regular basis, up to
about 3.5. The body will take much more G prone than sitting, unless
your brain is in your butt. G induced LOC happens because the blood
leaves the head. The problem with prone is having to hold your head up
all day. Sitting up is an inferior position for pulling G's, but it's
alot more comfortable.
GillCouto.com
Evolution is a slow process, but when you get it sorted out, you will
find out why it's a superior position. I initially crossed over to
sailplane because of back problems, and Im glad we don't fly them
prone.
Really? What FAR is that?
JJ Sinclair
Im quite aware of that effect, JJ, looking down & to the right during
a left turn is supposed to cause vertigo, suprisingly I've never
experianced anything like that, even doing aerobatics prone. Must be
physiologically different when flying on your belly like a reptile, as
I've never heard of anyone get that effect while hang gliding.
-Dan
Old December 29th 03, 11:49 PM
Gill Couto
There may be some days when my butt might be in my brain but I've
never had it the other way around, Dan. I can see it's a lot less
stressful to take G's sitting with the extra weight down your spine
than it is prone with the weigh of your head leveraging on your spine.
3.5 G's is like putting some 60+ lbs. of weights on a 25 lb. head.
You must have the neck of the CA governor or an extra rope to your
helmet from the hang loops to support those G's. Holding a 60 lb.
cement bag over your head while sitting might be easier.
Just a few more thoughts,
GillCouto.com
prone.
-Dan
Old December 31st 03, 12:34 AM
Gary Kemp
I remember in the late '60's at Elsinore California a glider that was
flown from the prone position, I think it was a Marske wing?? anyway
it was small and the pilot flew from his belly with rudders at the
back and head first in the canopy at the front.
I don't believe that's correct. I've been through the regs in 14 CFR
part 23, and also the European JAR-22, a few times and seen nothing
there that would bar prone flying. It seems to me that it's just not
the sort of thing that the FAA tends to make rules about. Besides
that, I can only imagine the language that it'd take to define a thing
like that to the necessary degree of detail.
Thanks, and best regards to all
Bob K.
http://www.hpaircraft.com
Old December 31st 03, 01:30 AM
Bill Daniels
"Gary Kemp" wrote in message
om...
Nope, that was Phil Lampson's UFO (Named "Unidentified Falling Object" due
to the low L/D by Ross Briglieb). He also flew it at the old El Mirage.
There was a story about it in a late '60's Soaring.
Seems he painted the leading edge with a stripe that tripped the boundary
layer into a separation bubble that caused full aileron and elevator
reversal - had to learn a new way to fly on the way down - there was no
bailout possibility.
All Marske designs have had fairly standard cockpits.
Bill Daniels
But, I'm a skilled professional [email protected] Piloting 10 December 2nd 04 05:01 AM
definition of "dual controls" Lee Elson Instrument Flight Rules 4 April 24th 04 02:58 PM
Why fly only seated? Gill Couto Soaring 18 December 31st 03 01:59 AM
