There is an article in the archives of Gliding & Motorgliding International
on Aerotow "Upset" Accidents by Chris Rollings which may be found at: http://www.glidingmagazine.com/ListF...Dtl.asp?id=327 . All tug pilots, and glider pilots who launch by aerotow, should read this article. For the U.K. the B.G.A. give advice to be found in "Laws and Rules for Glider Pilots" 14th edition June 2003 (cannot be read on-line): Under "Recommended Practices": RP12. The minimum length of aerowtow rope recommended is 150ft. However, under special circumstances a short rope may be used. The operators' attention is drawn to the following factors which may cumulatively contribute to a hazardous situation: (a) Low experience of glider and/or tug pilot (b) Gliders fitted with C of G hook only (c) Glider's C of G towards the aft limit (d) Turbulent air in the take-off area (e) Rough ground in the take-off area (f) Significant cross-wind component. RP13. After releasing the cable, the glider should turn away so that the tug aircraft pilot can see clearly that the glider is free. Under "Operational Regulations": 4.16 The sum of tows made by the tug pilot and the glider pilot, in their respective capacities, shall not be less than six. My own opinion is that if a forward aerotow hook is fitted it should always be used for aerotowing. If the glider does not have an aerotow hook, but can be fitted with one as a modification then this should be done if it is to be launched by aerotow. It is quite normal for tug pilots to refuse to launch a glider if the rope is on the aft hook when an aerotow hook is available. I cannot think of any circumstance when the use of the forward hook rather than the aft one for aerotow launching could cause a problem. The longer the rope the easier the flying is for the glider pilot (except perhaps in violent rotor?). The 150 ft rope is a compromise between safety and operational convenience which has been found to be satisfactory in practice in the U.K. The above BGA recommendations and my opinions are based on the assumption that the glider pilot has been properly trained and checked for currency etc. The requirements etc. are to be found in the BGA Instructors' Manual (which is not available to be read on-line). W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Bill Daniels" wrote in message hlink.net... snip There's a BGA write-up on CG hooks and pitch-up incidents that should be required reading for anyone contemplating airtow with a CG hook. Maybe one of our British friends can provide a link to it. Bill Daniels |
If I am well informed in Germany CG hooks are not allowed for airtow
anymore. The exception is that if your glider does not have a nose hook, you may use the CG hook provided that you can show that you made at least six airtows in the last three month prior to this occasion (or wordings like this). Karel, NL "Ian Strachan" schreef in bericht ... In article , Andy Durbin writes snip I have flown the last 15 or so years with aerotow on a cg hook. My new ASW-28 has forward and CG hooks but I have never used the forward hook. What you have been doing in your ASW-28 would not be allowed at Lasham and many other clubs (or if I were towing you!). If you have a forward hook (often called the air tow hook), at most gliding organisations with which I have been associated, you must use it for air tows except for well-controlled exercises to show the difference. A true CG hook position is for winch launching. Normally, if both hooks are fitted the rear one will be "really rear" because the manufacturer will assume that it will only be used for winch or auto-tow. What does it say in your flight manual? If only one hook is fitted then it will be somewhat forward of the pure "C of G" position because its location is a compromise for both air tow and winch and it will be tested for both before the initial C of A is given for the type. The reason not to use a CG hook for air tows if a front hook is available is not so much directional stability while on the ground, but the potentially much more dangerous "tug upset" which can, and has, killed tug pilots in the past. I think that the tug pitch-upset situation has been extensively covered before on this newsgroup. If the glider becomes high enough behind the tug, the tow pilot pulls back on the stick to counter the nose-down pitch and can run out of back-stick. The tug's tailplane (horizontal stabilizer) can then stall, leading to a sharp and uncontrollable steep nose-down pitch which, if near the ground (say 600 ft or less) is often fatal for the tug pilot. We have had such fatals in the UK at both Lasham, Dunstable and elsewhere, hence the universal use of nose hooks for air towing where such a hook is fitted to the glider. There was even a debate within the BGA after the last UK fatal tug upset, on whether gliders with only a CG hook should be allowed to be air towed at all. The upshot was the present situation combined with careful briefing and air tow practice concentrating on sitting close on top of the tug slipstream and never getting high. Tug pilots watch the rear-view mirror very carefully at and after takeoff and I am quite willing to dump anyone who gets really high, particularly close to the ground. Finally, on rope length I agree with Mike Borgelt. The longer the rope the easier an air tow is to fly in the glider. Last year I had a tow in Poland in a Puchatz at their Zar mountain soaring centre on a VERY short rope, and flying the tow was "very active". The field at Zar is a respectable length so I do not know why they insist on using such short ropes. The only reason for a short rope that I can think of is to tow out of a VERY short field, and in my view even that is questionable, if the field is THAT short it may not be safe to tow out of anyway. Finally, Lasham make up air tow ropes to be 50m long (164 ft). From memory, the BGA minimum tow rope length recommendation is 150 ft. Andy, I really suggest that you start using your air tow (front) hook when you take an air tow ! -- Ian Strachan Lasham Tow Pilot |
Ian Strachan wrote:
Andy, I really suggest that you start using your air tow (front) hook when you take an air tow ! I presume you can have an upset incident even with a nosehook. Are there any statistics that show the safety advantage of a nose hook compared to a CG hook? Greg Arnold 330 aerotows with CG hooks, and never any problems except when taking off without a wing runner |
Ian Strachan wrote in message
big snip, but all noted Andy, I really suggest that you start using your air tow (front) hook when you take an air tow ! I knew this would get a reply from someone. I am aware of the conditions of the LBA certification for the ASW 28 and also aware that BGA has prohibited, or discouraged, import of gliders that don't have a forward hook for aerotow. A Schleicher agent advised me not to buy the forward hook option. I chose to have it fitted because I didn't want any risk that FAA would grant an airworthiness certificate for aerotow. LBA certification prohibits the use of CG hook for aerotow but I don't believe my FAA experimental airworthiness certification has such a limitation. I use the ASW 28 cg hook for 2 reasons: 1. With over 1500 hours in the ASW 19 I am very familiar with aero tow with CG hooks. (the CG hook on both gliders is just forward of the main wheel inside the gear doors) 2. The forward hook is a poor design which is difficult to hook up and poorly sealed. Andy (GY) |
In article , Andy
Durbin writes snip LBA certification prohibits the use of CG hook for aerotow Does not that tell you something, then? 1. With over 1500 hours in the ASW 19 I am very familiar with aero tow with CG hooks. So I have no doubt also thought the glider pilots who got out of position and killed the tug pilot. Just do not come to my club and expect to tow on your aft hook, or anywhere where I am towing. I would have thought where life-and-death was concerned you could be a tad more humble about your undoubted handling abilities. But perhaps unlike the rest of us, you never have an off-day ...... -- Ian Strachan |
"W.J. (Bill) Dean (U.K.)." wrote in message ... | There is an article in the archives of Gliding & Motorgliding International | on Aerotow "Upset" Accidents by Chris Rollings which may be found at: | http://www.glidingmagazine.com/ListF...Dtl.asp?id=327 . | All tug pilots, and glider pilots who launch by aerotow, should read this | article. | | For the U.K. the B.G.A. give advice to be found in "Laws and Rules for | Glider Pilots" 14th edition June 2003 (cannot be read on-line): | | Under "Recommended Practices": | | RP12. The minimum length of aerowtow rope recommended is 150ft. However, | under special circumstances a short rope may be used. The operators' | attention is drawn to the following factors which may cumulatively | contribute to a hazardous situation: | | (a) Low experience of glider and/or tug pilot | (b) Gliders fitted with C of G hook only | (c) Glider's C of G towards the aft limit | (d) Turbulent air in the take-off area | (e) Rough ground in the take-off area | (f) Significant cross-wind component. | | RP13. After releasing the cable, the glider should turn away so that the | tug aircraft pilot can see clearly that the glider is free. | | Under "Operational Regulations": | | 4.16 The sum of tows made by the tug pilot and the glider pilot, in their | respective capacities, shall not be less than six. | | My own opinion is that if a forward aerotow hook is fitted it should always | be used for aerotowing. If the glider does not have an aerotow hook, but | can be fitted with one as a modification then this should be done if it is | to be launched by aerotow. | | It is quite normal for tug pilots to refuse to launch a glider if the rope | is on the aft hook when an aerotow hook is available. | | I cannot think of any circumstance when the use of the forward hook rather | than the aft one for aerotow launching could cause a problem. | | The longer the rope the easier the flying is for the glider pilot (except | perhaps in violent rotor?). The 150 ft rope is a compromise between safety | and operational convenience which has been found to be satisfactory in | practice in the U.K. | | The above BGA recommendations and my opinions are based on the assumption | that the glider pilot has been properly trained and checked for currency | etc. The requirements etc. are to be found in the BGA Instructors' Manual | (which is not available to be read on-line). | | W.J. (Bill) Dean (U.K.). | Remove "ic" to reply. In Australia, all new gliders and any gliders which change ownership must be fitted with a nose hook if aero tow is to be used. C of A not valid otherwise. John G. |
Andy Durbin wrote:
I use the ASW 28 cg hook for 2 reasons: 1. With over 1500 hours in the ASW 19 I am very familiar with aero tow with CG hooks. (the CG hook on both gliders is just forward of the main wheel inside the gear doors) I also had 1000+ hours on my ASW 20 CG hook (and another 600 on other gliders) when I had a forward hook installed. 2. The forward hook is a poor design which is difficult to hook up True, but I noticed each line person knew how to do it the second time they hooked me up, and no one complained. and poorly sealed. Not that bad, but I did spend an hour one day sealing against air instrusion (for winter flying) when I had the seat pan out for an annual. Why go to any trouble at all? I found the forward hook (about 1 to 2 feet back from the nose) was better in a crosswind, better if the wing runner was clumsy, better if I got distracted on tow, better in rough air, and I never ran over the tow rope, which happened once in a while with the CG hook. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
the easier an air tow is to fly in the glider. Last year I had a tow in Poland in a Puchatz at their Zar mountain soaring centre on a VERY short rope, and flying the tow was "very active". The field at Zar is a respectable length so I do not know why they insist on using such short ropes. The only reason for a short rope that I can think of is to tow out of a VERY short field, and in my view even that is questionable, if the field is THAT short it may not be safe to tow out of anyway. Finally, Lasham make up air tow ropes to be 50m long (164 ft). From memory, the BGA minimum tow rope length recommendation is 150 ft. I, too, have been towed by a short rope (10M!) in Poland; but only out of a dirt field. Mind you, getting towed out of a soft dirt field is, by itself, a new experience (in the States we would say "go get your trailer", but in Poland, do as the Poles do. The tow pilot, who spoke very little English, said "Rope OK?". I figured the guy had to have his reasons, hopefully not to make me look silly, so I said: "Rope OK". A short rope on a runway would be intimidating enough, but we are talking about a soft plowed field! With the help of a bunch of Polish children (they showed up every time I landed out) I positioned the glider (Jantar Std III) on the hardest furrow in the field. After some instruction by the tow pilot to the oldest child on how to hold the wing (one hand in the back pocket) we were ready to go. The tow plane was a 9 cylinder radial tail dragger Yak (lots of power!). The first thing that happened was that one of the amin gear dug in, causing the tow plane to veer that direction. Of course, I followed (so much for the hard furrow theory. Then the other wheel would dug in and we would go that direction. This ment that I would bounce over from furrow to furrow. At the same time, my gear would dug in, increasing tow tension until the gear pulled out. This would pull me violently unto my nose, which would cause me to bounce back onto the tail, which would bounce me back onto the nose and back onto the tail. At the same time one of the wing tips would drag into the dirt. At least 10 times I told myself this was just too intolerable and I should release; but each time I said (to myslef) I would hang on for just one more second, and if it didn't improve then I would release. Throughout this whole experience our speed was increasing, which was both good and bad. Good: we needed speed to fly. Bad: the jolts got more violent. Finally, I saw the tow plane go airborne. This was great except for one thing: I was still on the ground! Hanging on, I felt my main clear the dirt. But I could hear (yes, hear), the tail dragging through the ground. Then the noise stopped: I was airborne! Once airborne you might think that your troubles were over: wrong! At that distance you can see ever rivet of the tow plane. You are totally concentrating on following every little movement of the tow plane, especially the wing waggle (tow release). Because after they waggle their wings they do a split-S to go after the next glider! Sure enough, he waggled his wings and I released. Now, where is the airfield (it has to be close, doesn't it)? The airfield is a square km of grass, which happens to look like every other farm in the area! I started looking for another field to land in. Then I spotted the airfield, to my great relief. BTW, why the short rope? Simple: on take off I always had clear visibility; if the long rope had been used the dust from the prop wash would have made me IFR. |
ASW 27B is only certificated for aerotow operation when the forward tow
release is used! |
ASW 27 flight manual 4.4.1.2. states,THE SAILPLANE IS ONLY CERTIFICATED FOR=20
AEROTOW OPERATION WHEN THE FORWARD TOW RELEASE IS USED, now i know we all us= ed=20 to tow from belly hooks years ago, but think on , if you aerotow from the c/= g=20 hook on ASWs with forward hooks you are flying an uncertified glider and may= be=20 not be insured, big risk for a =A350,000 glider,and what about the tug pilot= ! |
| Tow Hook on Cessna 180 - Update | Stuart Grant | Soaring | 13 | April 10th 20 11:48 AM |
| Aero Advantage closing shop. | Eric Ulner | Owning | 51 | May 17th 04 04:56 AM |
| Tow Hook on Cessna 180? | Stuart Grant | Soaring | 3 | October 2nd 03 01:50 AM |
| Cambridge Aero Instruments Inc. Changeover | Joe McCormack | Soaring | 3 | July 30th 03 09:45 PM |
| CG hook & Low Tow | Ray Lovinggood | Soaring | 2 | July 25th 03 07:20 AM |
