How can I make new P-Leads?
Old October 6th 04, 01:59 AM
Justin H
Default How can I make new P-Leads?
I have some Bendix S4LN Mags and the P-Lead shielding is in bad condition
and I'm having noise problems. Can they be bought prebuilt or do I have to
buy wire and connectors and crimpers. Ive searched aircraft spruce and such,
I guess they dont sell it or im searching the wrong thing.
Old October 6th 04, 02:07 AM
jls
"Justin H" wrote in message
such,
The ends can be purchased from API and McFarlane. You solder a bead on the
mag ends, then sand the bead flat. Not hard to do but you need good
shielded wire which is available through Spruce or other sources. The
cable I used also had a teflon cover over the shielding. I could not find
cable as thick as the original on a 172. The A&P said that was a typical
problem but that the cable available was of a sufficient gauge.
So far, so good. I test the p-leads occasionally by turning the switch to
'off' when the engine is idling.
Old October 6th 04, 05:11 AM
Orval Fairbairn
such,
Even Radio Shack has shielded wire that will work. There is little
amperage through the P-leads. All they do is ground the mag coil.
Old October 6th 04, 07:17 AM
Roger Halstead
On Tue, 5 Oct 2004 21:07:28 -0400, " jls"
such,
If you're real quick you can turn them back on and clean any
restrictions out of the mufflers at the same time. you know, things
like flame cones?
www.rogerhalstead.com
