50+:1 15m sailplanes
Old January 12th 04, 12:14 AM
Andreas Maurer
On Mon, 12 Jan 2004 07:46:52 +1000, Mike Borgelt
Take a look at the movie clip of the Silent IN with the Jet engines. I
ran some numbers on the engines over the weekend and I'm convinced
I've seen the future of soaring.
Search for a glider called "Huetter 30 TS"... (look here, for example:
http://vintagesailplanes.de/Huetter30TS.htm). First flight was in
1960.
It later became the Libelle and Salto... but it failed miserably with
the turbine engine although it was a very good glider. Noise, fuel
consumption and bad climb rates were the killer factors.
Bye
Andreas
  #63
Old January 12th 04, 12:58 AM
Doug Taylor
Kirk,
Where do you fly from? I am trying to make some plans for travelling
with my SparrowHawk over the next few months. I am hoping to show the
SparrowHawk to as many people as want to see it, and hopefully convert
a few "non-believers". I would be very happy to have the opportunity
to show it to you and other people that would be interested in seeing
it. For a few qualified individuals there might even be the
opportunity to fly it.
Until you see it and feel it, I can understand how hard it is for
people to grasp just what kind of accomplishment this glider is. 155
pounds!? Ridiculous! That is if you are not familiar with the
materials. The carbon pre-preg and the adhesives used to bond the
plane together are totally different and more than twice as strong as
what is typically used to build sailplanes. We joke about how we
could take our rudder and use it to chop up every other glider on the
field. This really isn't far from truth. One used as a display
sample by the manufacturer of the pre-preg has been through the
airlines baggage handling system without the benefit of a box. If
anything can survive that....!
Is it possible to break it? Of course. One SparrowHawk did suffer
some damage to its landing gear while landing out last summer, however
the pilot reported that it is one heck of a strong airplane and the
tailboom would likely have broken on any of his other sailplanes.
Mine has been landed out a couple of times and it has flown off of
some fairly rough strips as well as suffering some of my landings.
All it has to show for this are some paint scratches. No dents or
cracks. Structural testing has been done to the wings, vertical tail,
horzontal tail, seat, fuselage and tow hook, as well as the control
system.
As far as performance goes, like one SparrowHawk owner said, on an
average day, flown by average pilots in an average way, it doesn't
really give up anything. Some trade-offs were made to make it a very
easy glider to fly for less experienced pilots (every CFIG who has
flown it has said it would be a good first single seater). Stalls
including fully cross controlled with the stick held full aft through
a number of cycles are a non-event. Control response and harmony is
excellent down to very low speeds making take-off and landing very
easy. So what is the trade-off? Up to about 60 knots, there isn't
really any. Above that, most of the newer 15M gliders do have a
performance advantage. That doesn't mean that the SparrowHawk falls
out of the sky though. At 80 knots it is still getting around 20:1
L. It has flown a 300 km triangle with a 25 knot wind blowing and
averaged 52 mph.
I realise that this is all talk until you actually see it, that is why
I would like to have the opportunity to show the plane to as many
people as possible over the next few months. Anyone who would like to
see it, please let me know.
Best regards,
Doug Taylor
ps. I am not an employee of Windward Performance, although I did help
out on the construction of tooling and the first few SparrowHawks. I
am just trying to help spread the word because I believe this is one
fantastic machine!
(Kirk Stant) wrote in message
No, unfortunately I havn't, so my opinion is worth precisely what you
paid for it! I am obviously making an assumption, and I hope I'm
proven wrong, by the way, as the Sparrowhawk looks like a nice little
glider, but my real concern is triggered by the emphasis on the
"ultralight" aspect, which obviously drives the 155lb (!) weight of
the glider - I can't help but wonder where the weight has been saved.
By the VNE and G limits, it seems to have faily strong wings, so I'm
guessing the fuselage is a real eggshell...
And I truly hope that an "ultralight" Sparrowhawk (i.e. no N number)
never shows up in the hands of an untrained, unlicenced non-pilot,
because I think that is a sure way to kill or injure someone, real
quick!
Has anyone out there actually touched and/or flown a Sparrowhawk? How
about an eyewitness report - I havn't eaten any crow in a while...
Kirk
  #64
Old January 12th 04, 04:24 AM
Mike Borgelt
On 11 Jan 2004 14:39:20 -0700, (Mark James Boyd)
Mike Borgelt wrote:
On Sun, 11 Jan 2004 09:40:25 -0800, Eric Greenwell
I'm waiting until they have a chance to put that motor in the SparrowHawk...
Mike Borgelt
I've come to much the same conclusion as Mike. I'd use a single
more powerful turbine (maybe the 1500) instead of 2, but
the numbers seem to work for even fairly short fields.
The heat on the tail scares me though. Hmmm...how do we
get rid of the glider tail?
The guys with the Silent don't seem to have a problem with the heat on
the tail - the two AMT 450 turbines seem to be mounted parallel to the
centerline. If this still worries you a V tail as on HP gliders or the
Salto is the easy answer.
I first thought of using the AMT1500 but when you do the numbers two
AMT450s (and soon the XP versions with about 10% more thrust) are
quite adequate for a 400kg glider. 50 feet at 500m takeoff run under
standard day sea level conditions seems doable, over 500 fpm rate of
climb at about 90 knots, single engine out climb of close to 200fpm at
70 knots. It makes a pretty good sustainer. (A real "turbo"!) Fuel
consumption on one engine is about 0.5kg/min , two is 1kg/min. Given
that a 2000 foot launch will only take about 4 minutes it is about as
fuel efficient as a launch behind a Pawnee.
Imagine self launcher with engine out capability and a decent climb
speed where you have significant energy for manouever even if both
engines fail!
Don't worry about ducting - extend the engine(s) on a short pylon.
They weigh so little and don't vibrate that this will be a very
lightweight structure, easy to extend and retract, solves any local
structural heat problems and the hole in the glider is so small, that
there will be minimal structural reinforcement required. The AMT 450
is 5.1" diameter and 10.7" long and weighs about 2.4kg (5 pounds or
so).
Great for motorising motorless gliders as the weight in the fuselage
is minimal. Convert part of the water tanks/bags for jet
fuel.60Kg(75liters) will give you one hour.
Now look at a Sparrowhawk
70kg empty
add say 10 kg for 1 x AMT450XP pylon and structural reinforcing
30 kg for 1 hours fuel.
add typical say 100 kg for pilot and chute etc
Only 210Kg!
One AMT 450 will self launch this adequately.
Two smaller engines may still be optimum for slightly increased thrust
and engine out capability.
Hope the Windward Performance guys have a plan to increase production
because if this works they might be swamped by customers.
These small turbines are still being developed - they will get better.
Engine pressure ratios are still only 4:1 or so, fuel consumption can
be improved.
Mike Borgelt
  #65
Old January 12th 04, 05:15 AM
Mark James Boyd
I've never seen a turbine airplane design that allows the hot exhaust
to reach a control surface of the aircraft. The fact that the Silent
flew a few times in this configuration is not convincing to me.
If the owner would put it on a stand in a hangar and
run it for an hour with his face right in front of the rudder/stab,
I'd change my tune. I don't have any hard facts or figures,
but my intuition sets off some warning flags here...
The larger engine isn't for more thrust than two engines, but
just for the lower complexity of using one engine. Two engines are
best used in aircraft with high wing loading that carry
passengers through turbulence. Two engines in a light-wing
loaded aircraft is just unneccesary, IMHO. Engine failure is
a non-issue due to the glide ratio, and the reliability of turbines.
The added weight, wiring, two starters, fuel lines, etc. seem
silly if a single turbine can be used instead.
Figuring out how to manage fuel from two tanks is a minor
complexity, and being able to dump fuel should ensure
one doesn't fly "chinese style" (won weeng lo).
It does seem using the fuel as ballast is an excellent feature,
but I'd want to really think hard about fire dangers.
Perhaps use less flammable fuel? I guess there is quite a
variety of fuel choices available...
More power than adequate = better. One can always throttle
back for fuel savings. I suspect the designers used two
engines instead of one because the 1500 may not be readily tested/
available rather than due to the need for redundancy. Again,
I've flown some twins and they have their uses; a powered glider
isn't a good match for two turbine powerplants
(just overkill/expense)...
The Sparrowhawk may be ideal for this application, but other
light gliders also have comparable potential. And I personally
would want to see a competitor which could taxi well.
A self-launch glider which has trouble taxiing is less
interesting to me personally than something more flexible.
Besides, the noise may get one banned from the gliderport and forced
to use a gasp towered airport... ;P
  #66
Old January 12th 04, 09:44 AM
Mike Borgelt
On 11 Jan 2004 22:15:26 -0700, (Mark James Boyd)
(Mark James Boyd)
A few of us were brainstorming this this afternoon and we think that
mounting the turbines in the inside of the swing out doors solves this
completely. One engine ends up over each wing root. These things are
installed in R/C models so the heat issues are obviously manageable.
You can easily then cant then out a little if you want. Problem
solved(and a good argument for two engines)
Given you will have only an electric fuel pump you are going to want
two anyway even for one engine. You already have two fuel tanks. You
might want two batteries as well to be sure of getting a start when
about to land out. Each of two smaller engines is lighter and simpler
to swing out than one larger one.
This looks one one of those issues where the "obvious" solution isn't
so obvious on reflection. The cost of the engines seems to scale
roughly with thrust so it is dollars per Newton you pay for.
The smaller engines also have thousands of hours operating history
which is worth a lot. And I *love* the idea of engine out capability
plus with two you really aren't going to fail to get at least one
running to avoid an outlanding.
I figured on one tank in each wing anyway and jet fuel is much less
flammable than gasoline anyway.
Climb to 1000 feet or so and shut one down, then go find a thermal.
Yes and the redundancy is really nice to have. If the glider was not
capable of climbing on one I'd agree with you that one engine is
desirable but what is the point of designing around an engine that
isn't readily available with lots of operating history? The packaging
of two is also easier.
Think about it some more and look at the prices. I didn't think jet
gliders were at all viable until I ran the numbers.
I've seen and heard the R/C model jets fly. They aren't that noisy at
all. Two smaller engines over the wingroots actually shields the
people on the ground from much of the noise.
Taxiing is still going to be problematical but then very few existing
self launchers taxi well(as opposed to Stemme's, Katanas etc and even
they would have trouble at our airport.
I've got some time in the Jet Caproni about 20 years ago and I wasn't
that impressed. When I last flew in it 10 years ago the owner had
figured it out and it was good. We are talking the same sort of thrust
weight for a 400Kg glider(most 15/18m gliders) with two AMT 450's.
As for complexity of two jet engines compare with a horrible, heavy,
noisy vibrating two stroke with reduction drive and propeller, complex
and heavy extend /retract mechanism, heat issues if the engine is
buried in the fuselage and complex operating procedures with very
limited climb speed range. Look at the prices being charged for these
contraptions.
Mike Borgelt
  #67
Old January 12th 04, 02:36 PM
Kirk Stant
(Doug Taylor) wrote in message om...
Kirk,
Doug, thanks for the excellent response. I fly out of Turf Soaring,
near Phoenix Arizona - and would love the opportunity to see the
Sparrowhawk in action. I'll admit I'm a bit of a sceptic, but from
the reasoned responses from several of you out there it sounds like it
is a nice little glider.
I just wish the whole "ultralight" aspect would go away - that still
scares me. It may be a pretty moot point - I doubt anyone could show
up in an unregistered glider and get a tow at any glider operation I
know of!
One question: how do you buy a factory-built Sparrowhawk and register
it if it isn't certified yet? Or did I miss something. Just curious.
So come on out to Turf and show your stuff - on any weekend there will
be plenty of glass to keep you company on some XC or racing, and a
nice airconditioned clubhouse with cold beer and chicks waiting after
the flight (see Pez, he got it just about right, if you stay you will
have to race!).
Kirk
  #68
Old January 12th 04, 04:41 PM
Mark James Boyd
contraptions.
Compared to a two-stroke, four jet engines is an improvement.
But again, IMHO, one jet engine of the same power is better than
more engines in light wing-loaded aircraft. The complexity of
pilot management, and the extra workload to manage the feeding and
maintenance is the downside. And redundancy is, I believe,
notional. I'd rather run out of gas and then switch to a full
tank than run out of gas on one engine and then, a few seconds
later, run out of gas on the other side.
I hope we can agree as gentlemen to disagree on this one...
I'm strongly in favor of a single turbine engine for this
application.
I just don't know how large the heat cones are out of these engines, so
I can't really agree or disagree...I don't think I can solve this
one from an armchair...
Out of gas is out of gas, period. Turbines get more reliable as they
get larger, and are lots more reliable than anything with a prop.
The reliability card simply has negligible meaning in this context.
And again, the cost isn't the acquisition or fuel costs, it's
continuing cost...
The fuel is slightly less flammable but the heat danger is much
greater than a pure glider (of course). My point is just that
if one has a choice, maybe use the least flammable fuel? You
can still fill up with Jet A if needed...
And I'm also emphasizing that I think the fire risk is really
something to pay attention to and minimize by design...
Completely true. If we MUST use two because of
marketing/availability/testing reasons
then fine. Two in the hand is better than none in the bush. But
accepting a sub-optimal design instead of making some extra phone
calls means somebody else is gonna compete with you later, at
a better price offering reduced maintenance/complexity...
The packaging
Boy I gotta strongly disagree with that.
Installing, testing, wiring, instrumenting, fueling,
operating, shutting down, diagnosing in flight, etc.
for two engines is wholly different than one.
There's a reason 727s have three crewmembers instead of one,
and it isn't because of the complexity of the passengers
or so the Captain can take a nap...
My comment about noise meaning you may get banned from the gliderport
was tongue in cheek. Here's the that should have been there...
Mike Borgelt
Yes, I'd very much like to see taxi capability. A short wingspan and
light weight like a Sparrowhawk is excellent for this turbine.
The extra stuff to make it taxi well would sell it to the
biggest market, "power pilots," with the best success.
Mark Boyd
  #69
Old January 12th 04, 04:58 PM
Eric Greenwell
contraptions.
Typical self-launchers are rpm limited to about 70-75 knot cruise, which
is painfully slow when flying into a 30-40 knot headwind while trying to
reach a wave. As a result, I often don't attempt to fly our best winter
waves, since it'd an hour+ to reach them. Being able to cruise at 100+
knots would cut the transit time in half.
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
  #70
Old January 12th 04, 05:11 PM
Eric Greenwell
know of!
Don't they tow ultralights at Turf? You know, on the "other" side of the
airport? It doesn't take a 230 hp Pawnee to tow a 400 pound glider,
though it tows behind one just fine.
It was registered in the Experimetal class, just like your LS-6.
Eric Greenwell
Washington State
USA
sailplanes for sale Jerry Marshall Soaring 1 October 21st 03 03:51 AM
