I have been conducting some bench experiments with my Bohli taut-band
bellows with capillary leak vario to determine the system time constant. The set-up is a 0.45 liter glass vacuum flask attached to the vario with .5 meter of 3mm Tygon tubing with a 1cc syringe teed into the tubing at the flask. The static/TE port on the vario is left open to the atmosphere. By injecting 1cc of air into the flask, I simulate a sharp edged thermal encounter. This causes the vario reading to instantly jump to about 5 meters per second up and then decay to zero. I am starting a timer at various points on the scale as the needle falls and timing the decay to half that value. (For example, start timer at 4 MPS and stop at 2 MPS) I am consistently getting 7 seconds for this decay interval. The Sage web site suggest the test should be for the decay to 37% of the initial value. Using 37%, the decay interval is 11 seconds. Sage claims 1 second decay. Repeating the 50% test on a 5MPS vane-in-torus type vario resulted in values of only 2.5 seconds. The decay values for the Bohli vario seem large to me. I am starting to suspect that the 0.45 capacity is far too large for the size of the capillary in the Bohli. Is this type of experiment of any real value? Any comments? Bill Daniels |
"Bill Daniels" wrote in message ... I have been conducting some bench experiments with my Bohli taut-band bellows with capillary leak vario to determine the system time constant. The set-up is a 0.45 liter glass vacuum flask attached to the vario with ..5 meter of 3mm Tygon tubing with a 1cc syringe teed into the tubing at the flask. The static/TE port on the vario is left open to the atmosphere. By injecting 1cc of air into the flask, I simulate a sharp edged thermal encounter. This causes the vario reading to instantly jump to about 5 meters per second up and then decay to zero. I am starting a timer at various points on the scale as the needle falls and timing the decay to half that value. (For example, start timer at 4 MPS and stop at 2 MPS) I am consistently getting 7 seconds for this decay interval. The Sage web site suggest the test should be for the decay to 37% of the initial value. Using 37%, the decay interval is 11 seconds. Sage claims 1 second decay. Repeating the 50% test on a 5MPS vane-in-torus type vario resulted in values of only 2.5 seconds. The decay values for the Bohli vario seem large to me. I am starting to suspect that the 0.45 capacity is far too large for the size of the capillary in the Bohli. Is this type of experiment of any real value? Any comments? Bill Daniels Since I can't edit a previous message, I'm just replying to myself. I decided that the experiment needed some improvements so I connected the syringe to the TE side of the vario along with a 1 liter vacuum flask and a helicopter airspeed indicator that reads in one knot increments. This allowed me to closely control the pressure change on the TE side and more accurately simulate flight conditions. Setup: Capacity side = .45 Liter glass vacuum bottle TE side = 1.0 liter glass vacuum bottle with syringe and ASI connected by "T" fittings in the tubing. I injected an amount of air corresponding to 30 knots on the airspeed and adjusted the syringe to keep it there. (Essentially a instant step change in the pressure.) This resulted in just about full scale down (6Knots) on the vario. Timing the decay from 5kts to 1.85 Kts (Tau or 37% of 5 Kts.) gets 7 seconds. This is a bit faster than the 7 seconds to 50% decay previously but still too long for my taste. To test the scalar accuracy, I replaced the ASI with a known-good 0-2000 FPM rate of climb indicator and withdrew air from the TE side so as to hold a constant 5 meters per second up on the vario until I had a steady reading on the ROC. That reading was 1200 Feet per minute or just over 6 MPS. The vario seems to be under stating the rate of climb by 20%. Bill Daniels |
On Thu, 15 Jan 2004 13:13:39 -0700, "Bill Daniels"
wrote: "Bill Daniels" wrote in message ... I have been conducting some bench experiments with my Bohli taut-band bellows with capillary leak vario to determine the system time constant. The set-up is a 0.45 liter glass vacuum flask attached to the vario with .5 meter of 3mm Tygon tubing with a 1cc syringe teed into the tubing at the flask. The static/TE port on the vario is left open to the atmosphere. By injecting 1cc of air into the flask, I simulate a sharp edged thermal encounter. This causes the vario reading to instantly jump to about 5 meters per second up and then decay to zero. I am starting a timer at various points on the scale as the needle falls and timing the decay to half that value. (For example, start timer at 4 MPS and stop at 2 MPS) I am consistently getting 7 seconds for this decay interval. The Sage web site suggest the test should be for the decay to 37% of the initial value. Using 37%, the decay interval is 11 seconds. Sage claims 1 second decay. Repeating the 50% test on a 5MPS vane-in-torus type vario resulted in values of only 2.5 seconds. The decay values for the Bohli vario seem large to me. I am starting to suspect that the 0.45 capacity is far too large for the size of the capillary in the Bohli. Is this type of experiment of any real value? Any comments? Bill Daniels Since I can't edit a previous message, I'm just replying to myself. I decided that the experiment needed some improvements so I connected the syringe to the TE side of the vario along with a 1 liter vacuum flask and a helicopter airspeed indicator that reads in one knot increments. This allowed me to closely control the pressure change on the TE side and more accurately simulate flight conditions. Setup: Capacity side = .45 Liter glass vacuum bottle TE side = 1.0 liter glass vacuum bottle with syringe and ASI connected by "T" fittings in the tubing. I injected an amount of air corresponding to 30 knots on the airspeed and adjusted the syringe to keep it there. (Essentially a instant step change in the pressure.) This resulted in just about full scale down (6Knots) on the vario. Timing the decay from 5kts to 1.85 Kts (Tau or 37% of 5 Kts.) gets 7 seconds. This is a bit faster than the 7 seconds to 50% decay previously but still too long for my taste. To test the scalar accuracy, I replaced the ASI with a known-good 0-2000 FPM rate of climb indicator and withdrew air from the TE side so as to hold a constant 5 meters per second up on the vario until I had a steady reading on the ROC. That reading was 1200 Feet per minute or just over 6 MPS. The vario seems to be under stating the rate of climb by 20%. Bill Daniels Bill, I tested a Bohli about 16 years ago and got similar results to you. It did seem quite slow. Now whatever has happened to r.a.s.? Real data with real apparatus and no arm waving?????? Mike Borgelt |
"Mike Borgelt" wrote in message news ![]() On Thu, 15 Jan 2004 13:13:39 -0700, "Bill Daniels" wrote: "Bill Daniels" wrote in message ... I have been conducting some bench experiments with my Bohli taut-band bellows with capillary leak vario to determine the system time constant. The set-up is a 0.45 liter glass vacuum flask attached to the vario with .5 meter of 3mm Tygon tubing with a 1cc syringe teed into the tubing at the flask. The static/TE port on the vario is left open to the atmosphere. By injecting 1cc of air into the flask, I simulate a sharp edged thermal encounter. This causes the vario reading to instantly jump to about 5 meters per second up and then decay to zero. I am starting a timer at various points on the scale as the needle falls and timing the decay to half that value. (For example, start timer at 4 MPS and stop at 2 MPS) I am consistently getting 7 seconds for this decay interval. The Sage web site suggest the test should be for the decay to 37% of the initial value. Using 37%, the decay interval is 11 seconds. Sage claims 1 second decay. Repeating the 50% test on a 5MPS vane-in-torus type vario resulted in values of only 2.5 seconds. The decay values for the Bohli vario seem large to me. I am starting to suspect that the 0.45 capacity is far too large for the size of the capillary in the Bohli. Is this type of experiment of any real value? Any comments? Bill Daniels Since I can't edit a previous message, I'm just replying to myself. I decided that the experiment needed some improvements so I connected the syringe to the TE side of the vario along with a 1 liter vacuum flask and a helicopter airspeed indicator that reads in one knot increments. This allowed me to closely control the pressure change on the TE side and more accurately simulate flight conditions. Setup: Capacity side = .45 Liter glass vacuum bottle TE side = 1.0 liter glass vacuum bottle with syringe and ASI connected by "T" fittings in the tubing. I injected an amount of air corresponding to 30 knots on the airspeed and adjusted the syringe to keep it there. (Essentially a instant step change in the pressure.) This resulted in just about full scale down (6Knots) on the vario. Timing the decay from 5kts to 1.85 Kts (Tau or 37% of 5 Kts.) gets 7 seconds. This is a bit faster than the 7 seconds to 50% decay previously but still too long for my taste. To test the scalar accuracy, I replaced the ASI with a known-good 0-2000 FPM rate of climb indicator and withdrew air from the TE side so as to hold a constant 5 meters per second up on the vario until I had a steady reading on the ROC. That reading was 1200 Feet per minute or just over 6 MPS. The vario seems to be under stating the rate of climb by 20%. Bill Daniels Bill, I tested a Bohli about 16 years ago and got similar results to you. It did seem quite slow. Now whatever has happened to r.a.s.? Real data with real apparatus and no arm waving?????? Mike Borgelt To be fair to the Bohli, I don't think my "desktop instrument lab" is all that accurate. There are several possible explanations for the slow response other than the instrument itself - instrument interactions for example. I'd need a full instrument test bench to do it right. Still, I have a B40 on order to replace it. I just don't think bellows with capillary-leak varios are in the same league as altitude derivative units. Bill Daniels |
| American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 11:46 PM |
| Good Instructors... | doc | Piloting | 52 | December 5th 04 10:20 PM |
| Logging Time Consistently - Hobbs AND Tach | Carl Orton | Piloting | 11 | June 29th 04 10:52 PM |
| FS: 1990 Cracker Jack "War Time Airplanes" Minis 6-Card (CJR-3) Set | J.R. Sinclair | Aviation Marketplace | 0 | April 12th 04 06:57 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
