Fellow r.a.s.'ers:
Tell me about the Lark. I don't yet know which model, but I hear that our club is about to acquire one. Should I be ecstatic, or concerned? Jack |
Lark.. IS28B2.. heavy metal.. has a calendar life limit but possible to
extend beyond with inspections and parts replacements.. don't know the details.. heavy to move around on ground.. if you are on grass.. hard to manually move flies great.. BT "Jack" wrote in message ... Fellow r.a.s.'ers: Tell me about the Lark. I don't yet know which model, but I hear that our club is about to acquire one. Should I be ecstatic, or concerned? Jack |
"Jack" wrote in message ... Fellow r.a.s.'ers: Tell me about the Lark. I don't yet know which model, but I hear that our club is about to acquire one. Should I be ecstatic, or concerned? Jack The following assumes your club is getting an IS28 b2. I owned an IS28 b2 Lark (two seater) for several years. It was a fine glider. I found it would soar with the best of the 17 meter glass two seaters and out-run all of them. The negative flaps really work well at high speeds. I could circle at 45 knots and 54 degree bank at gross weight using 5 or 10 degrees of positive flap. Mine was equipped with 50 pounds of oxygen gear but still had 390 pounds of useful load. It was intended as an advanced trainer so better than average flying skills are required. On the other hand, I felt totally prepared for my first flight in a Nimbus. The Lark makes a fantastic transition trainer for fast glass. 10 hours in it and you should be able to fly any glider. Larks come with the same air/oil main gear strut that Blaniks use. The Lark just uses more gas pressure because it is heavier. If the strut hasn't been rebuilt in a long time, it's likely that the oil has mostly leaked out and the strut contains mostly nitrogen from many top-offs. This can make the strut really bouncy. It still works fine with tail first touchdowns but a botched wheel landing can produce some spectacular bounces. I found the directional control on rollout to be fantastic. I could steer it anywhere I wanted. The brake is a tiny Tost drum that is totally inadequate to stop a 1300 pound glider so plan on not aiming it at anything you want to keep. You will find some who will criticize the stall spin characteristics but I found mine to be totally honest. It would spin if abused but a strong pre-stall buffet (it would shake things off the Velcro) gave ample warning that you were approaching a stall. In a incipient spin entry the nose would start to swing as a wing dropped giving an unmistakable signal that a spin was starting. Releasing the backpressure stopped this instantly. The ailerons are heavy because they are very large, but you get a control stick the size of a baseball bat to operate them. Still, you'll need to develop some shoulder muscles. I was able to demonstrate a 45-45 roll in 4.5 seconds at an airspeed of 50 knots. You need to use full rudder to get a fast roll rate. I had several pilots criticize the rudder as inadequate but I could tell they were only using half the available travel by watching the rear pedals. The front cockpit pedals travel almost 10 inches so you REALLY have to use your feet to get full rudder. You'll have to work to get comfortable in the seats. There will be a need for an infinite range of cushions. Take very good care of the tail dolly and the lift tube that goes through the tail boom - you'll need them every time you want to move the glider on the ground. The tail is VERY heavy so plan on some help lifting it to fit the dolly. Get an aggressive maintenance program going and stick with it. The Lark demands some TLC so plan on it. Don't EVER fly it with a deflated strut - you will damage the fuselage structure at the gear box. Pay a lot of attention to the tires and inflation pressures. Have fun with it. Bill Daniels |
The IS28 "Lark" has East European spinning characteristics - think Puchacz.
One moment you are thermalling, or just turning, the next moment you are pointing at the ground and rotating, with seemingly no warning. Happened to a pupil when I was in the back seat at 700ft. right over the airfield, woke me up that did! W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Jack" wrote in message ... Fellow r.a.s.'ers: Tell me about the Lark. I don't yet know which model, but I hear that our club is about to acquire one. Should I be ecstatic, or concerned? Jack |
I have many hours in the IS-28B and I think it's one of the best 2 place
trainers around. I like it because it's affordable, and an honest 2 place, high performance trainer. It has semi-retractable landing gear so that when you land it gear up, there's no damage if you don't put it down too hard. I also like it because of it's spin characteristics. It's an honest spinning aircraft, meaning that if you aren't paying attention, it WILL fall into a spin on it's own, like a lot of high performance machines will. I think this is important in a transition trainer. Having a ship that will spin accidentally, and doesn't have to be forced into a spin, really teaches you what you need to know when moving up in performance. Because of the heavy tail on the Lark, make sure you are pointing in the direction that you want to be going as your speed drops below 20mph in the rollout. Once the tail drops, that's the direction you are going to go, and remember, there's not much break. The more positive flap you leave in, the longer the tail stays steerable. I usually land with the flaps in the number 2 position, 10 degrees positive. With them in the 15 degree position, the glide angle is pretty steep. I go to +15 on final to keep the landing speed slow and the tail light so that I can steer longer. I've found that most people tend to let the speed bleed off before they get low enough as they approach the flair. I think that with the flaps down and the long wings there is a huge cushioning effect as you approach the ground. Because of this, many people drop this plane in from about 10 feet and damage the undercarriage. They do this even after I warn them about it before hand. You must be very careful to teach pilots new to this aircraft to be sure and fly it ALL THE WAY DOWN TO THE FLAIR!!! When you're close to the ground and you get too slow, it just stops flying and drops to the ground. Make sure you aren't too high when this happens. Another thing to watch for is getting the tail too high while rolling, either on take off, or in most cases, during landing. If pilots are used to flying in an aircraft with a nose skid or wheel, it's easy to forget this and scrape the nose badly. The wings weigh a TON! The trailer that came with our ship is equipped with a bomb hoist at the wing root to assist with lifting the wing off the trailer. Don't plan on fetching this great bird out of a field very often. Keep the wing joints very clean and well lubed, it makes a big difference with the ease of assembly. These are really great ships, but they're not 2-33s. Like any higher performance ship, they require a higher level of skill to fly safely. Give new pilots a thorough training before letting them solo in it, and be careful, and you'll have lots of fun with your new acquisition. -- Gary Boggs 3650 Airport Dr. Hood River, Oregon, USA 97031-9613 "Bill Daniels" wrote in message ... "Jack" wrote in message ... Fellow r.a.s.'ers: Tell me about the Lark. I don't yet know which model, but I hear that our club is about to acquire one. Should I be ecstatic, or concerned? Jack |
This is exactly why I think the Lark is a good and honest transition trainer. Remember the 6 warning signs of a stall? 1. Stick back 2. Nose high 3. Low airspeed 4.Quiet 5.Mushy controls 6. Buffet When our Lark spins, there isn't a real strong buffet but the rest of the signs are definitely there and it's very important to learn them with an instructor before moving up in performance. Stall, spin accidents continue to be a big killer in our sport. 700' over the airport is no place to be learning about the 6 warning signs! Miss the first three or four in anything but a 2-33 and your friends and family may be very sad for a long time. Gary Boggs 3650 Airport Dr. Hood River, Oregon, USA 97031-9613 "W.J. (Bill) Dean (U.K.)." wrote in message ... The IS28 "Lark" has East European spinning characteristics - think Puchacz. One moment you are thermalling, or just turning, the next moment you are pointing at the ground and rotating, with seemingly no warning. Happened to a pupil when I was in the back seat at 700ft. right over the airfield, woke me up that did! W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Jack" wrote in message ... Fellow r.a.s.'ers: Tell me about the Lark. I don't yet know which model, but I hear that our club is about to acquire one. Should I be ecstatic, or concerned? Jack |
Ok, I'm a pedant (and no that doesn't mean I have an
unhealthy interest in kids!!). Maybe it's partly because I'm English. (It used to be our language)--but look Gary: A break is the process of getting something broken and flair is a natural aptitude or skill. The thing that slows you down is a brake and the thing you do to avoid flying into the ground is a flare. Rob At 05:36 19 January 2004, Gary Boggs wrote: remember, there's not much break. The more positive flap you leave in, the longer the tail stays steerable. I've found that most people tend to let the speed bleed off before they get low enough as they approach the flair. |
Oops, spell check won't help me there.
-- Gary Boggs 3650 Airport Dr. Hood River, Oregon, USA 97031-9613 "Robert John" wrote in message ... Ok, I'm a pedant (and no that doesn't mean I have an unhealthy interest in kids!!). Maybe it's partly because I'm English. (It used to be our language)--but look Gary: A break is the process of getting something broken and flair is a natural aptitude or skill. The thing that slows you down is a brake and the thing you do to avoid flying into the ground is a flare. Rob At 05:36 19 January 2004, Gary Boggs wrote: remember, there's not much break. The more positive flap you leave in, the longer the tail stays steerable. I've found that most people tend to let the speed bleed off before they get low enough as they approach the flair. |
| Interesting. Life history of John Lear (Bill's son) | Big John | Piloting | 7 | September 20th 04 06:24 PM |
| Interesting Resume (V Long) | Bob Chilcoat | Piloting | 24 | September 13th 04 07:44 AM |
| We flew the umbrella. RAF flew clamshell | ArtKramr | Military Aviation | 0 | July 22nd 04 05:14 PM |
| Okay, I posted a photo of the Lark | Badwater Bill | Home Built | 10 | February 2nd 04 07:41 PM |
| ?? Wasps flew Hurricanes and Spits?? | ArtKramr | Military Aviation | 0 | December 20th 03 02:05 PM |
