Vibration Testing
Old October 10th 04, 07:22 AM
smjmitchell
You are dreaming ...
Yes you can predict flutter speeds by measuring the variation of modal
damping with speed. This can be done using accelerometers mounted on the
structure and connected to appropriate signal processing hardware.
However this must be done in a carefully controlled flight test environment
on an aircraft fitted with with equipment to excite various vibration modes
(rotating mass and other types of exciters are used).
Not something you can just lash onto any airplane and so flying and have a
light that flashes on when flutter is immenent !!
"sidk" wrote in message
om...
Ernest, what the heck does "... fairly steady state and random,"
mean??
and just before flutter sets in the vibration begins
to diverge logritmically (I know that ain't spelt rite).
A circuit with a sort of squelch mode would be very useful, especially
during initial flight testing.
Or maybe better than a squelch threshold might be a LED bar-graph
showing relative magnitude..??
Sid Knox
Velocity N199RS
Starduster N666SK
KR2 N24TC
W7QJQ
Pilot log book and taxi testing Bob Olds Home Built 1 February 11th 04 03:32 PM
Pressure testing gone bad Mark Hickey Home Built 17 November 25th 03 02:29 AM
Looking for out of service main rotor blades for testing newro... James Lloyd Home Built 0 July 28th 03 10:27 PM
Looking for out of service main rotor blades for testing new rotor Wright1902Glider Home Built 9 July 28th 03 06:06 AM
Torsional Vibration Testing B2431 Home Built 8 July 25th 03 07:15 AM
