String in the middle does not protect you from a spin
Old January 28th 04, 05:22 PM
Default String in the middle does not protect you from a spin
I think the recent threads on spinning have been wonderful. I find
them a great help to focusing on such an important issue.
Somewhere in my dark student-pilot experiences I was shown that
coordinated flight, with the yaw string kept carefully in the middle,
does not guarantee against spin entry. As I recall, it was pointed
out to me that even with the string in the middle, in a steep turn the
inside wing is flying at a higher angle of attack than is the outer
wing. If a stall is induced in such a steep turn the inside wing is
likely to stall before the outside wing and thus will have higher drag
than the outer wing and the glider will likely fall off over the
inside wing. If confusion or inadequate skill or distraction get in
the way of an immediate recovery the higher drag of the inside,
falling wing may initiate an autorotation and possible spin entry.
Does this seem like a real possibility?
In any case, it instilled in me the knowledge that the yaw string is
not an indicator of the relative angles of attack on the two wings.
Old January 28th 04, 05:57 PM
Bill Daniels
"Jim" wrote in message
news
Your analysis is correct.
Dick Johnson makes a persuasive case for flying thermals with the yaw string
deflected slightly toward the high wing. Dick says this in not only safer,
it is aerodynamically more efficient.
Bill Daniels
Old January 28th 04, 11:03 PM
Henry Irvine
string deflected slightly toward the high wing. Dick says this in not
only safer, it is aerodynamically more efficient.
Bill Daniels
I would love to read that article, could you post a link please?
Henry Irvine
Those willing to give up a little liberty for a little security
deserve neither security nor liberty.
---- Benjamin Franklin
Old January 29th 04, 12:00 AM
Bill Daniels
"Henry Irvine" wrote in message
news
Bill Daniels
Henry Irvine
I didn't read an article, I just heard him say it at Hobbs.
Bill Daniels
Old January 29th 04, 01:37 PM
W.J. \(Bill\) Dean \(U.K.\).
Balanced flight (string in the middle) does not protect you from stalling or
a spin entry, but it helps. This is true both in straight flight and
turning flight.
Stalling is about angle of attack, above the critical angle you are stalled,
below it you are not. Whether you are in balanced or unbalanced flight
makes no difference to this.
Spinning and spin entry are stalled manoeuvres, unstalled and they cannot
happen, stalled and they may.
If you are just below the stalled angle of attack, then unbalanced flight
(slip or skid, string to one side) may stall part of the wing, so the glider
will stall.
If you are stalled and in unbalanced flight, then it is more likely that the
stall will become a spin entry.
Some types of glider will enter a spin even if stalled wings level in
balanced flight, whether this happens may be affected by C. of G. position;
different examples of the same type of glider may vary. Stalling in
balanced flight when turning is more likely to result in a spin entry than
when the wings are level.
Any turbulence, roughness, gustiness or gradient in the air will increase
the likelihood of stalling when close to the stall, and will increase the
likelihood of a spin entry when stalled.
Unbalanced flight makes it more difficult to sense and control the angle of
attack, especially when close to the stall. Unbalanced flight can conceal
the symptoms of the approaching stall.
Derek Piggott wrote (5th February 1994):
"I think lots of people still think that pro-spin controls means having a
lot of rudder or aileron on and don't realise that the important thing is
the stick position. If the stick is well back, spinable machines spin:
without the stick being back they don't spin."
In steady turning flight the stick will be further back for a particular
angle of attack compared with straight flight. The angle of attack with
the stick on the back stop in a steady turn will be lower than with the
stick on the back stop in straight flight. These statements are not true
when making a rapid entry into a turn.
The change in stick position in steady turning flight is due to circular
flow, as explained in "Understanding Gliding" by Derek Piggott, see chapter
2, use the index; the section is titled "Stalling in turns". However, note
the section titled "The function of the elevator" earlier in the same
chapter, note in particular where he says:
"In a tight turn, the nose may even be a little lower than the normal
cruising position but if the stick is being held well back near the end of
its range, the angle of attack _is_ large and the aircraft _is_ close to the
stall."
When instructors are being trained in the U.K., a standard demonstration
which every instructor must show is to get the glider to stall off a steep
turn. The K13 shows this very well, it departs abruptly into a steep spin
entry. Usually there is either only very subtle symptoms of what is about
to happen, or no symptoms at all; other of course from the position and
movement of the controls.
The best book I know for basic "theory of flight", an understanding of angle
of attack and the stall, and the importance of stick position and movement
is still "Stick and Rudder" by Wolfgang Langewiesche published 1944.
Fly safe, careful when you pull the stick!
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
news
Old January 29th 04, 03:06 PM
nafod40
turning flight.
Interesting problem. Reminds me of flying multi-engine noncenterline
with one engine out, where to keep the string in the middle you have to
fly with the ball to the side.
So (my swag analysis) if you are in a right hand turn, the forces on the
wings are as below, with the inner wing having more drag, because it is
slower and must fly at a higher AOA (gained through aileron deflection).
To counteract the forces now trying to rotate the aircraft, one must
toss in some rudder. To then keep from side slipping, one must fly in
what would feel like a skidded turn to balance all of the forces.
V H V
H
H
H
H
Does this make sense?
true dat.
Old January 29th 04, 03:44 PM
Nyal Williams
At 18:00 28 January 2004, Bill Daniels wrote:
'Jim' wrote in message
news
I find
issue.
shown that
in the middle,
it was pointed
in a steep turn the
than is the outer
the inside wing is
have higher drag
off over the
distraction get in
the inside,
spin entry.
the yaw string is
on the two wings.
with the yaw string
Bill Daniels
The yaw string is ahead of the line of the center of
lift along the wing. This line is on the true radius
of the turn. Any yaw string not directly on this line
will be deflected to some extent in a turn. The two
yaw strings on a two-seater will not show the same
deflection in a turn; the one in front will be deflected
further.
Old January 29th 04, 04:00 PM
CV
wing.
This is so, in theory, for a descending turn, and the other way around
for a climbing turn. In power flying we are taught that from a descending
turn you are more likely to spin in the direction of the turn and in the
opposite direction from a climbing turn. All this is based on there
being a certain amount of rotation around the longitudinal axis in
a descending/climbing turn.
A glider is of course always descending, in relation to the surrounding
air mass, thus creating the effect described, but at the glide angles
of modern gliders, as opposed to power planes, even in a steep turn,
I'd expect the effect to be very small, perhaps too small to make any
real difference (?), It would be interesting to hear whether anyone
has been able to observe this in practice.
And as somebody already pointed out somewhere in the spinning
thread, in a steepish turn you can often (depending on the type
of glider) fly with the stick on the back stop without ever
slowing down to stalling speed, making it next to impossible
to provoke this type of spin, even if possible in theory.
CV
Old January 29th 04, 04:18 PM
Chris OCallaghan
This possibility was brought up deep in the bowels of another spin
thread. It a said, in essence, that the yaw string can be straight in
a steep turn while the controls are crossed, to compensate for the
overbanking tendency. If you are able to stall the aircraft in this
condition, that may well lead to a spin. There are some mitigating
factors, but I could see how one would develop.
It will be at least 6 weeks before I can get out to experiment for
myself, so any western or southern pilots who feel up to some flight
testing, I'd be interested to hear your results. Be sure to let things
develop for several seconds after the stall break so we know exactly
what is going on. Insipient phases of spins and spiral dives are too
easy to confuse.
Jim wrote in message . ..
Old January 29th 04, 04:57 PM
Mark James Boyd
Bill Daniels
Henry Irvine
Carl Herold mentions "slips in turns" at
www.lvvsa.org/Training/LANDOUT-VER-2b.pdf
briefly, but the rest of the article is WELL worth a looksie
too...between Carl Herold, Dick Johnson, Jack Glendening, and
Judy Ruprecht, this sport has really got some juice and
some top-notch volunteers...
No US soldier should have 2 die for Israel 4 oil Ewe n0 who Military Aviation 1 April 9th 04 11:25 PM
No US soldier should have 2 die for Israel 4 oil Ewe n0 who Naval Aviation 0 April 7th 04 07:31 PM
Israeli Air Force to lose Middle East Air Superiority Capability to the Saudis in the near future Jack White Military Aviation 71 September 21st 03 02:58 PM
