Cleveland Parking Brake Parts
Old October 8th 04, 04:05 AM
Jeff
Default Cleveland Parking Brake Parts
I have a Cleveland parking brake line lock on my Dragonfly. The part number
is 60-5. It has developed a leak, the fluid is coming out of the body where
the actuator arm connects. I would assume there is an O-ring on either end
of the shaft that goes through the body, but I can not locate a parts
diagram for it. I do not want to take it apart until I am able to obtain
the new seals/O-rings/whatever to make the repair since it is a small leak
and it is not making a mess. Does anyone know where I can obtain the parts
to make the repair? A/S sells the 60-5, but does not list a parts diagram
like they do for the brakes and wheels. I looked for what seemed like hours
at www.parker.com, but that web site is a mess.
Thanks,
Jeff
Old October 9th 04, 01:32 AM
JDupre5762
Snip
to make the repair?
Cleveland gives away a parts book that covers most of its products. I have one
at the office but I won't be there again till Monday. Don't know if it is on
line.
John Dupre'
Old October 11th 04, 10:38 PM
JDupre5762
You need three MS28775-010 orings for the shaft. There are two other orings
for fittings and poppet valves. Those are MS28775-006 and -012. The poppet
valves might fall down into the shaft cavity when the shaft is removed.
John Dupre'
Goodyear Brake Pucks - Cheap! Ron Wanttaja Home Built 7 July 16th 04 06:45 AM
Building the Po' Boy Bending Brake Veeduber Home Built 14 March 1st 04 06:15 PM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Home Built 0 January 10th 04 02:20 AM
Brake caliper flange Stealth Pilot Home Built 5 July 7th 03 04:19 PM
Brake line design question Charlie Smith Home Built 0 July 2nd 03 12:31 PM
