I need a small ( approx 18" square ) panel cut for an experimental
sailplane. Can anybody suggest a good source? |
If you can send me a drawing (dimensioned sketch is OK) I can probably help you out. This is the sort of project that is a good learning tool fro my students. Anyone else who needs similar work please take note! Costs will be far less than sending it out to a commercial machine shop. Accurate is our forte. Fast is not, so plan far ahead! Errol Groff Instructor, Machine Tool Department H.H. Ellis Regional Technical School Danielson, CT 06239 860 774 8511 x1811 On Tue, 12 Oct 2004 19:41:28 GMT, "Bill Daniels" wrote: I need a small ( approx 18" square ) panel cut for an experimental sailplane. Can anybody suggest a good source? |
On Tue, 12 Oct 2004 19:41:28 GMT, Bill Daniels wrote:
I need a small ( approx 18" square ) panel cut for an experimental sailplane. Can anybody suggest a good source? Have a look at this web site: www.emachineshop.com I have not tried them yet, but the idea looks cool. |
Also consider having it water jetted. Like laser cut, but uses a high
pressure jet of water with abrasives in it. John |
"JohnT." wrote in message ... Also consider having it water jetted. Like laser cut, but uses a high pressure jet of water with abrasives in it. John At this point, I would consider anything. I've been talking to some of the dumbest phone sales people I can imagine. I've e-mailed the CAD file to 20 or so firms that advertise "custom panels" and, so far, no replies except for one local CNC shop that quoted $855 for the 9-hole 18" panel in .125" sheet. Bill Daniels |
"Bill Daniels" wrote ...
At this point, I would consider anything. I've been talking to some of the dumbest phone sales people I can imagine. I've e-mailed the CAD file to 20 or so firms that advertise "custom panels" and, so far, no replies except for one local CNC shop that quoted $855 for the 9-hole 18" panel in .125" sheet. This is a homebuilt group. Have you considered building it yourself? Rich |
"Richard Isakson" wrote in message ... "Bill Daniels" wrote ... At this point, I would consider anything. I've been talking to some of the dumbest phone sales people I can imagine. I've e-mailed the CAD file to 20 or so firms that advertise "custom panels" and, so far, no replies except for one local CNC shop that quoted $855 for the 9-hole 18" panel in ..125" sheet. This is a homebuilt group. Have you considered building it yourself? Rich Yes. I have made several panels but the CNC or laser cut panels are so much higher quality than what I can make with a bandsaw, drill press and sander. Bill Daniels |
I was wondering the same thing myself , a panel is not hard to make at all.
If you have built an airplane the panel should be about the easiest part. Are you planning on building this panel out of a special material? If it's metal I would do it myself. Patrick "Richard Isakson" wrote in message ... "Bill Daniels" wrote ... At this point, I would consider anything. I've been talking to some of the dumbest phone sales people I can imagine. I've e-mailed the CAD file to 20 or so firms that advertise "custom panels" and, so far, no replies except for one local CNC shop that quoted $855 for the 9-hole 18" panel in ..125" sheet. This is a homebuilt group. Have you considered building it yourself? Rich |
The panel has to be .125" 7075 because it is a structural member. This is
NOT easy stuff to cut. The last time is did this, I used a milling machine with a fly cutter to make the instrument holes. Now all I have is a drill press. The tools that I would need to buy to do this simple job will cost more than the job 'should' cost from a CNC or waterjet shop. bildan "W P Dixon" wrote in message ... I was wondering the same thing myself , a panel is not hard to make at all. If you have built an airplane the panel should be about the easiest part. Are you planning on building this panel out of a special material? If it's metal I would do it myself. Patrick "Richard Isakson" wrote in message ... "Bill Daniels" wrote ... At this point, I would consider anything. I've been talking to some of the dumbest phone sales people I can imagine. I've e-mailed the CAD file to 20 or so firms that advertise "custom panels" and, so far, no replies except for one local CNC shop that quoted $855 for the 9-hole 18" panel in .125" sheet. This is a homebuilt group. Have you considered building it yourself? Rich |
"Bill Daniels" wrote in message news:g6fbd.251368$3l3.188348@attbi_s03... The panel has to be .125" 7075 because it is a structural member. This is NOT easy stuff to cut. The last time is did this, I used a milling machine with a fly cutter to make the instrument holes. Now all I have is a drill press. The tools that I would need to buy to do this simple job will cost more than the job 'should' cost from a CNC or waterjet shop. bildan Aluminum can be cut on ANY woodworking tool, so I would cut it with a table saw, (or radial arm) slightly oversize, then run the edge across the jointer (or router table) to clean up the edge, if it has to be beautiful. The holes could be cut with a high quality hole saw (under 40 bucks), and you could make a template for the mounting holes, and you would be all set. Not that hard, is it? -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.776 / Virus Database: 523 - Release Date: 10/12/2004 |
| Thread Tools | |
| Display Modes | |
| Instrument mounting question | Rob Turk | Home Built | 4 | July 19th 04 11:33 PM |
| Panel Lights - Need Help | Barnyard BOb - | Home Built | 2 | May 29th 04 08:51 PM |
| Panel lighting | Corky Scott | Home Built | 5 | March 6th 04 01:22 AM |
| Aluminum instrument panel finish? | Richard Riley | Home Built | 31 | February 4th 04 03:09 AM |
| CAD outline of Rans S6S instrument panel? | Rob Turk | Home Built | 2 | October 21st 03 10:27 PM |
