FAI turnpoint Question
Old February 11th 04, 04:01 PM
Andrew Warbrick
At 05:30 11 February 2004, Tango4 wrote:
Snip ....
But why not try doing it the real way?
300km - Straight out
You can only claim gold distance out of a straight
300k, diamond goal is a triangle or O/R.
500 km - O/R or at least a full FAI triangle with home
as one apex.
That would be nice, unfortunately at some clubs (including
mine) you fall off the edge of the country or hit airspace
if you try to fly a 500k triangle, let alone an O/R,
a 500k triangle with the club halfway along one leg
might just be on, except either the sea breeze would
get you, or you'd spend way too long jumping wave gaps.
snip...
Old February 11th 04, 06:03 PM
tango4
I can fit a 750km FAI triangle into the Uk and from Parham it's actually
acheivable.
PAR, PRE, BRN, PAR ( Parham Prestign up through the Midlands/manchester
airspace gap to Burn and then home to Parham ( via approximately Newbury to
miss the Heathrow airspace ) The FAI distance is 755km tha actual distance
around the airspaces is about 785.
Not impossible if we get another day like August 15th last year.
Ian
Old February 11th 04, 06:17 PM
Derrick Steed
acheivable.
Ian
Have you ever been through Manchesters low level corridor? it's busy! or did
you mean something else?
Rgds,
Derrick.
Old February 15th 04, 02:31 AM
Denis Flament
Mark Grubb wrote:
Trying to find the following information and an FAI Sporting Code
reference for the following:
1) The minimum separation between turnpoints on a 3-turn task
10 km
2) Maximum distance between start and finish on a closed circuit FAI
task
(O&R or Triangle)
0 km
(closed circuit implies start point = finish point)
Denis
R. Parce que ça rompt le cours normal de la conversation !!!
Q. Pourquoi ne faut-il pas répondre au-dessus de la question ?
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 04:51 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 12:14 AM
