Tow hook for a Cesna 185?
Old February 11th 04, 11:21 PM
Gary Boggs
Default Tow hook for a Cesna 185?
Has anybody gotten an STC for a tow hook or have any experience putting a
tow hook on a 185?
Gary Boggs
3650 Airport Dr.
Hood River, Oregon, USA
97031-9613
Old February 12th 04, 06:20 AM
REMOVE TO REPLY.pdb
Gary:
The FAA Advisory Circular on Aircraft Inspection and Repair
(EA-AC 43.13-1A&2, my copy is old, this may have been since
amended)has a section on the installation of towhooks. Chap
8 Glider aand Banner Tow-Hitch Installations (page 44-8 AC
43.13-2 chg 5 dtd 11/9/67) has a picture of a Schweizer
hook on a 180/185 stinger. I am not aware of an STC (may
well exist however) but with this drawing in the FAA's
official publication, it make make a 337 easier ...well
maybe possible.
If I were doing the installation, I would flip the hook
upside down per Jim Burch's 337 to insure better releases in
tension of the glider gets high on tow.
Pete Brown
tow hook on a 185?
Peter D. Brown
http://home.gci.net/~pdb/
http://groups.yahoo.com/group/akmtnsoaring/
Old February 12th 04, 01:23 PM
F.L. Whiteley
A local pilot has one on his C-180, but has thus far refused to consider
glider towing. It was used for banner towing in the past. It's possibly
original, optional equipment.
Frank Whiteley
"REMOVE TO REPLY.pdb" "REMOVE TO wrote in message
Gary:
maybe possible.
Pete Brown
a
tow hook on a 185?
Peter D. Brown
Old February 12th 04, 08:03 PM
Duane Eisenbeiss
"Gary Boggs" wrote in message
tow hook on a 185?
You might get some info by looking at the following page on the SSA web site
for starters.
http://www.ssa.org/ListGovtNewsDetail.asp?Action=&id=35
Duane
Old February 13th 04, 02:09 AM
Stuart Grant
An STC to install Tow Hook on Cessna 180 was donated to the SSA by
David Blanton Sr. the owner of Javelin Aircraft. The SSA sent me a
drawing showing how to fabricate and install a bracket and tow hook on
the tailwheel after I requested it by e-mail. Took about 10 days for
the SSA to reply but there was no charge. Wag-Aero sells Schweizer
hook, release and cable as a package cat. no. H-865-000 for $383.45.
As best I can tell you will have to fabricate mounting bracket
yourself out of 4130 0.10 plates. I am planning on doing all this on
my 180 as soon as more pressing maintenance issues are finished.
Investigated TOST hook and folks at TOST were very helpful sending
drawings of their E-85 series hooks. Mounting the TOST hooks to a 180
tailwheel bracket seems a little more complicated than Schweizer but
may be worth it for a very well-engineered release. Talking with the
old-timers at the Miami Glider Club, the opinion is that a Schweizer
hook installed "upside down" is dirt simple, easy to inspect and
should last for 10,000 tows. Haven't actually done anything yet except
research.
Charles Pate at Cessna Engineering pointed me to Cessna Documents that
tested towhooks on most of their aircraft (including 180 & 185).
Towhook was an option on nose-wheel 100 series Cessnas but not on
tailwheel. Likely to be some paperwork issues and will need a 337. It
has been done many times. The Advisory Circular referenced below helps
your IA build a case for field-approval. Will forward documents if you
need - just don't want to violate any copyright/ownership issues.
Gary:
maybe possible.
Pete Brown
a
tow hook on a 185?
Peter D. Brown
Tow Hook on Cessna 180 - Update Stuart Grant Soaring 13 April 10th 20 10:48 AM
Pull plane by tail hook Tarif Halabi Owning 19 February 24th 04 02:27 PM
Pawnee Tow Hook STC Shawn Curry Soaring 9 January 22nd 04 04:17 AM
Tow Hook on Cessna 180? Stuart Grant Soaring 3 October 2nd 03 12:50 AM
CG hook & Low Tow Ray Lovinggood Soaring 2 July 25th 03 06:20 AM
