Bolt torque
Old October 15th 04, 09:14 PM
Neal Fulco
Default Bolt torque
I'm about to do some final torquing of bolts and I want to make sure
I have the right torque numbers. A DOT Inspection and Repair manual
chart states that an AN-3 bolt with an AN-365 nut ( fine thread )
should be torqued to 20-25 inch pounds. Is this correct? Thanks
Neal
Old October 16th 04, 07:57 AM
smjmitchell
With that nut (tension type) this is the correct torque.
You would use a lower torque (12-15 in lb) for a shear type nut (i.e. AN364)
See Chapter 5 of AC43.13-1A (or 1B - the later rev) for further details.
"Neal Fulco" wrote in message
om...
Neal
V-8 powered Seabee Corky Scott Home Built 212 October 3rd 04 12:45 AM
piston connecting rod bolt replacement Dick Home Built 5 October 7th 03 03:34 PM
Trike wing bolt size Aaron Smith Home Built 0 September 30th 03 04:02 AM
Prop bolt torque setting Whunicut Home Built 2 September 4th 03 01:12 PM
Brake caliper flange Stealth Pilot Home Built 5 July 7th 03 05:19 PM
