People have mentioned spins when discussing the 1-26 both here and in previous
threads over the last couple of years. I got my rating in the 2-33, then spent some hours in the 1-26, and have also recently had a handful of flights in the Grob 103A. I mentioned to the CFIGs/DPEs where I fly the comments made by people on this group about the 1-26 spinning easily--this was met with various reactions, though NO ONE agreed that the 1-26 spins "easily". Those comments, accurate or not, prompted me to get at least some specific spin training in the 2-33. I am 110 lbs, and usually put 40 to 60 more in the front seat of the 2-33 when I fly it solo (and before anyone says anything, yes, I'm one of the weirdos who, despite having my license for a year, still walks away with a huge grin after flying the 2-33! sue me!!), but when we did the spin training, I didn't add any weight, and the CFIG is around 185. It took some doing to make it spin ... by that I mean that seeing what we had to do with the controls, how long we had to wait, and the multitude of glaring signs that were visible, audible, and perceivable by feel before it went into a spin, it's hard to imagine how, in **that** aircraft, the signs of the impending stall alone could be missed. I realize that's not the case for all aircraft, however. The comment was made here on RAS: "We teach people in the 2-33 and then put them into a 1-26 that spins at the drop of a hat with virtually little or no spin training ... shame on us!" In the hours I've flown the 1-26 (summers in AZ include some great-but-turbulent weather), I have not *unintentionally* come close to stalling it, and no, I have not chosen to spin it on purpose. To those who have stressed the importance of spin training *when talking about flying the 1-26*, I would like to know specifics -- are you saying it stalls and spins with little or no warning? If so, I'd like to hear details of specific instances where this has actually happened to you ... not just the blanket warning that applies to being aware of stalls and spins in *any* aircraft...I'm assuming we always have that in mind. Anyone? (Thanks in advance.) |
D.A.L wrote:
All good advice except for the one mentioning spin recovery...'Be sure you know proper spin recovery...'. You should know the signs of spin entry and avoid one! My one and only unintentional spin was on my first flight in a 1-26 (also my first flight in a single seat glider). I was thermalling and my first sign of spin entry was noticing that the ground and the air had swapped places. I may be better at recognizing warning signs now :-) but it was quick. Recovery was a no brainer. Tony V. http://home.comcast.net/~verhulst/SOARING |
Martin Gregorie wrote in message . ..
Trim? In a 1-26? |
On 19 Feb 2004 17:20:17 -0800, (Lennie the Lurker) wrote: Martin Gregorie wrote in message . .. Trim? In a 1-26? I've seen one once. Never flown one. Couldn't possibly comment. Actually, Lennie has a good point. In typical Schweizer fashion, the trim in a 1-26 is usually (always?) a joke. Fortunately, unlike the 2-33, the 1-26 pretty much doesn't need much trimming due to it's light elevator forces. Just in case, it's worth checking that the trim control is in the full forward position prior to takeoff, especially if the pilot is light and you are not familiar with that particular 1-26 (since they may vary quite a lot!). Still a fun little glider to fly, all things considered. Kirk |
Kirk Stant wrote:
Martin Gregorie wrote in message . .. On 19 Feb 2004 17:20:17 -0800, (Lennie the Lurker) wrote: Martin Gregorie wrote in message . .. Trim? In a 1-26? I've seen one once. Never flown one. Couldn't possibly comment. Actually, Lennie has a good point. In typical Schweizer fashion, the trim in a 1-26 is usually (always?) a joke. I don't know if the 2-32 is typical, but when I was training in 2-32s, I really noticed if the trim wasn't set properly. Sure, I could still fly the glider, but it was very distracting. Jeremy |
It's posible to adjust the trim mechanism to make it work better, I have
done some spring changes to make mine work very well. It's kinda tough because you have to take the nose cone off and fiddle around a lopt, and it's not really that big of a deal - the only time I like to use the trim is on tow when the towpilot get a bit frisky and forgets its a 1-26 on the end of the rope and we're bouncing off 70 mph. Otherwise, the stick forces are so light, it's no big deal, besides, you're mostly conentrating on where you are going to find that next thermal. Jim "Kirk Stant" wrote in message om... Martin Gregorie wrote in message . .. On 19 Feb 2004 17:20:17 -0800, (Lennie the Lurker) wrote: Martin Gregorie wrote in message . .. Trim? In a 1-26? I've seen one once. Never flown one. Couldn't possibly comment. Actually, Lennie has a good point. In typical Schweizer fashion, the trim in a 1-26 is usually (always?) a joke. Fortunately, unlike the 2-33, the 1-26 pretty much doesn't need much trimming due to it's light elevator forces. Just in case, it's worth checking that the trim control is in the full forward position prior to takeoff, especially if the pilot is light and you are not familiar with that particular 1-26 (since they may vary quite a lot!). Still a fun little glider to fly, all things considered. Kirk |
Yes, there is trim in a 1-26. Just not a tremendous amount. Usually full
forward is about best L/D, and full back is a good thermaling speed. ( if the trim is set well) I have made the transition the other way. I originally trained in a L-23 then transitioned to a 1-26. After over 200 hours in a 1-26 I took a check flight in a 2-33 while visiting another club. The 1-26 is much lighter on the controls, and much more responsive. The 2-33 is much more like a truck. Just use a light hand on the controls. By the time you get off tow and make a few turns you will get a big smile on your face and see how much fun the little bird is. I usually fly my pattern at about 50 mph. This and keeping the yaw string straight will take care of all of the things that have been written about spins on this thread. I have not found the 1-26 to have any tendency toward spinning. I have done some spins at altitude intentionally and recovery is quite quick and conventional. The point is that you do not want to spin ANY ship in the pattern. The model of 1-26 that you are going to fly will make a difference in the amount of spoiler that you will have. I started in an E model with both upper and lower surface spoilers (our club ship), and now own a B model, top only so less spoiler, but it still comes down fine. The bird also slips very well. Before you ever fly the bird however the first thing that you should do is to spend 1/2 the amount of a tow to join the 1-26 Association. www.126association.org The Association supports the 1-26 and sponsors the 1-26 Championships each year. The last few years a badge camp has also been included at the Championships. Once you get some flights in the little bird you will find it to be a delight. Then consider chasing your badges in the 1-26. At least make sure that you get your silver in it, however all your badges through diamond are possible in the 1-26 and are encouraged by die hard 1-26ers. Hope this helps. Kevin R. Anderson Soar 192 Eastern VP 1-26 Association "Jeremy Zawodny" wrote in message ... Kirk Stant wrote: Martin Gregorie wrote in message . .. On 19 Feb 2004 17:20:17 -0800, (Lennie the Lurker) wrote: Martin Gregorie wrote in message . .. Trim? In a 1-26? I've seen one once. Never flown one. Couldn't possibly comment. Actually, Lennie has a good point. In typical Schweizer fashion, the trim in a 1-26 is usually (always?) a joke. I don't know if the 2-32 is typical, but when I was training in 2-32s, I really noticed if the trim wasn't set properly. Sure, I could still fly the glider, but it was very distracting. Jeremy |
