Sammy Mason on Stalling & Spinning
Old February 19th 04, 09:04 PM
BAToulson
In article , Todd Pattist
writes:
The first time I tried this in my Ventus, I was flying along
sideways with full rudder and level wings and heard a loud
"BANG!" After my heart stopped thumping, I figured out that
one of the gear doors had sucked open into the sideways
airflow. :-)
That happened to me once.Scared the hell out of me.
Another scarey bang was in a Puchacz on the winch when the cover, which is over
the rear seat adjustment bar, could not have been secure and flicked down and
hit the side of the fuselage. This was about six inches from my left ear and
was magnified by the megaphone shape of the hollow fuselage.
A third was in a Bocian, also on a winch when the rear canopy, which slid
backwards on rails, came unlocked, slid back and hit the rear stop. This one
was probably the worst because, a) we were about 100ft and starting to rotate
into full climb, b) in addtion to the "bang" as it hit the stop, there was a
huge, disorientating rush of air, and c) it took a while to work out what had
happened, take over from the pupil, (only his second or third winch take off)
and get the nose down etc.
However, one of the the worst I know of these type of incidents was a pilot at
my club who owned a Carmem and lost the complete canopy at about 4000ft agl. It
departing it caught his skull which bled profusely and a combination of blood
and the wind causing his eyes to run, made it extremely hard for him to see.
Once he worked out what had happened, his big concern was what else the canopy
had hit, tailplane for example. He considered baling out but, having checked
all controls decided to ride it down to the nearest field, successfully I am
pleased to say.
The farmers reaction to this bllod covered figure arriving at his door was, I
understand, unprintable.
Needlesss to say, all of the above (except U/c doors) occurred either as a
result of poor take off checks or mechanical faults.
Barney
UK
Old February 19th 04, 09:10 PM
BAToulson
writes:
airflow. :-)
pleased to say.
Barney
UK
Old February 19th 04, 09:20 PM
BAToulson
writes:
airflow. :-)
pleased to say.
Barney
UK
Old February 19th 04, 10:35 PM
BAToulson
writes:
airflow. :-)
pleased to say.
Barney
UK
Old February 20th 04, 07:42 AM
Bruce Greeff
We had one genius pull the canopy release on winch launch, then a week later do
it again with the new canopy.
Fortunately he has moved on to smashing cars...
writes:
airflow. :-)
pleased to say.
Barney
UK
Old February 20th 04, 11:15 AM
Robert Ehrlich
I wonder how you manage to get a new canopy and install it
so quickly.
Old February 20th 04, 01:53 PM
Chris OCallaghan
Where I'm having trouble is seeing why there is any difference between
sinking, level, and climbing. From the point of view of raf, these
should all be same. I choose to set my longitudinal reference based on
the fuselage, not the horizon. If I do this, the aircraft always has a
sink rate, not relative to the ground, but relative to the projection
of the fuselage centerline at a given time (T=0) and proportional to
the angle of attack -- that is, the rate at which the aircraft "falls"
away from this projection (dT). Since it shouldn't matter which
reference frame I use to make my observations, my confusion arises
with the suggestion that the pseudo-rolling moment reverses beetween
sink and climb.
As for the approach, it remains interesting. To help my understanding,
I've been using a train. Imagine a sensor on a rail that only measures
side force. A train going straight on level ground registers zero side
force. As the rail bends though, the sensor would measure a side force
proportional to the train's acceleration. However, a straight rail
with a side pitch would register a force as well. When viewed this
way, a train rolling on a straight rail with several degrees of side
inclination could be said to be "turning." Of course, it isn't. Unlike
a curved rail, no additional power is needed to maintain speed. (Note
the limitations of my reference frame. I only see side force on the
rail, not total force.) It's not exactly analogous, but it's a step in
the right direction.
Old February 20th 04, 07:48 PM
BAToulson
writes:
airflow. :-)
pleased to say.
Barney
UK
Old February 20th 04, 08:32 PM
Fredrik Thörnell
Chris OCallaghan skrev den 20 Feb 2004 05:53:14
-0800:
sink and climb.
When turning, the only rotation is about the vertical (earth-fixed) axis.
Then take it to the extreme case of diving straight down (here defined as
the longitudinal axis vertical). In that situation, all of the rotation
will be around the longitudinal axis of the aircraft - i e roll.
In turning flight with the fuselage level (longitudinal axis horizontal),
all of the rotation will be around the yaw axis of the aircraft.
In all the cases between these two extremes, part of the rotation will be
around both the longitudinal and the yaw axis of the aircraft. The bank
will mean some of it is around the pitch axis as well, which is a problem
to be considered in, among other things, turn rate gyros.
The equivalent to a banked railway track would be straight slipping
flight. And in both cases, the normal force on the rail (the lift) will
have to be larger if it is to keep the train/aircraft from accelerating
downwards, and there will have to be a lateral (train/aircraft frame of
reference) force as well, assuming that there are no other forces
perpendicular to the direction of travel than the normal and lateral (to
the wings/rail). Both these forces will add friction/induced drag and
require additional power.
Cheers,
Fred
Old February 20th 04, 09:02 PM
Fredrik Thörnell
Todd Pattist skrev den Fri, 20 Feb 2004
15:44:10 -0500:
And, to answer his question on why there is a reversal
between sink and climb, you need to go on and point out that
with the nose pointed strongly down, the top of the outer
wing is moving forward around the outside of the turn
circle. With the nose pointed strongly up, the bottom of
the outer wing is moving forward around the outside of the
turn circle. Thus, a reversal at level.
Good job! The same thing, but understandable in your version!
Another example of why you should never let an engineer explain anything
to do with his field of work.
Cheers,
Fred
Puchaz Spinning thread that might be of interest in light of the recent accident. Al Soaring 134 February 9th 04 03:44 PM
Stalling and spinning generally Ian Strachan Soaring 0 February 1st 04 08:40 PM
Spinning or the after effects of stalling. Dave Martin Soaring 0 January 29th 04 11:24 PM
Spinning Horizon Mike Adams Owning 8 December 26th 03 01:35 AM
Dynamic stalling of delta wing a/c (wrt MiG 21) drake Military Aviation 12 August 26th 03 06:37 PM
