Turning over fuselage to work on undercarriage.
Old February 19th 04, 11:25 PM
Dan Goldman
Default Turning over fuselage to work on undercarriage.
What is a good (safe) method to turn over the fuselage so work can be
done on the udercarriage ? I have access to a fork lift if needed.
Dan
Old February 19th 04, 11:34 PM
Mark Zivley
Dan,
I rolled my LS-1 on it's side by gently sliding the cradle out from
under it and resting the fuse on an old thick sofa cushion. Remove the
canopy first obviously. Once onto the thick sofa cushion, gently roll
it on it's side and support the vertical fin with another cushion.
Advantage here is that it doesn't require any lifting and it can't
"fall" as can happen if you attempt to invert it onto a sawhorse.
Mark
Dan
Old February 20th 04, 12:35 AM
BTIZ
get a few friends over.. remove the canopy.. and prepare (cushion) a couple
of sturdy saw horses.. rest one across the open cockpit area, and one on the
tail boom, the saw horse should be tall enough to protect the tail
BT
"Dan Goldman" wrote in message
om...
Dan
Old February 21st 04, 09:31 PM
Papa3
If you've got a shop with a moderately high ceiling and exposed beams, you
can use a hoist. Make a sling out of two lengths of wide webbing. This goes
around the fuselage near the aft end of the cockpit. Attach this to a
come-along securely fastened to the overhead beams. It helps if you use a
spreader to connect the straps to the come-along (eg strong steel pipe with
bolts through it) just slightly narrower than the fuselage; this allows you
to roll the fuselage to any angle you want. You can then crank the
fuselage up to any height and either roll it upside down or turn it 90
degrees. You'll obviously need a sawhorse under the tail boom.
The advantages to this method a 1: you can rotate to any number of
angles and 2: if it's set up right, you can actually manhandle this without
anyone else around.
P3
om...
Dan
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 07:35 AM
Ford V-6 engine work Corky Scott Home Built 19 August 21st 03 12:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
