I need to make a specialized tool and am looking for a way to drill a
1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. In other words, I am trying to make something similar to a screwdriver using solid aluminum rod for the handle and 1/16" brass rod as the blade. -- Scott http://corbenflyer.tripod.com/ Building RV-4 Gotta Fly or Gonna Die |
Got a lathe? Failing that, you could lay the thing out by hand, carefully
centerpunch it, then put it in a drill press. I'm sure you already know this, but with care, you'd be amazed at how precise you can be on *one* small part. Especially if it is the second or third one you've attempted to make. ;-) KB "Scott" wrote in message ... I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. In other words, I am trying to make something similar to a screwdriver using solid aluminum rod for the handle and 1/16" brass rod as the blade. -- Scott http://corbenflyer.tripod.com/ Building RV-4 Gotta Fly or Gonna Die |
centerpunch it, then put it in a drill press If you can, spin the part, not the bit. Q |
Take the part down to your local engineering shop, should cost about a
six-pack to drill both ends. Hope this helps, Peter "Scott" wrote in message ... I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. In other words, I am trying to make something similar to a screwdriver using solid aluminum rod for the handle and 1/16" brass rod as the blade. -- Scott http://corbenflyer.tripod.com/ Building RV-4 Gotta Fly or Gonna Die |
You need a centering head square---http://www.wttool.com/p/1279-0006-----
put end of rod in Vee, scribe line using center blade, --rotate 90deg, scribe again, intersection of scribed lines is center of circle...QED Kyle Boatright wrote: Got a lathe? Failing that, you could lay the thing out by hand, carefully centerpunch it, then put it in a drill press. I'm sure you already know this, but with care, you'd be amazed at how precise you can be on *one* small part. Especially if it is the second or third one you've attempted to make. ;-) KB "Scott" wrote in message ... I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. In other words, I am trying to make something similar to a screwdriver using solid aluminum rod for the handle and 1/16" brass rod as the blade. -- Scott http://corbenflyer.tripod.com/ Building RV-4 Gotta Fly or Gonna Die |
... I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. In other words, I am trying to make something similar to a screwdriver using solid aluminum rod for the handle and 1/16" brass rod as the blade. Scott............ This may sound a bit backwards, but start with a hole and center the aluminum around the hole. In other words, first drill a hole in an oversized piece of rod. Try to get it in the middle, but don't be too anal about it - just keep it straight, not curved like a dull bit will tend to do. Either a drill press or a lathe will work for this operation. Then put the rod in a lathe, between centers, and drive it with a "dog". Don't use a chuck. Turn the outside to the desired diameter. Now the outside and the inside will be perfectly concentric. Saw off the butt end where the dog clamped the rod to spin it. Violá . . .or Violin . . .or Viagrá. Rich S. |
Scott wrote ...
I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. ... Can't be done. Not "EXACTLY" anyway. If somebody hands you one that's "exactly" dead nuts center, they simply aren't using a fine enough means of measuring. So pick your tolerance, .005", .001", ..0005", .0001", a nanometer, an angstrom, a yoctometer, whatever. If something within a few thousandths is sufficiently accurate, a drill press alone will do the job. Trick is to make a one-time custom fit vise in situ. Take two chunks of similar dimension hardwood, say 1x2 oak. Screw them together with a couple slips of paper between them. Don't use bolts, only screws. Lay the assembly on the drill press table with the seam & paper standing vertically, directly under the center of a tiny drill bit (as close as you can eyeball it anyway). Clamp the rear hardwood block to the drill table. Drill a 3/4" hole down through the seam. Half of the hole will be in each piece of wood. Leave the rear block clamped to the table while you partially unscrew the front block from it. Remove the remnants of the paper spacer. Put a little powdered rosin in the two halves of the hole (get a rosin bag at a sporting goods store). Drop your aluminum stock in the hole you just drilled & screw the front block back in place. You've now clamped your stock in a hole that's pretty damn close to perfectly centered under your drill chuck. Drill it to find out just how close. Daniel |
"Kyle Boatright" wrote in message ...
Got a lathe? Failing that, you could lay the thing out by hand, carefully centerpunch it, then put it in a drill press. I'm sure you already know this, but with care, you'd be amazed at how precise you can be on *one* small part. Especially if it is the second or third one you've attempted to make. ;-) KB "Scott" wrote in message ... I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. In other words, I am trying to make something similar to a screwdriver using solid aluminum rod for the handle and 1/16" brass rod as the blade. -- Scott http://corbenflyer.tripod.com/ Building RV-4 Gotta Fly or Gonna Die Old mechanics saying: It ain't hard to make one piece alike, the problem is making two alike. Harry K |
On Sat, 16 Oct 2004 11:52:02 +0000, Scott
wrote: I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. In other words, I am trying to make something similar to a screwdriver using solid aluminum rod for the handle and 1/16" brass rod as the blade. I dunno how exact you mean when you say exact, but this summer I built a "C-Frame" riveting/dimpling tool and had to drill a 3/16" hole in the "exact" center of a 5/8" rod. I accomplished this by finding a piece of 1" or so round steel, clamping it in my drill press vise and then clamping the vise to the drill press table. I first drilled a 3/16" hole completely through the 1" round steel (approx 2.5" long) as close to centered as I could (non critical), and then chucked a 5/8" bit in my drill press. Taking care to keep the alignment the same, I then drilled about halfway down the first hole with the 5/8" bit to make a drill guide. I clamped the 5/8" rod in a vise, and placed the guide over it. Then took the 3/16" bit in a hand drill and drilled into the rod using the guide to center it. It isn't as exact as using a lathe would have gotten, but it is more than good enough for the task at hand especially considering that I dont *have* a lathe. A picture of the C-frame tool (before paint and sandblast) can be found he http://www.rawlinsbrothers.org/bhfaq/imptool.html It didn't occur to me to take a picture of the drilling guide but it should be fairly self explanatory. ================================================== == Del Rawlins-- Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ Remove _kills_spammers_ to reply |
Hey Kyle,
Well, I have zero experience on a lathe, so THAT's out ![]() Actually, after my post and while having breakfast and COFFEE with fellow EAAers, I thought of a way to do it. What if I had a piece of square steel tube and put the round rod inside (as long as it's a snug fit by wrapping layers of tape around the rod if necessary) and drew lines across from opposite corners of the steel tube. That should put the interesecting lines at the center of the aluminum rod. I hope to get it on the first try ![]() -- Scott http://corbenflyer.tripod.com/ Building RV-4 Gotta Fly or Gonna Die Kyle Boatright wrote: Got a lathe? Failing that, you could lay the thing out by hand, carefully centerpunch it, then put it in a drill press. I'm sure you already know this, but with care, you'd be amazed at how precise you can be on *one* small part. Especially if it is the second or third one you've attempted to make. ;-) KB "Scott" wrote in message ... I need to make a specialized tool and am looking for a way to drill a 1/16" hole EXACTLY in the center of the end of a piece of say 1/2" of 3/4" solid aluminum rod. In other words, I am trying to make something similar to a screwdriver using solid aluminum rod for the handle and 1/16" brass rod as the blade. -- Scott http://corbenflyer.tripod.com/ Building RV-4 Gotta Fly or Gonna Die |
| Fairing question... | Tina Marie | Home Built | 5 | July 16th 03 01:18 AM |
