Servicing Cobra Hydraulic foot pumps
Old March 8th 04, 11:05 PM
JJ Sinclair
The bolt in the middle of the scissor should be tightened a little.
Then you can lift it from the top without pulling the piston out of
the cylinder
AS
Thanks Al,
The problem I had was with a 2-jack set-up on my ASH-25 trailer.
Should we be using DOT-3 automotive brake fluid in your jacks?
JJ Sinclair
Old March 9th 04, 02:12 PM
JJ Sinclair
No brake fluid ,please.
Just hydraulic oil or oil from automatic hydraulic car gears gears.
AS
Oops, I stand corrected.
I would like to thank you for making a real quality product. Your fully
fumctional trailers make assembling and disassembling the glider a joy, not a
burden. Only those who have owned a dysfunctional trailers, can really
appreciate the Cobra.
Keep up the good work,
JJ Sinclair
Old March 9th 04, 04:04 PM
R Barry
AS
What Al means is ATF a.k.a. automatic Trans Fluid is ok
COBRA TALON, COBRA SPOT Allen Thomson Military Aviation 0 December 9th 03 06:44 PM
