Winch Cable Splicing (w/o ferrules)
Old March 18th 04, 10:36 PM
Gary Emerson
Default Winch Cable Splicing (w/o ferrules)
In reading Derek's book, he makes mention that a cable can be
effectively repaired with out using aluminum or copper ferrules, but
apparently by carefully opening up the 7x7 stranded construction and
then interweaving the strands back together for a seamless repair.
Obviously this has advantages of a smooth running cable, but it may be
tricky and time consuming to do right.
So, with that said, does anyone have a document that they could refer me
to that describes this operation in enough detail to be able to give it
a try?
Thanks,
Gary
Old March 18th 04, 11:20 PM
Stefan
Basic seamanship. Every sail boat shop should have books about splicing
and knotting and rope work in general.
Stefan
Old March 18th 04, 11:56 PM
Marc
You won't find many A&P mechanics that are current on it, but cable splicing
is covered in the FAA's AC 43.13 publication. The section is aimed at
repair of flying/bracing wires and control cables but the technique is the
same with heavier material.
A larger chandlery (sailboat parts shop) is likely your best bet to find
someone with actual experience.
I'm pleased to see the support for winch launching. Even in the wide-open
USA midwest they make sense (except maybe for wave entries).
Cheers,
Marc
Old March 19th 04, 12:11 AM
Dave Martin
can be
ferrules, but
construction and
repair.
but it may be
they could refer me
be able to give it
a try?
Thanks,
Gary
Proper interwoven splices in 7 strand cable are difficult
and time consuming.
The following is a simple simple procedure, books not
required.
I was taught this many years ago by an experience winch
driver.
Takes about three minutes after a bit or practice.
Steps are as follows, the basic principle is like tying
a reef knot.
1. Make neat cuts to the ends to be joined.
2. Open one cable around the centre core for about
10inches in two halves. Leaving the centre core on
its own (Longer until you get used to it, less as you
get more experience)
3. Cut out the centre core and re wind the cable for
about half an inch.
4. The taking the two ends on one cable tie a single
'knot' in them. If done correctly the cable will lie
together following the natural twist in the cable.
Now keep wrapping each end round the other end. If
you got it right, you should finish with the cut ends
twisting naturally round each other until they reach
the main cable.
You should now have a cable with a neat loop at the
end.
If this is right you have cracked the job.
Next go to step 2 with the other cable.
Before going any further, feed this cable through the
loop you created in the first cable and then
6 Wrap the two ends round the other cable and Tie a
knot as above .
You should finish with two cables each with a loop
in the end
each loop being around the other cable.
7. Pull tight.
If you look at the finished knot it is similar to a
reef knot.
Some clubs wrap the knot in 'gaffer' tape which then
forms a protective coat as it beds in the tape and
glue form part of the knot and reduce frayed ends.
I have done many splices like this and they eventually
pull so tight they are difficult to detect. They are
also smoother on the pay on gear than new ferrules.
It is very good on older worn rope when ferrules do
not compress enough to grip and the club have forgot
to order new cables.
Hope this makes sense. It is a very simple procecure
try it with some spare cable.
Dave
Old March 19th 04, 12:28 AM
Bill Daniels
"Dave Martin" wrote in message
can be
ferrules, but
construction and
repair.
but it may be
they could refer me
be able to give it
a try?
Thanks,
Gary
and time consuming.
required.
driver.
a reef knot.
about half an inch.
the main cable.
end.
knot as above .
in the end
7. Pull tight.
reef knot.
Dave
Of course, you could just dump the old steel cable and use 3 - 4 mm Spectra
hollow 12 strand braid. To make a splice you just to tuck each end into the
other piece for about 18 inches using a fid. It takes less than a minute to
make an invisible splice. The rope diameter barely increases at the splice.
No bloody fingers either.
Bill Daniels
Old March 19th 04, 12:46 AM
Charles Yeates
Dave
Copper ferrules have worked easily and well for us at Bluenose for over
twenty-two years -- Why take the time and risk of interweaving strands?
can be
ferrules, but
construction and
repair.
but it may be
they could refer me
be able to give it
a try?
Thanks,
Gary
and time consuming.
required.
driver.
a reef knot.
about half an inch.
the main cable.
end.
knot as above .
in the end
7. Pull tight.
reef knot.
Dave
Old March 19th 04, 06:37 AM
F.L. Whiteley
The NCSA, now CSA, used to have 'wave' winch camps at Walden, CO annually.
IIRC, the pilot in this image got his diamond from a winch launch.
http://www.soarcsa.org/images/pikwinch.jpg (photo credit to Rich Carr)
Steamboats in the distance.
"Marc" mwilliams SPAM@us family.netSPAM Remove SPAM and spaces. wrote in
message ...
splicing
Cheers,
Marc
Old March 19th 04, 06:42 AM
F.L. Whiteley
One thing about the old RAF clubs, 50p launches. Did some 5+ hours flights
from those;^) Cable mending with the 4/3
wind and a reef knot was nearly as fast as with swaging tools.
Frank Whiteley
PS: That's when the UKP=$2.00US
"Charles Yeates" wrote in message
Dave
can be
ferrules, but
construction and
repair.
but it may be
they could refer me
be able to give it
a try?
Thanks,
Gary
and time consuming.
required.
driver.
a reef knot.
about half an inch.
the main cable.
end.
knot as above .
in the end
7. Pull tight.
reef knot.
Dave
Old March 19th 04, 08:22 AM
Dave Martin
tools.
Frank Whiteley
'Charles Yeates' wrote in message
Dave
at Bluenose for over twenty-two years -- Why take the
Charles and Bill
My own club use ferrules -- most of the time, But glider
pilot being glider pilots there are times when the
ferrules have run out, the press is U/S and you need
to join a cable quickly.
Tying knots in cable is just a quick and simple mthod
that winch drivers should be able to do. I have seen
simple reef knots tied in cables as Frank said and
then wrapped in gaffer tape. Just as effective but
'knot'as pretty.
I agree with Bill re spectra, but we have visited this
topic before and as yet no one in the UK wants to make
the investment in trials. But we will keep plugging
away
Dave
Old March 19th 04, 03:31 PM
Martin Gregorie
On Thu, 18 Mar 2004 23:37:37 -0700, "F.L. Whiteley"
Nice picture! Nice launch too.
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
Winching - Reverse Auto Tow John Spargo Soaring 61 January 3rd 19 02:41 AM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
Winch problem Lach and JoAnn Ohman Soaring 8 December 24th 03 05:13 PM
using winch instead of aerotow goneill Soaring 5 August 27th 03 02:46 PM
Winch cable Bill Daniels Soaring 5 August 24th 03 11:13 PM
