Devices for avoiding VNE?
Old April 2nd 04, 08:13 PM
Arnold Pieper
Good if that's what makes YOU feel safe !
"Todd Pattist" wrote in message
"Arnold Pieper" wrote:
These reports led you to the wrong conclusion.
Overstress is the key here, weahter with or without airbrakes.
My load limit is 5 G's brakes closed, 3.5 G's brakes open.
If you want to pull the nose up at 5 G's to avoid hitting
the ground, you can do it brakes closed, but not brakes
open. If your adrenaline kicks in as you pull back, you can
pull until you feel 5 G's if you leave the brakes closed,
but only to 3.5G's if you open them.
Todd Pattist - "WH" Ventus C
(Remove DONTSPAMME from address to email reply.)
  #42
Old April 2nd 04, 10:13 PM
Andy Blackburn
Okay - point taken on designs with lots of tip washout
or inbord flaps deployed. But the wing twist discussion
was really a secondary point in the dialog about pitch
stability overall, and I'm not sure that a twisting
at the tip would contribute very much to making the
glider unstable overall.
I still think it's not reasonable to expect that a
glider would be certified where you'd get enough structural
twisting to upset the overall stability of the aircraft.
More broadly, I doubt that you'll find a certified
aircraft that has a pitching moment that becomes more
nose down with increasing speed no matter what the
reason. The feds are unlikely to smile on a design
with static instability at any speed.
I remain convinced that if your sailplane exhibits
pitch instability you have a c.g. problem, a rigging
problem, your aircraft has been modified or you are
outside the certified operating limits.
At 18:42 02 April 2004, Jj Sinclair wrote:
I a bit suspicious of this whole wing twist thing.
Take a K-6 up to 100 and look at the tips.
Take an ASH-25 up to 80 with landing flaps on and
look at the tips.
In the case of the K-6, she does have a few degrees
of tip wash-out (leading
edge down)
In the case of the ASH-25 with landing flaps on, Only
the inboard flaps go
down, the outboard flaps and ailerons go up to produce
a negative angle of
attack.
So why do the wings in both cases bend down?
Why does the B-52 use spoilers instead of ailerons?
Because at higher airspeeds
an aileron input causes the wing to bend and can cause
the ship to turn in the
opposite direction (wing twist)
Even in a *certified* ship, if the wings start to tuck
under and you don't
catch it right away, you could find yourself in a situation
where elevator
won't stop the pitch down action. Now, all of this
is at or above VNE, so if we
are flying our glass slippers within limits, we should
be OK.
JJ Sinclair
  #43
Old April 2nd 04, 10:52 PM
ADP
Well,
Although not directly related to gliders (except really fast ones), look up
"mach tuck" and you will find several certified aircraft that tend to nose
down as speed increases.
Critical mach is a aeronautics term that refers to the speed at which some
of the airflow on a wing becomes supersonic. When this occurs the
distribution of forces on the wing changes suddenly and dramatically,
typically leading to a strong nose-down force on the aircraft. This effect
led to a number of accidents in the 1930s and 1940s, when aircraft in a dive
would hit critical mach and continue to push over into a steeper and steeper
dive. This problem is often lumped in with the catch-all phrase
compressibility.
Wings generate much of their lift due to the Bernoulli effect; by speeding
up the airflow over the top of the wing, the air has less density on top
than on the bottom, leading to a net upward force. The relative difference
in speed is due largely to the wing's shape, so the difference in speed
remains a fairly constant ratio over a wide range of speeds.
But if the air speed on the top of the wing is faster than on the bottom,
there will be some speed where the air on top reaches the speed of sound.
This is the critical mach. When this happens shock waves form on the upper
wing at the point where the flow becomes supersonic, typically behind the
midline of the chord. Shock waves generate lift of their own, so the lift of
the wing suddenly moves rearward, twisting it down. This effect is known as
mach tuck.
;0)
Allan
"Andy Blackburn" wrote in message
  #46
Old April 3rd 04, 03:31 AM
Arnold Pieper
A+ for research initiative, D- for applicability.
Mach tuck affects certain high speed aircraft (high mach numbers, jets only)
with swept back wings, when they exceed their Mmo.
When flying within their normal certified speed ranges, they do not present
this abnormality.
As someone already posted, no aircraft would be certified with instability
being a part of its normal flight envelope.
"ADP" wrote in message
Well,
up
dive
steeper
compressibility.
of
as
mach tuck.
;0)
Allan
  #47
Old April 3rd 04, 06:41 AM
d b
Do you include rudder lock as an instability? How about dynamic stability?
What about downsprings, bob weights and other stability enhancement devices?
Stability is a really broad subject.
In article , "Arnold Pieper"
this abnormality.
Well,
up
dive
steeper
compressibility.
of
as
mach tuck.
;0)
Allan
  #48
Old April 3rd 04, 08:20 AM
Jan-Olov Newborg
"ADP" wrote in message ...
Well,
compressibility.
mach tuck.
How do you fly inverted using "Bernoulli Effect"?
Jan-Olov Newborg
  #49
Old April 3rd 04, 08:46 AM
ADP
A for effort, D for accuracy. The DC-8 Could not be flown at altitude with
out it's PTC (Pitch Trim Compensator) being operative.
The function of the PTC was to protect against mach tuck.
Since the DC-8 was undoubtedly certified, the argument is invalid.
Had you read my post you would have noticed the reference to supersonic
airflow which presumably does not apply to gliders.
On the other hand, a P-38 with a critical mach number of .69 is hardly a jet
and has straight wings.
Several were lost in early testing because the phenomenon of mach tuck was
not well known.
In fact, sweepback is a design factor that helps delay critical mach to
higher numbers.
Not to make too fine a point but any aircraft, if flown fast enough without
breaking up, can be subject to mach tuck.
Allan
"Arnold Pieper" wrote in message
m...
only)
present
this abnormality.
Well,
up
nose
some
effect
dive
steeper
compressibility.
speeding
difference
upper
of
as
mach tuck.
;0)
Allan
  #50
Old April 3rd 04, 08:48 AM
ADP
It's called angle of attack.
Allan
"Jan-Olov Newborg" wrote in message
om...
Well,
Jan-Olov Newborg
Aircraft Deceleration Devices SteveM8597 Military Aviation 10 April 13th 04 10:01 AM
GPS and Night Vision Devices Steve Products 0 February 12th 04 11:34 AM
WinPilot-compatible GPS devices Ted Wagner Soaring 21 January 12th 04 10:27 AM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
Airdropped Fusion Devices Blinky the Shark Military Aviation 4 September 17th 03 05:34 PM
