#11
![]() "Wallace Berry" wrote in message ... So, would your idea work? I proved it would but all that heavy gear will be pretty hard to get into a glider. Throwing out bits of toilet paper probably works better. Hmmm, Lets see.....what would a toilet paper dispensing machine look like... Bill Daniels Someone beat you to it. Ted Teach had a 1-26 with a toilet paper dispensing mechanism in the turtledeck. It was a little trapdoor with a cutting edge. Open the door and toilet paper unrolled into the slipstream. Close the door and it severed the paper. Repeatedly opening and closing the door supposedly dispensed tp chaff to be followed as a thermal marker. Teach's 1-26 also had a reprofiled nose and canopy and doors that enclosed the landing gear (retractable gear being against the rules in 1-26 racing. Mark Connor later had this 1-26 and was undoing all the "Teachisms" on it. In all seriousness, the bubble experiments produced some very good insights in low level convective airflow. Neutrally buoyant bubbles have no aerodynamic qualities of their own so if they are seen to move, it is because airflow is pushing them. Bits of paper and other debris do have some aerodynamic qualities so the data is corrupted. Up to that point there were several studies that used smoke, but that can't be analyzed numerically. Discrete bubbles provided a means to measure speed and direction of airflow in 3D to high precision. Later, larger scale experiments with Mylar balloons were even more interesting. First pairs would be released and tracked for many miles by radar. Eventually, large numbers of these balloons were released simultaneously along a crosswind line in thermic conditions and watched by radar as they traced out thermal streets. Today, most work of this kind is done with LIDAR (Laser Radar) which can track naturally occurring tiny aerosols of pollen and dust revealing the 3D structure of airflow with great precision over a large area in real time. Now, putting a LIDAR in a glider WOULD be interesting. Bill Daniels |
be analyzed I was wondering about orange smoke flares but I can see that one might either fill the cockpit with an impenetrable haze or knock chucks off the horizontal stabiliser. Both would cause a greater degradation of performance than a need to pee. I can also see that flares attached to balloons are difficult to push through the clear view panel. But maybe the T21 will come in handy! I wonder how "skywriters" make their smoke and what the effect of thermalling with a smoke dispenser would be like, maybe personal IMC conditions. Thermals could be colour coded according to strength. If the dispenser was attached to the vario, then the smoke could be varied by colour according to lift, making it easier to move towards the green smoke and away from the red smoke. - with the potential to reverse the colours if needed to confuse the unwanted. Today, most work of this kind is done with LIDAR (Laser Radar) which can track naturally occurring tiny aerosols of pollen and dust revealing the 3D structure of airflow with great precision over a large area in real time. Has anyone any leads to accessible output on the results of LIDAR? Rory |
Actually for thermal marking purporses smoke would work pretty fine. But I
don't know any smoke machine which is small enough to fit to the glider and which is controllable. For aerobatics they just fit smoking cartridges that burn to the end after ignition, but thermal marking needs some repeatable 2 sec buffs of somke. There's another problem with bubbles. The only reasonable place to put it is on top of the rear fuselage. But then you spill the vertical fin with wet bubbles and this harms your L/D. Regards, Kaido "Bill Daniels" wrote in message news:t6ahc.33650$ru4.33232@attbi_s52... "Wallace Berry" wrote in message ... So, would your idea work? I proved it would but all that heavy gear will be pretty hard to get into a glider. Throwing out bits of toilet paper probably works better. Hmmm, Lets see.....what would a toilet paper dispensing machine look like... Bill Daniels Someone beat you to it. Ted Teach had a 1-26 with a toilet paper dispensing mechanism in the turtledeck. It was a little trapdoor with a cutting edge. Open the door and toilet paper unrolled into the slipstream. Close the door and it severed the paper. Repeatedly opening and closing the door supposedly dispensed tp chaff to be followed as a thermal marker. Teach's 1-26 also had a reprofiled nose and canopy and doors that enclosed the landing gear (retractable gear being against the rules in 1-26 racing. Mark Connor later had this 1-26 and was undoing all the "Teachisms" on it. In all seriousness, the bubble experiments produced some very good insights in low level convective airflow. Neutrally buoyant bubbles have no aerodynamic qualities of their own so if they are seen to move, it is because airflow is pushing them. Bits of paper and other debris do have some aerodynamic qualities so the data is corrupted. Up to that point there were several studies that used smoke, but that can't be analyzed numerically. Discrete bubbles provided a means to measure speed and direction of airflow in 3D to high precision. Later, larger scale experiments with Mylar balloons were even more interesting. First pairs would be released and tracked for many miles by radar. Eventually, large numbers of these balloons were released simultaneously along a crosswind line in thermic conditions and watched by radar as they traced out thermal streets. Today, most work of this kind is done with LIDAR (Laser Radar) which can track naturally occurring tiny aerosols of pollen and dust revealing the 3D structure of airflow with great precision over a large area in real time. Now, putting a LIDAR in a glider WOULD be interesting. Bill Daniels |
On Mon, 19 Apr 2004 16:39:49 GMT, "Bill Daniels"
wrote: [snip] So, would your idea work? I proved it would but all that heavy gear will be pretty hard to get into a glider. Throwing out bits of toilet paper probably works better. Hmmm, Lets see.....what would a toilet paper dispensing machine look like... A building with a sign saying "Ziff-Davis"? rj |
Perhaps NASA will help us with thermal locating. Quoting from a CNN article
currently at http://www.cnn.com/2004/TECH/space/0...vil/index.html : Dust particles in a devil become electrified because they rub against one another. It's like shuffling your feet across the carpet, the researchers explained. But they figured the positive and negative particles would be evenly mixed in a dust devil, keeping the overall electrical charge in balance. Instead, it turns out smaller particles tend to gain negative charge, and the wind carries them higher. Heavier, positive particles remain nearer the surface. The separation of charges creates a giant battery. And because the particles are in motion, a magnetic field is generated by the moving electrical charges, the researchers explained. They don't yet know for sure what to expect on Mars. If dust on the red planet comes in a variety of sizes and compositions, as expected, then dust devils there ought to be similarly electrified, the scientists said. NASA could equip a future Mars landing craft with an instrument to detect a dust devil's electric and magnetic fields. Mike Koerner "iPilot" wrote in message ... Actually for thermal marking purporses smoke would work pretty fine. But I don't know any smoke machine which is small enough to fit to the glider and which is controllable. For aerobatics they just fit smoking cartridges that burn to the end after ignition, but thermal marking needs some repeatable 2 sec buffs of somke. There's another problem with bubbles. The only reasonable place to put it is on top of the rear fuselage. But then you spill the vertical fin with wet bubbles and this harms your L/D. Regards, Kaido "Bill Daniels" wrote in message news:t6ahc.33650$ru4.33232@attbi_s52... "Wallace Berry" wrote in message ... So, would your idea work? I proved it would but all that heavy gear will be pretty hard to get into a glider. Throwing out bits of toilet paper probably works better. Hmmm, Lets see.....what would a toilet paper dispensing machine look like... Bill Daniels Someone beat you to it. Ted Teach had a 1-26 with a toilet paper dispensing mechanism in the turtledeck. It was a little trapdoor with a cutting edge. Open the door and toilet paper unrolled into the slipstream. Close the door and it severed the paper. Repeatedly opening and closing the door supposedly dispensed tp chaff to be followed as a thermal marker. Teach's 1-26 also had a reprofiled nose and canopy and doors that enclosed the landing gear (retractable gear being against the rules in 1-26 racing. Mark Connor later had this 1-26 and was undoing all the "Teachisms" on it. In all seriousness, the bubble experiments produced some very good insights in low level convective airflow. Neutrally buoyant bubbles have no aerodynamic qualities of their own so if they are seen to move, it is because airflow is pushing them. Bits of paper and other debris do have some aerodynamic qualities so the data is corrupted. Up to that point there were several studies that used smoke, but that can't be analyzed numerically. Discrete bubbles provided a means to measure speed and direction of airflow in 3D to high precision. Later, larger scale experiments with Mylar balloons were even more interesting. First pairs would be released and tracked for many miles by radar. Eventually, large numbers of these balloons were released simultaneously along a crosswind line in thermic conditions and watched by radar as they traced out thermal streets. Today, most work of this kind is done with LIDAR (Laser Radar) which can track naturally occurring tiny aerosols of pollen and dust revealing the 3D structure of airflow with great precision over a large area in real time. Now, putting a LIDAR in a glider WOULD be interesting. Bill Daniels |
"Mike Koerner" wrote in message news:AZohc.25214$Yf6.24446@fed1read07...
Perhaps NASA will help us with thermal locating. Quoting from a CNN article currently at http://www.cnn.com/2004/TECH/space/0...vil/index.html : Dust particles in a devil become electrified because they rub against one another. It's like shuffling your feet across the carpet, the researchers explained. But they figured the positive and negative particles would be evenly mixed in a dust devil, keeping the overall electrical charge in balance. Instead, it turns out smaller particles tend to gain negative charge, and the wind carries them higher. Heavier, positive particles remain nearer the surface. The separation of charges creates a giant battery. And because the particles are in motion, a magnetic field is generated by the moving electrical charges, the researchers explained. They don't yet know for sure what to expect on Mars. Famous modeler Maynard Hill studied varying electric charge related to thermals about 25 or 30 years ago. As I recall he found that there was a horizontal differential related to thermals. So- he built a device to sense this and steer the model into the thermal- so cool! Then he tested it- When turned on it would not turn aircraft into the thermal and in fact kept the wings absolutely level. Darn! Why? It turns out that the vertical voltage potential around the earth is far stronger than the horizontal one due to thermals. The good news- He invented the electrostatic wing leveler. UH If dust on the red planet comes in a variety of sizes and compositions, as expected, then dust devils there ought to be similarly electrified, the scientists said. NASA could equip a future Mars landing craft with an instrument to detect a dust devil's electric and magnetic fields. Mike Koerner "iPilot" wrote in message ... Actually for thermal marking purporses smoke would work pretty fine. But I don't know any smoke machine which is small enough to fit to the glider and which is controllable. For aerobatics they just fit smoking cartridges that burn to the end after ignition, but thermal marking needs some repeatable 2 sec buffs of somke. There's another problem with bubbles. The only reasonable place to put it is on top of the rear fuselage. But then you spill the vertical fin with wet bubbles and this harms your L/D. Regards, Kaido "Bill Daniels" wrote in message news:t6ahc.33650$ru4.33232@attbi_s52... "Wallace Berry" wrote in message ... So, would your idea work? I proved it would but all that heavy gear will be pretty hard to get into a glider. Throwing out bits of toilet paper probably works better. Hmmm, Lets see.....what would a toilet paper dispensing machine look like... Bill Daniels Someone beat you to it. Ted Teach had a 1-26 with a toilet paper dispensing mechanism in the turtledeck. It was a little trapdoor with a cutting edge. Open the door and toilet paper unrolled into the slipstream. Close the door and it severed the paper. Repeatedly opening and closing the door supposedly dispensed tp chaff to be followed as a thermal marker. Teach's 1-26 also had a reprofiled nose and canopy and doors that enclosed the landing gear (retractable gear being against the rules in 1-26 racing. Mark Connor later had this 1-26 and was undoing all the "Teachisms" on it. In all seriousness, the bubble experiments produced some very good insights in low level convective airflow. Neutrally buoyant bubbles have no aerodynamic qualities of their own so if they are seen to move, it is because airflow is pushing them. Bits of paper and other debris do have some aerodynamic qualities so the data is corrupted. Up to that point there were several studies that used smoke, but that can't be analyzed numerically. Discrete bubbles provided a means to measure speed and direction of airflow in 3D to high precision. Later, larger scale experiments with Mylar balloons were even more interesting. First pairs would be released and tracked for many miles by radar. Eventually, large numbers of these balloons were released simultaneously along a crosswind line in thermic conditions and watched by radar as they traced out thermal streets. Today, most work of this kind is done with LIDAR (Laser Radar) which can track naturally occurring tiny aerosols of pollen and dust revealing the 3D structure of airflow with great precision over a large area in real time. Now, putting a LIDAR in a glider WOULD be interesting. Bill Daniels |
![]() "Hank Nixon" wrote in message Famous modeler Maynard Hill studied varying electric charge related to thermals about 25 or 30 years ago. As I recall he found that there was a horizontal differential related to thermals. So- he built a device to sense this and steer the model into the thermal- so cool! Then he tested it- When turned on it would not turn aircraft into the thermal and in fact kept the wings absolutely level. Darn! Why? It turns out that the vertical voltage potential around the earth is far stronger than the horizontal one due to thermals. The good news- He invented the electrostatic wing leveler. UH It's fascinating that after decades of looking at thermals with the entire electromagnetic spectrum, sampling the chemistry, listening to the sounds and using every known sensing technology, the one consistent characteristic is that they are updrafts! The effect of air motion on a glider is still the only way they can be detected reliably. LIDAR might open a tiny window for remote sensing. I have thought of a low power, short range LIDAR that would sweep left and right of a line angled down 45 degrees from the horizontal. It would look for bubbles rising from below out to 100 meters or so to the front and left or right of the glider. This would be enough to have a major impact on the probability of encountering lift. It would also be a great help in centering the best lift as it swept the sky to the outside of the thermalling turn looking for stronger cores. At the moment, I know of no way the weight and power consumption would allow a LIDAR to fit in a glider. Bill Daniels |
Rory O'Conor wrote:
were several studies that used smoke, but that can't be analyzed I was wondering about orange smoke flares but I can see that one might either fill the cockpit with an impenetrable haze or knock chucks off the horizontal stabiliser. Both would cause a greater degradation of performance than a need to pee. I can also see that flares attached to balloons are difficult to push through the clear view panel. But maybe the T21 will come in handy! I wonder how "skywriters" make their smoke and what the effect of thermalling with a smoke dispenser would be like, maybe personal IMC conditions. Thermals could be colour coded according to strength. If the dispenser was attached to the vario, then the smoke could be varied by colour according to lift, making it easier to move towards the green smoke and away from the red smoke. - with the potential to reverse the colours if needed to confuse the unwanted. Today, most work of this kind is done with LIDAR (Laser Radar) which can track naturally occurring tiny aerosols of pollen and dust revealing the 3D structure of airflow with great precision over a large area in real time. Has anyone any leads to accessible output on the results of LIDAR? Rory I thought the Northern soaring season had started already... |
I maybe mistaken, but I think there is something on the competition rules
that forbids the use of tools to "see" thermals ahead of the glider at a distance of more than a wingspan or so... So it could be good for centering thermals maybe, like the Themi, but probably not more than that. "Bill Daniels" wrote in message news:2Tuhc.171468$gA5.1991465@attbi_s03... "Hank Nixon" wrote in message Famous modeler Maynard Hill studied varying electric charge related to thermals about 25 or 30 years ago. As I recall he found that there was a horizontal differential related to thermals. So- he built a device to sense this and steer the model into the thermal- so cool! Then he tested it- When turned on it would not turn aircraft into the thermal and in fact kept the wings absolutely level. Darn! Why? It turns out that the vertical voltage potential around the earth is far stronger than the horizontal one due to thermals. The good news- He invented the electrostatic wing leveler. UH It's fascinating that after decades of looking at thermals with the entire electromagnetic spectrum, sampling the chemistry, listening to the sounds and using every known sensing technology, the one consistent characteristic is that they are updrafts! The effect of air motion on a glider is still the only way they can be detected reliably. LIDAR might open a tiny window for remote sensing. I have thought of a low power, short range LIDAR that would sweep left and right of a line angled down 45 degrees from the horizontal. It would look for bubbles rising from below out to 100 meters or so to the front and left or right of the glider. This would be enough to have a major impact on the probability of encountering lift. It would also be a great help in centering the best lift as it swept the sky to the outside of the thermalling turn looking for stronger cores. At the moment, I know of no way the weight and power consumption would allow a LIDAR to fit in a glider. Bill Daniels |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Rotorcraft | 0 | April 29th 04 08:29 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Naval Aviation | 0 | April 29th 04 08:09 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Military Aviation | 0 | April 29th 04 06:45 PM |
Spin on thermal entry - how-to | Bill Daniels | Soaring | 0 | January 29th 04 05:43 PM |
Thermal to Wave contact! | C.Fleming | Soaring | 1 | January 21st 04 01:54 PM |
