Does any body have the BGA UK turnpoit list in .da4
format, or do you know where I can download it. The SAA site does not have that format available. Thanks. |
Have you try : http://acro.harvard.edu/SOARING/JL/TP ?
Regards, Frederic www.planeur.net - www.netcoupe.net "Croft Brown" wrote in message ... Does any body have the BGA UK turnpoit list in .da4 format, or do you know where I can download it. The SAA site does not have that format available. Thanks. |
At 15:18 28 April 2004, Croft Brown wrote:
Does any body have the BGA UK turnpoit list in .da4 format, or do you know where I can download it. The SAA site does not have that format available. Thanks. You didn't look very hard did you? http://acro.harvard.edu/SOARING/JL/T...n/BGASth04.da4 http://acro.harvard.edu/SOARING/JL/T...r/BGACen04.da4 http://acro.harvard.edu/SOARING/JL/T...s/BGAMid4a.da4 http://acro.harvard.edu/SOARING/JL/T...n/BGANrt4a.da4 http://acro.harvard.edu/SOARING/JL/T...d/Sctlnd4a.da4 They appear to be divided by region, presumably because the whole database won't fit a Filser. |
I would recommend using TP Select.
This will produce an extract of the 800 odd BGA waypoints in a suitable size (less than 500 for LX) and in almost any format. Rory |
X-no-archive: yes
In article , Andrew Warbrick writes At 15:18 28 April 2004, Croft Brown wrote: Does any body have the BGA UK turnpoit list in .da4 format, or do you know where I can download it. The SAA site does not have that format available. Thanks. You didn't look very hard did you? http://acro.harvard.edu/SOARING/JL/T...n/BGASth04.da4 http://acro.harvard.edu/SOARING/JL/T...r/BGACen04.da4 http://acro.harvard.edu/SOARING/JL/T...s/BGAMid4a.da4 http://acro.harvard.edu/SOARING/JL/T...n/BGANrt4a.da4 http://acro.harvard.edu/SOARING/JL/T...d/Sctlnd4a.da4 They appear to be divided by region, presumably because the whole database won't fit a Filser. That is absolutely correct. There is a note about this on the BGA Waypoint Web page (http://www.spsys.demon.co.uk/turningpoints.htm), but every year it catches someone out. Incidentally, the Midlands, Northern and Scotland files have been updates in the last week, but the is because Four Counties have moved from Syerston to Barkston Heath. If you don't fly from Barkston Heath, this shouldn't affect you. Tim Newport-Peace "Indecision is the Key to Flexibility." |
X-no-archive: yes
In article , Tim Newport-Peace ] writes X-no-archive: yes In article , Andrew Warbrick writes At 15:18 28 April 2004, Croft Brown wrote: Does any body have the BGA UK turnpoit list in .da4 format, or do you know where I can download it. The SAA site does not have that format available. Thanks. You didn't look very hard did you? http://acro.harvard.edu/SOARING/JL/T...n/BGASth04.da4 http://acro.harvard.edu/SOARING/JL/T...r/BGACen04.da4 http://acro.harvard.edu/SOARING/JL/T...s/BGAMid4a.da4 http://acro.harvard.edu/SOARING/JL/T...n/BGANrt4a.da4 http://acro.harvard.edu/SOARING/JL/T...d/Sctlnd4a.da4 They appear to be divided by region, presumably because the whole database won't fit a Filser. That is absolutely correct. There is a note about this on the BGA Waypoint Web page (http://www.spsys.demon.co.uk/turningpoints.htm), but every year it catches someone out. UPDATE: As a number of people have encountered the same problem, the site has been changed and when the is not sufficient space in the manufacturer's format for all the waypoints, the download symbol with a large red cross over it displayed. If this happens for the format you want, go to a regional list. Tim Newport-Peace "Indecision is the Key to Flexibility." |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | June 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | April 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | March 1st 04 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | January 1st 04 06:27 AM |
