Anti Collision Warning
Old April 30th 04, 06:10 PM
Bill Daniels
"Rory O'Conor" wrote in message
Mid Air collisions are a problem. Maybe we need to
pull together more information about them.
There are a number of different phases of flight
during which they occur:
Climbing phase (high Angle of Attack)
(power planes only)
Circuit phase (all planes)
Aerobatics (all planes)
IFR & low visibility flight (all planes)
Normal flight (all planes)
Thermalling (soaring planes only)
We need to understand the proportion of collisions
occurring in the different phases and the potential
contributory factors. Road Traffic Accidents happen
more often in good weather than bad. It is not
entirely clear that thermal collisions happen more
often in competition gaggles than when there are only
two in a thermal, whatever our instincts.
For the different flight phases, different factors
will be more or less important and the solutions and
devices to prevent collisions may be different.
Personnally I would be surprised if TCAS devices could
cope with resolving the trajectories of thermalling
gliders other than the basic level of identifying
another nearby plane. Thus I suspect that the main
detection instrument in thermals remains the eyeball.
In which case, every effort should be made to ensure
the best use of the eyeball in thermals.
There may be a role for such devices in other phases
eg normal flight and IFR.
The only power planes that regularly fly close
together are the military and aerobatic display teams.
I am sure that the Red Arrows are fitted with the
instruments that they best require, but I would be
most surprised if they have any electronic device
warning them that they are about to hit a team-mate.
I expect that they do a lot of training, have superb
lookout and excellent communications.
I would assume that a TCAS/GPS device will be making
noises at 1 mile and probably very loud noises at 1/4
mile (1500 ft). With a typical thermalling diameter
of 200-600 feet and circling period of less than 20
seconds, any normal TCAS would be screaming fit to be
turned off!
We are also entering the area where the margin of
error for a GPS (30 ft horizontally, 100 ft
vertically) is a significant issue. GPS is not
accurate enough to tell which side of the highway you
are driving on, nor probably to determine the correct
seperation of two thermalling gliders when the pilots
using their eyeballs consider that they are adequately
seperated.
I cannot envisage an electronic GPS device for
avoiding intra-thermal collisions, assuming that the
planes are going to remain in the same thermal.
Rory
And yet another....
Bill Daniels
  #32
Old April 30th 04, 06:14 PM
Bill Daniels
"Dave Martin" wrote in message
This is what it boils down to EDUCATION/TRAINING
Training pilots how to look out.
How to concentrate,
What the dangers are, real and perceived and potential
and where these danger lurk in a particular phase of
flight.
We will never eliminate accidents but by education
we can reduce the opportunities. Train hard fly easy
as some one said!
Dave
(power planes only)
be
turned off!
seperated.
Rory
We've trained and trained for 100 years and yet we still have collisions.
The 'Mark 20 eyeball' is a good tool but it isn't the total solution.
Humans just can't maintain the vigilance required. We have plenty of
evidence of that both clinical and anecdotal.
Bill Daniels
  #33
Old April 30th 04, 07:19 PM
Ramy Yanetz
I'm surprised people still beleive that eyes are better than
electronic equipment.
Consider the following:
1 - You don't see behind and below, and even forward visibility is
somewhat restricted, depend on cockpit style.
2 - We fly invisible aircrafts. Did you notice how quickly a sailplane
disappears when it flies away? If you stand on a runway behind a
launching glider it almost disappears before it reaches the end of the
runway, this is less than a mile!
3 - While you can notice planty of aircrafts flying nearby, the ones
on a direct collision course are the hardest to detect since they look
stationary relatively to you! I once barely noticed while thermaling a
strange stationary dot in the sky and wondered what was it, the next
turn it turned into an airliner heading directly to me and I had to
perform an evasive maneuver! Since then I am flying with a transponder
and never saw an airliner nearby again.
4 - The above gets even more difficult if not impossible to detect
when the threat is flying perpendicular to you.
5 - The main reason why we don't colide with other aircrafts more
often is simply the fact that the sky is (still) big and the chance
that 2 aircrafts will occupy the same 4 dimensions is rare.
Ramy
Dave Martin wrote in message ...
At 05:12 30 April 2004, Graeme Cant wrote:
Dave Martin wrote:
Whatever happened to teaching good look out and airmanship?
Nothing. It's still taught and practiced as effectively,
efficiently and thoroughly as it ever was - and has
been for many years. And it's just as ineffective
as it ever was.
Are you one of those who see it as simply a problem
of laziness and complacency? You're probably right
but they're both endemic in human nature and won't
change now. For jobs as important as this, monitoring
systems designed with built-in tendencies to distraction
and complacency and with multiple duties just to top
it off - are simply inadequate
and always will be.
All forms of training in lookout are doomed to fail
because of basic human limitations. Not just optical
limitations. Humans are simply bad at continuous alertness
and monitoring for a very low probability threat over
a long period. That's why we no longer have engineer's
panels in the flight decks of large aeroplanes. There's
as much or more to monitor than there always was -
we've just accepted that humans don't do it well and
found other solutions.
Gliders have the highest rate of midairs of all forms
of hard wing aviation. I'm happy with the collision
threat and the things I do to minimise it and I'll
go on flying gliders. If you're not happy, Dave, you
need to accept that it won't be improved without electronic
assistance.
Isn't 50 or more years enough?
Graeme Cant
Graeme
Where did I say I wasn't happy with the present situation
Adding an electronic device will not ease the problem,
in the majority of cases it could compound the problems
faced by the average pilot.
Large aircraft do not fly in close proximity to others
in great numbers such as a thermal gaggle. They also
have such things as transponders, outside radar support
from control towers and other sophisticated equipment
plus the electronic power to support all the devices.
In the main they fly in regulated airspace, where everyone
has the same equipment
Flying in isolation such a device may help but in crowded
skies I suspect the information supplied would overload
the equipment and pilot, as you say above, 'Humans
are simply bad at continuous alertness and monitoring
for a very low probability threat over a long period.'
How does this equate with a large competiton gaggle
who must monitor high probability threats over long
periods say several hours and during their flight will
meet others not in their competition on their flight
path. I suppose someone will say they train for this
type of flying.
Fitting units to gliders in isolation will also give
the pilot a false sense of security.
You ask, 'Isn't 50 or more years enough?'
1 year is too long!
Dave
  #34
Old April 30th 04, 11:16 PM
Finbar
We've tried "look out the window." We still have collisions. Since
human capabilities change only over evolutionary time, and training
programs that encourage good use of existing capabilities have been in
place for some time, we should assume that training and exhortations
have achieved as much improvement as they ever will. The remaining
collision risk must be reduced through some other means.
The traffic pattern and thermals are two high-density traffic
environments where aircraft maneuvering renders collision prediction
difficult. It's not just difficult for machines, it's also difficult
for pilots. During pilot training the task must be taught in several
steps: 1) be aware of how many other aircraft are nearby 2) locate
them 3) avoid getting close to those aircraft unless necessary 4) if
proximity is necessary, watch (i.e., try to predict) the path of the
other aircraft and avoid going toward the place where it is going 5)
learn to anticipate possible unpredictable variations in the path of
the other aircraft also and avoid going toward those areas. Level 5)
is probably only required in thermals and in formation flying. When
we begin thermaling, most of us have to use 3) because we're not good
enough at 4) or 5).
However, at the moment pilots are much better than machines at 4) and
5), while machines are much better than pilots at 1) and 2). Yet, if
1) fails, the rest is useless.
The fact that machines can't do the whole job does NOT mean they can't
be helpful. A machine that could inform a pilot that there are 5
other aircraft in the thermal within +/- 500 ft would be valuable to a
very alert contest pilot who could account for only 4 of them. The
tasks of finding the 5th, and avoiding all 5, might still have to rely
on the Mark I Eyeball.
Of course, pilots in gaggles know that they are in a high
collision-risk situation, and they devote significant attention to
seeing and avoiding other aircraft. Pilots who think they are alone
in the sky devote much less mental capacity to those tasks. Insisting
on "always" maintaining lookout vigilance is ill-advised: many of us
have a pretty high cognitive load a high percentage of the time in
flight, and if we devote too much attention to lookout we may well
lose navigational or meteorological situational awareness, or even
just tire ourselves out mentally, leaving ourselves vulnerable when
attention is important later. This is where a machine could help, by
maintaining a scan and verifying that, indeed, the collision risk is
low. If that changes, the machine can alert the pilot, allowing the
pilot to properly switch mental capacity to "see and avoid." In fact,
this is the primary benefit of flight following during powered VFR
flight, and it's no small benefit.
Insisting that a technology is useless unless it can solve the whole
problem makes perfection the enemy of the good. It's also, in this
case, blind to the imperfection of the current technology - the Mark I
Eyeball - which plenty of science has shown is, in most near-miss
scenarios, far less valuable than the sheer size of the sky.
  #35
Old May 1st 04, 12:00 AM
Mike Borgelt
efl
Finbar, I think that post sums it up nicely. The Swiss FLARM would
appear to be a good start.
Having something say " traffic, 5 miles. closing, level" would give
you something to look for and would essentially be an automated and
autonomous flight following service.
Unfortunately we won't get sensible ADS-B anytime soon at any
reasonable price for the rest of aviation. Take a look at the system
specifications and you'll soon see it is over specified by about 3
orders of magnitude. Politics again.
A simple GPS/VHF based system was demonstrated in Australia a few
years ago but the authorities didn't follow through because there were
no ICAO standards for such a system. Even now ADS-B looks like
operating on different frequencies in different countries.
Mike Borgelt
  #36
Old May 1st 04, 06:49 AM
Finbar
Mike,
The FLARM concept has been painfully obvious, from a technology point
of view, since the introduction of low-cost GPS. In fact, it could
even have been partially implemented with LORAN, but those receivers
were expensive and were never widely deployed.
Unfortunately, FLARM-type collision avoidance is only going to work if
it's deployed to virtually all aircraft, which would require the
authorities to insist on it. This won't happen: ADS-B is the chosen
approach.
It seems to me that TIS-B is most likely what will first begin to
provide us with the functionality we need - and actually get deployed.
TIS-B (Traffic Information Service - Broadcast) is a portion of
ADS-B, essentially a broadcast of the radar returns seen by ATC. At
the moment it has limited coverage in the US but you can receive it -
however you need to spend about $15,000 on avionics including a Mode S
transponder plus a display unit designed for bigger panels than we
have. Still, no doubt it will soon occur to some entrepreneur that a
TIS-B receiver without all the Mode S baggage, designed for display on
a PDA might well find a market (lots of Cezzna drivers think $15k is a
lot of money too).
  #37
Old May 1st 04, 07:07 AM
Eric Greenwell
Don Johnstone wrote:
The answer is, good lookout, good situational awareness
and the ability to put safety first, press on itius
second.
This doesn't sound like an answer to me. I do all those things, yet I've
still come close to collisions.
Don't expect the other guy to get out of your
way, get out of his, and if that means he has an advantage,
sobeit, at least you continue to fly on intact.
I don't expect the other guy to get out of my way, but I've still come
These have generally been contest situations involving many gliders, but
not always. An effective, but not perfect, way to avoid collsions is to
always fly well away from other gliders. It's not a perfect way, because
you can't stop other glider from seeing you and joining you.
I'm surprised people are willing to claim a technological solution is
unworkable without any demonstration of it's ability. How can you say
"The answer is, good lookout, good situational awareness and the ability
to put safety first, press on itius second", when you have no data on
the proposed solution? Wouldn't a better remark be "Try it, and show us
the results?"
Eric Greenwell
Washington State
USA
  #38
Old May 1st 04, 10:00 AM
OscarCVox
In a recent mid air in the UK it was a quiet day, bright and hazy with poor
visability. There were only 3 or 4 aircraft in the air at the same time.
Percieved low risk of collision so level of lookout was low?
A very experienced (10,000+ hrs in gliders) was killed.
  #39
Old May 1st 04, 11:41 AM
Dave Martin
Anti-collision warnings
Once again a thread on RAS has polarised neatly into
two camps
Argument 1.
The mark 1 eyeball and the USB (Universal Standard
Brain) are the best!
Train them and the problem is solved.
Argument 2
Statistics show the above equipment is outdated for
present needs it needs replacing or providing with
some assistance.
OK.
Accept that at present theory 1 is the best we have
come up with so far and that change is needed.
The challenge is now how to assist the brain solve
the problem. Individuals are not the probelm, it is
everyone else out there who is trying to get you. Remember
it is the aircraft you do not see that gets you!
So all we need is a simple instrument that meets the
following criteria.
1. It will detect at least 40 gliders in close proximity.
2. Plus those within a 5 nautical mile range.
3. Work out their relative positions.
4. Assess the collision threat of each and every one.
5. Feed the information to the pilot of each glider
in a readable format that can be assessed within the
bat of an eyelid.
6. Develop the instrument with little financial assistance
from within the movement.
7. Ensure every glider has the equipment fitted.
8. Ensure the equipment works with very little power
consumption.
9. Ensure that the cost is no more that a launch fee.
10. Make fitting compulsary to ALL aircraft flying
in uncontrolled airspace.
No one who fits any form of instrument to his glider
can be accused of being anti progress. BUT until the
above problems are more than half solved the practicalities
of a succesfull anti collision device are low.
In he mean time I return to argument 1. At present
this is the best we have!
If technology comes up with a reliable assistant this
must be good until then WE MUST ensure that our pilots
are trained on the dangers that lurk out there.
Dave
  #40
Old May 1st 04, 12:49 PM
W.J. \(Bill\) Dean \(U.K.\).
Who are you, OscarCVox? Why the nickname?
Where do you fly?
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
Talgarth, Nympsfield, Mynd, formerly Lasham for over 20 years.
"OscarCVox" wrote in message
poor visibility.
Perceived low risk of collision so level of lookout was low?
For Keith Willshaw... robert arndt Military Aviation 253 July 6th 04 05:18 AM
Anti collision lights mods for Arrow 1968?? Frode Berg Piloting 3 May 20th 04 05:42 AM
Anti collision light mod for Piper Arrow 1968 model? Frode Berg Owning 4 May 20th 04 05:16 AM
New anti collision system for aircrafts, helicopters and gliders Thierry Owning 10 February 14th 04 08:36 AM
