Off topic - Metric Nuts
Old May 4th 04, 03:19 PM
Paul Remde
Default Off topic - Metric Nuts
Hi,
This post is a bit off-topic, but it relates to the soaring goosenecks I
sell. The require M10 x 1mm pitch nuts. I've been trying for months to
find small, thin (3 mm or less) nuts for the goosenecks. All the US
suppliers I've contacted can supply metric nuts with the right inner
diameter and thread pitch, but they have all been 8 to 10 mm thick.
I'm posting this dilemma here because I know there are many resourceful
glider pilots and I'll bet that someone will be able to clue me in on a good
US source for these parts.
Please help! Please reply to my e-mail address so as not to bore the
readers of r.a.s. with this off-topic question.
Thank you,
Paul Remde
Old May 4th 04, 03:38 PM
Bob Kuykendall
Earlier, Paul Remde wrote:
...All the US suppliers I've contacted
inner diameter and thread pitch, but
they have all been 8 to 10 mm thick...
My two suggestions would be:
1. Try Mr. Metric in San Jose, CA:
http://www.mrmetric.com
2. Make a drawing of what you need and shop it out
on mfgquote.com. They'd be very easy to make by cutting
down the full-size nuts, and not too hard to make from
raw hex bar.
Bob K.
Old May 4th 04, 05:36 PM
Mark Zivley
GRINDER....
Paul Remde wrote:
Hi,
Thank you,
Paul Remde
Old May 4th 04, 05:37 PM
Vaughn Simon
Ask this question at rec.crafts.metalworking
"Paul Remde" wrote in message
news:_DNlc.30299$kh4.1519426@attbi_s52...
Hi,
good
Thank you,
Paul Remde
Old May 4th 04, 05:43 PM
Shawn Curry
Where's Lennie when you need him?
Old May 4th 04, 06:14 PM
Paul Remde
Hi,
A tip lead me to www.fastenerplace.com. He didn't have them in stock but he
ordered the parts I needed.
Thanks for the tip JC.
Thanks,
Paul Remde
Hi,
good
Thank you,
Paul Remde
Old May 5th 04, 01:01 AM
Walter Kronester
Hello Paul,
M10x1 is used for lamp sockets in Europe (as well as for hydraulic brakes).
Lamp sockets are often fixed with small (~2mm) M10x1 nuts.
So it may be better to look for electric part supliers than for screw shops.
Regards Walter
Old May 5th 04, 09:11 PM
Rod
Paul, I can probably find what you need at one of the local hardware stores
here in Switzerland.
Cheers,
Rod
Old May 5th 04, 11:15 PM
Paul Remde
Hi Rod,
Thanks! I found some metric nuts that are 5 mm tall, but I'd love a box of
100 if you can find some that are anywhere from 1 to 3 mm tall. They must
be M10 x 1mm (pitch).
Paul Remde
"Rod" wrote in message
stores
Cheers,
Rod
Proposal: use OT (off topic) Scott Moore Instrument Flight Rules 7 November 14th 04 09:47 PM
Metric measuring tool source? DL152279546231 Home Built 12 April 29th 04 02:13 AM
metric system newsgroup call for votes #1 Paul Hirose Military Aviation 72 November 16th 03 06:59 PM
Edwards air show B-1 speed record attempt Paul Hirose Military Aviation 146 November 3rd 03 05:18 PM
Wanted - Metric Altimeters RHWOODY Soaring 0 September 13th 03 10:20 PM
